Rake?
Old Jan 6, 2015 | 02:09 PM
cdew002's Avatar
cdew002
Default Rake?
Anyone know off the top of their head what the rake is on our vehicles? The lift kit I ordered came with a half inch spacer to use (if desired) on vehicles with a rake.
Don't want to put it on only to find it lifts the front too much.
Thanks
Cliff
Old Jan 7, 2015 | 02:49 PM
Rz500's Avatar
Rz500
I did a 4 1/2" lift on mine in the front and 3 in the rear. My measurements prior to the lift were around 1 1/2" difference front to rear. Now it's pretty much level. Hope this helps. Good luck with your project.
Old Jan 7, 2015 | 05:24 PM
cdew002's Avatar
cdew002
It does - thanks!
I don't think I've seen pics of your ride. Do you have any you could post?
Old Jan 8, 2015 | 10:25 AM
Rz500's Avatar
Rz500
Old Jan 8, 2015 | 10:38 AM
470SNC's Avatar
470SNC
that looks more like a 3.5"/2" lift to me, this is mine (3.5" in front, 2" in back w Icons)
Old Jan 8, 2015 | 12:19 PM
cdew002's Avatar
cdew002
Love it. Y'all are making me want to brave this cold Alabama air and put my lift on.
Cliff
Old Jan 8, 2015 | 06:19 PM
abatodu's Avatar
abatodu
geez that lift looks sick! Love it!
Old Jan 13, 2015 | 06:34 PM
wademracer's Avatar
wademracer
RZ500 what size tires are you running? Do you have wheel spacers?
Old Jan 14, 2015 | 04:24 AM
Rz500's Avatar
Rz500
Tires are Goodyear 285-70-17. Yes I am running wheel spacers. If I remember correctly they are 1.25". They came from spider trax. The front lift is OME springs with a spacer on top of the strut. For the rear I machined my own 2.5" spacers that sit under the air bags. My final ride height was adjusted by tweaking the height sensors. My air ride and adjustable suspension all still function as intended. A 1" diff drop and sway bar relocation kit were also installed. The majority of the parts I used came from toytec. When the weather is a little nicer out I'll have to take some current pictures. The rear end sits about 1.5" higher now and I have installed centre caps on the wheels.
Shmee
20
Oct 16, 2013 05:49 PM
AtlantaVIP
Nov 17, 2011 04:10 PM
JiBBeL
Aug 8, 2010 01:19 PM
passnu2
May 17, 2010 03:44 PM
D-MAN63
Jul 31, 2005 10:26 PM
