View Full Version : Suspension and Brakes
- Whats the difference?
- R1 Concept Premium Rotor kit
- another brake upgrade question! :-(
- super noob suspension question
- cx racing coilovers looove them
- Rusted calibers
- Rear suspension banging
- 47 or 50 mm Steering Rack Mounting Bush Kit ?
- Supra rear sway bar endlinks question
- Lower control arms
- inner tie rod torque specs??
- Toyota Supra TT brakes
- Bilstein shocks with 93+ Toyota Supra Springs?
- normal variance in rotor weight and face thickness?
- ABS Codes
- LS400 Calipers and rotors ready for install
- Drilled & Slotted Performance Rotors
- Coilover Question
- what markings should OEM LS400 rotors have, if any?
- Grunchy sound when going over speed bumps when its cold
- most likely source of squishy sound from rear suspension?
- 1998 SC300 Lower Control Arms.
- NEED HELP BEFORE TOMORROW! Brakes/Rotors
- Help with lance alignment on a 300
- replacement rear sway end links?
- DIY Shock Revalve Series: BC Racing BR shock dismantle & Revalve w/ Bilstein parts
- What else should I replace while doing control arms?
- Replacing oem springs,shocks - do I need to replace top hats?
- Megan Racing Coilovers - EZ Street Series
- Suspension advice please
- Brake calipers moving while braking
- long tie rods for drifting
- Help with harsh ride on Supra TT Struts and Springs
- Front Suspension Front Tie Rod Questions
- New Frankenstein Rear BBK for all SC's
- Need An Answer On Pitch
- Front wheel skipping when reversing
- sc300/sc400 fender rolling
- Chase Bays Brake Booster Eliminator
- Possible Suspension problem?
- Energy Suspension Poly Bushing all around?
- post pics of SC's with TT shocks and Eibach springs
- Unnecessary Roughness
- So HNR Eibachs or tein s techs
- Adjustable control arm question:
- Will UAS bags fit over stance ss+ coils?
- Master Cylinder Upgrade
- Gixxer Drew Suspension Update 2014
- Warning! Aftermaket UCA Failure
- Oem CD changer not working 96sc300
- Active suspension help
- need to replace lower control arms.
- SC400 suspension. What would you do?
- Has anyone replaced their wheel bearings
- Where can I buy parking brake hardware kit???
- Best rotors and pads for an LS430
- New wheels, question about spacers?
- Strut Replacement Advice - 92 SC400
- Installing Rack Bushing Question
- 97 SC4 Changing Brake Lines Today
- Brake line and bleeding question 1999 Sc300
- Klunking Noise in Rear
- school me on control arms
- weird braking problem
- A little info for supra stock front sway bar here.
- Vibration when braking
- Brake problem ?
- Rear LCA bushings
- Modified rear lca now Bv toe rod is to long
- Popping, clicking noise from front end when I drop clutch at high RPM
- Where can I find brake caliper mounts?!?!
- Ran Into A Few Problems
- Suspension arm overhaul
- Are OEM Strut Mounts the only option I really have?
- How to make figs toe links OEM length
- SC430 rear 2-Pots?
- front lower control arm camber adjustment
- New brakes for my SC400 question on calipers
- Rear Lower Control Arm Differences
- Strut bushings
- Need 97 SC300 ABS ECU Pinout.
- Use factory brakes? Or another brand for 99 SC400?
- Looking for good replacement rear shocks for 99 Sc400
- coilovers that simulate stockish feel but go low?
- The definitive MKIV Supra SC300/400 suspension crossover thread
- SC400 rear calipers
- Need SS Brake Lines Installed on 97 SC400
- Sc300 front adjustable upper/lower control arms
- Bushings!!!
- Airstrut bags installed
- Odd brake issue
- Who has prothane (or R2) control arm bushings in their car?
- I'm going to torch my car
- How you know your power steering rack is bad
- 1997+ Supra Sub frame Mounts
- Sagging springs ??
- Replacing sheered Rear Camber Bolt SC400
- Help me decide which coils...
- How many guy are using poweredbymax coilovers?
- Problems getting a good alignment
- Where to buy supra tt brake pads
- Rear hubs the same?
- What Other suspension upgrades?
