Foglight bulb help....
Old Dec 22, 2013 | 09:38 AM
MyGS3's Avatar
MyGS3
Default Foglight bulb help....
Guys,
I need desperate help replacing the fog light bulbs. I've removed the housing and I've opened the part that exposes the bulb. For the life of me, I can't figure out how to remove the bulb. I've attached pictures of the part that has me stumped.
I know that I'm supposed to know how to change the bulbs...but I don't. Please help me out guys.
Attached Thumbnails Foglight bulb help....-photo.jpg   Foglight bulb help....-photo-1-1.jpg
Old Dec 22, 2013 | 10:18 AM
houndawgbp's Avatar
houndawgbp
I'm roaming right now so the pictures won't load. If their out, rotate the housing counter clock wise, then the little "paper clip" that holds the bulb in, push down and slide toward you. The H3 bulb only has one wire hookup and it slides right out.
If your still lost i'll be home in a few hours so I'll walk you through it in a pm if you can't get it
Old Dec 22, 2013 | 10:52 AM
MyGS3's Avatar
MyGS3
I'm still lost. I'm looking at the replacement and there is a blue wire attached to the bulb. I'm looking at the fog light and I don't see a place to insert the wire in the light. I will post a picture of the replacement. Once you see the pictures, you will see where I am.
Old Dec 23, 2013 | 12:16 AM
houndawgbp's Avatar
houndawgbp
Just in case my PM didn't send. That big white wire is only a sheath. Slide it up and you'll see the connection. It just simply pulls apart. I didn't even re-use the wire sheath.
Old Dec 23, 2013 | 12:53 AM
Nixspeed's Avatar
Nixspeed
Yes those are 1 wire type so that 1 white wire comes apart right there about 4" down from the bulb base. Give it a tug and it'll come loose. Some of them are kinda sticky. Get some dielectric grease for the connection to help for next.
Old Dec 23, 2013 | 02:37 AM
houndawgbp's Avatar
houndawgbp
+1 on the electric grease
Old Dec 23, 2013 | 08:27 AM
MyGS3's Avatar
MyGS3
Thanks guys!
I will play around with it when I get home. I was tugging on it, but I'm fearful of breaking it. I will provide a status update later tonight.
Update: I was able to remove and install the fog lights . I appreciate the help!!
Old Dec 24, 2013 | 10:00 AM
Nixspeed's Avatar
Nixspeed
Glad you got it. There is usually someone on here that has done what you're trying to do before and probably ran into the same issues. Seems you got pretty quick advice too so that's good.
Old Dec 25, 2013 | 04:37 AM
houndawgbp's Avatar
houndawgbp
Your welcome man. Sometimes it's the simple things we need help with! Look at the questions I've asked! Lol if you don't ask you don't learn!
gcam77
GX - 1st Gen (2003-2009)
Jul 11, 2018 08:07 AM
billydpowe
Oct 11, 2010 01:40 PM
JayCaz
Feb 19, 2010 09:24 PM
kgh31386
Nov 27, 2005 11:32 AM
