- gs 300 exhaust system q's
- Coil overs
- Gs 300 1996 : Starts cuts off
- ac problem tx heat!!!
- Blew my motor... Here's my options. Advice?
- Wheel Fitment Question!!
- 18 inch Wheels Thread
- back seat.anchors
- Cold Start Issue
- JDM Aristo Tail Light conversion?
- 1995 gs300 2jzgte swap HELP!!
- Tein Super Street Coilovers
- 1993 gs300 fuse issue no power, need help ASAP!
- Need input ASAP
- Sound System, heres what i did.
- New 1st Gen owner. need help with Apexi SAFC1
- WTB, WTT and FS posts go into classifieds forum once eligibility is reached.
- Any one here put in a 2jzgte vvti jzs161 into a jzs147 ? Need help to wire it up ..
- First time posting 95 gs300
- New to forms
- Forced to sit her down
- DIY Fuel Filter change/replace
- 6x9 Speakers Post ur pix!
- You guys have got to see this
- i'm pissed
- Strangest thing ever!
- Really concerned. ..
- Long over due
- GS300 2JZ Swap issues
- What is the "short pin" in DLC1 for?
- is this worth buying?
- I need some help
- Anyone ever loaded UAS Air Bags on stock struts?
- Just a quick one: how does 1st Gen GS300 feel?
- Fuse box diagram?
- gs300 i found at a salvage yard
- how much did it cost to buy a 1st gen gs300 brand new?
- A/c compressor continuously runs even when turned off
- Intermittant ABS light
- picked up a 93 gs300 for 1,300
- My $400 score :)
- Question on which bushings should be changed
- Front crank seal?
- 91-97 Aristo/ GS300 Fuel pump ECU location
- weird shutdown
- Gs300 owner
- Correct way to remove O/D button and back cover on shift knob without breaking?
- my 1st gen gs..named ghost.
- Power Steering
- Turbo Question
- power seat malfunction
- Overheating problem cant solve
- Is this the right water pump? Fan won't mount to water pump (pic)
- H.I.D. Problem
- help turbo issues
- Windows Stuck
- Adjustable Tow Arms??
- 96' GS300 Transmission
- Is it possible to replace power steering reservoir with out replacing pump?
- DIY ?s......Am I being overcharged??
- lower Rear control arm ball joint replacement
- Aristo Vaccume Diagram
- Help! Please!
- Just got her (1994 gs300)
- jzs147 rear bushings
- 2jz ge oil pan o ring
- 1995 GS300 Rims and Off Set
- Im back! AGAIN! For the 3rd time!
- would you swap 2jzgte?
- Window seal thing bent
- Where can I get a 1994 GS300 Factory Service Manual?
- Does the 94 GS300 Ca Emissions have A/F ratio sensors instead of regular O2 sensors?
- Should I swap to a Auto Supra diff housing???
- Going to Check out a 93' GS Today
- Can We Fix the DIY section?
- TPS and Oxygen sensor codes
- 03 GS 300 14 mpg :-(
- Wipers not working untill washer button is pushed?
- Fog Mod for 1st gen GS
- power steering problem
- 1st gen GS300 Miss Firing
- Code 71 - Tried Almost Everything (replaced everything)
- New Member
- Replaced the ECU - did NOT fix my problems!!
- HELP! Detailers messed up my car!
- Tax Money!! What goodies you all get?
- thinking about giving the 1st gen GS a shot. Ls400 owner how do they compair?
- Please look! In need of major help, having electrical issues...
- Which SS brake lines for TT Supra Brake upgrade?
- Headlights
- swap of seating from first gen to second gen
- Help!!!
- ECU pin out
- Heater blows warm, then cold, then warm again
- AUX port/input with stock radio?
- New to the Lexus world with a 95 GS
- rear adjustable upper control arms
- Moving to Cali! Need help finding great shop!
- bypass hose on throttle body
- long time come back to CL with gs300
- ISCV Valve (AKA IAC VALVE) No power
- please help !!!!!!!!!!
- New Battery New alternator, still not charging
- My first Gen!
- 2nd Gen GS300 Seats in the first gen?
- Stereo rundown
- GS300 vs SC300 ECM compatibility
- finally found a first gen
- Where to buy Junction Produce kit?
- Power steering pump
- Way too much Fuel!
- Cracked Exhaust Manifold
- Tires and rims
- Ok here we go...
- Things to look for when buying used GS
- Code 78
- Door Lock Actuator, Rear Passenger Door Install
- 1993 GS300 w58 swap A/T ECU
- Anyone using a MSD Blaster Coil?
