AVS - Is it Working?
Old Feb 13, 2015 | 10:40 AM
rentschl's Avatar
rentschl
5th Gear
Default AVS - Is it Working?
I acquired an '09 GX470 (42k miles) and I'm trying to tell if my AVS is really working.
I owned a 4Runner Limited with XREAS before. I was assuming that the GX470, since it had 4 settings, would provide a range that could be more sporty or more plush than the 4Runner XREAS single, fixed setting is.
But I also realize that it might not be completely straight forward to compare the two, since the AVS supposedly changes its damping dynamically based on driving conditions.
I would expect that I should easily be able to tell if my AVS is working when I switch between settings.
I cannot tell at all.
Do others agree that this probably means that my AVS is broken?
Or are the settings only subtlety different such that it might actually be working and is just hard to tell the difference?
Any comments appreciated!
-Eric
Old Feb 13, 2015 | 01:30 PM
lesz's Avatar
lesz
With my GX, changing the suspension settings results in a clearly noticeable change in ride quality. While I might describe the difference between two adjacent settings as being fairly subtle, it is immediately noticeable if the setting is changed from the softest setting to the firmest setting.
Old Feb 15, 2015 | 08:26 AM
IanB2's Avatar
IanB2
I hadn't read the thread earlier, and assumed from the title you were asking about the audio/visual system, lol. What does AVS stand for to you?
As above, if you switch from full soft to full firm while driving, you can tell the difference, but it's not crazy obvious to me.
Old Feb 16, 2015 | 08:59 PM
GreatHim's Avatar
GreatHim
same here, the change is noticeable going from soft to firm, but not from going one at a time.
Old Feb 16, 2015 | 11:21 PM
LexRex's Avatar
LexRex
He means Adaptive variable suspension.
alawode
GX - 2nd Gen (2010-2023)
Apr 23, 2014 06:59 AM
DSW
GX - 1st Gen (2003-2009)
26
Mar 11, 2005 02:52 AM
SacKen
Oct 25, 2004 09:21 AM