- Converting from Clutch Fan to Electric Fan
- rear upper control arms
- UGH! Trouble removing rear passenger door panel to replace lock actuator!
- Transmission hard shifting
- Code DTC: 12 CEL on. Rpm signal. Help please.
- LS400 shocks
- Transmisson swap
- Tein SKY98-BUB00 High.Tech
- Lost 1994 GS300 Key
- Nnnnooooooo!!!!
- 1993 gs300 car is running rough
- Traction Control CEL after snow
- Happy New Year to all of the 1st Gen GS Owners!!
- Sub Woofer Upgrade and Crossover Questions
- Window Trim Removal
- sc tokico shocks
- 1st gen instagram page
- Parasitic Battery Drain..."Dome"
- Best piggy back out there????
- Key issue!!!!!!!
- Driverside Lean
- What'd Santa Bring You?
- #1 speed sensor location
- Foglight bulb help....
- JDM tail lights installed
- Yellow mustard sludge in radiator
- 1993 Water Pump Replaced, Gasket & O-Ring Left Out
- Racing seats and Swap Seats discussion thread
- JDM VVTI transmission into 93 GS
- Weight reduction. How light can you go??
- thoughts of a chaser conversion
- alternator
- Hot Running after heater valve replacement
- I Need a 2jz swap specialist!!!
- car shut down while driving!
- New Member-New Aristo-New License
- 1993 GS300 Speaker Sizes
- 93 GS300 Misfiring problem! Don't Know where to start for Diag
- Thought I would share this
- 93 gs stumbles when coming to a stop
- Help, Thinking of getting a gs400
- Alignment Issue
- Lower control arm #2 bushing?
- 1993 gs300
- Changing Heater Core
- Rack and Pinion: Pressure Return and Feed tube
- IS "Fuel Pump Relay" and EFI the same thing?
- 94 gs300 no power or sound to rear pass door
- Rear Differential Swap from LS400
- Help me from freezing.
- 1994 GS300 ECU Location
- 2JZ Swapped, IDLE HELP
- Over Drive Light Flashing Code 11???
- PLEASE HELP!! Mangled front bumper, what to do?
- 93 GS300 Grill Removal
- Idle Air Control Valve Problems
- 94 gs Power steering help!!! Advice wanted
- Odd question. .
- Trouble gs300/aristo swap. Torque converter?
- Motor mounts
- Help getting in since some bad storms
- broken glove box handle
- Pros and Cons between GS series
- need help with my radio
- 2000 Lexus GS 300 Low Voltage Problem
- 147 HVAC control LCD
- Newbie from the UK saying hello,
- just picked uo a 93
- 1993 gs300 help
- 93' GS300 Shaking
- 1st gen gs300 info needed
- Car dies, then won't start. Starts later and dies.
- Transmisson
- Have you removed (know how) the ECU from 1995?
- Head Lighting question
- Problems with fog lights...
- Facing a perdicament...
- this is my number 6 cylinder
- Car is overheating. Steam. From heater control valve hose.
- Need Advice: SUPER nice GS with bad head gasket
- New Parts
- Just started having problems....
- new photos
- Lexus gs300 toyota aristo
- Tire size
- Upgrading brakes
- Now the process begins
- General Intro
- Transmission Cooler Setup?
- Oil pump gasket....
- POLL: How many GS enthusiasts owned an SC?
- Steering wheel swaps
- Wheel Fitment Quetions
- gs300
- Fuel upgrade hanger and filter questions
- Meet my "Ex" 1995 GS300
- Overheating, A/C helping cool engine???
- OBD1 codes NOT displaying
- 1st Gen Replacement carpet
- new here! pics of my gs!
- power steering vacuum lines?
- Damn Trunk!!!
- injectors
- 1993 Lexus gs300 2jzgte boost cut
- ECU serial numbers
- Help! Car running horribly.
- First Gen fuse box diagram?
- Help identifying oil leak....
- Dreams really do come true....
- Help No Boost very rich 93 Gs300
- Wrecked.
- My Latest Find $700 Find
- Looking for some lights..
- Overdrive Kickdown Switch Problem
- Engine Mods and the Value of resale
- Help. Weird suspension problem.
- Question about radio
- cluster needles
- 02 sensor
- Body work question
- Rca's for 1st gen gs300
- K & M Missile JZS147
- Leather seats or rewrap
- Replacement differential for my imported gs300
- Front suspension issues/ concerns
- rollcenter adjusters
- Looking to buying a 95' GS