- Brake Problem (New Rear Pads)
- FYI MKIV supra rear superpro bushing kit != sc300 bushings
- How To Camber In Rear On 1997 SC300?
- Lowering my SC3; worried about exhaust. Pictures and video within.
- A little wheel show fun...in the blistering humidity
- Coilovers Which one?
- SuperPro Polyurethane Steering Rack Mounting Bush Kit 47 mm or 50 mm ?
- Show me your 9.5/10.5 +22/+22 wheels
- Confirmed (With Pics): Supra Lower Control Arms LCA's on Lexus SC-300
- Help! Long Distance Suspension Diagnosis
- Uh oh, I think it's a goner
- Post a Pic of your SC Dumped with Bags
- what's your entire brake set up?
- silverminemotors bbk
- Loud pop while driving but nothing appear to be wrong
- 1996 SC400 - Reasonable Expectations
- Clear BBK ?
- Brake shuddering please help
- How screwed am I? steering rack question.
- xyz sport suspension
- hand brake only one side working
- What is the BEST, CLEAREST DIY for Ls400 BBK installation?
- Steering wheel has play
- The uneven drop problem
- replacement daizen sway bar bushing
- Well here goes.....
- Rear brake hose line
- Using springs made for 1G GS on SC
- fuel filter line help
- Sway Bay End Link Questions
- bushings - urethane vs rubber?
- LS400 rear calipers HELP!
- BC Racing Coils BR type
- vibration at highway speeds
- Old style vs new style front LCAs
- Thinking of getting a Strut tower brace for my '98 ScC400
- Will SC400 rear rotors work with Supra TT rear calipers?
- OEM shocks/struts
- Torn tie rod boot--replace boot or entire rack?
- Will Prothane LCA bushings fit Supra LCA on a 95' SC400?
- "Click" sound from front end while turning wheel.
- Circuit racing suspension setup?
- anyone try these Coilovers?
- Need new inner tie rods..what else?
- Tie rod end boot clamp and DIY for TRE replacement?
- Can anyone name these coilovers?
- Resonator suggestions?
- Mechanic replaced steering rack bushings. One was left over. What did he miss?
- LS400 BBK Install Trouble
- unsettled rear end
- Head gasket question
- 1992 Aristo/Gs300 struts and shocks on a 1993 sc400?
- 1991 sc400 rear brake rotors
- When changing Rack Bushings, what else is logical to change ?
- Oh Lord, rotation noise.
- 1991 UZZ31 Rear Brake Rotors
- Basic Q. How do you tell SC shocks are bad?
- Do I need adjustable sway bar end links or just stock ones? Where should I buy them?
- Need help with Gixxer_drew suspension!
- Do xxr 526 18x9+35 clear ls400 BBK?
- Sway bars
- Stance coilovers...
- off set question for my ls brakes
- SC400 Suspesion Rebuild
- SS Brake lines
- Rear caliper upgrade
- More negative camber?
- Squealing brake pedal when pressed?
- Questions for People with Cut Knuckles..
- Ebrake removal and stuck caliper
- At what point does the stock suspension becomes a bottleneck?
- Compatible Supra OEM Rotors for SC300
- 95 SC400, front shocks replacement?
- 1997 SC300 Lower Control Arms. any input greatly appreciated!
- goodridge SS line question
- strut bars
- Rear Brake Pics
- Wanna swap my d2 8 pot to an sc300
- Burning smell from rear wheel well.
- difference in width tt vs ls400 vs n/a
- Free suspension
- Tips on removing rear suspension arms?
- diff bushing replacement?
- Kido Coilover on Lexus is Look Good and Have nice Support
- LS400 brakes are in!
- Sc300 "Intermed shaft"?
- LS400 brake upgrade, need longer studs
- 1997 front upper control arm clarification
- suspension
- Confirming bad bushings or LCA?
- Oh Yes! New Brakes!
- Coilovers for squatting
- Best rear brake caliper
- where to start
- Eau Rouge rear Suspension parts/ Help!
- So I installed front Supra TT Eibach-Pro springs on SC300 shocks...Espelir vs Eibach
- Brake pad recommendations
- new bilstein struts and TT springs, ride is incredibly rough
- Breaks on the floor to stop while backing up
- SC4 rear is low after TT springs
- My 93' SC400 - Rear Brakes
- Tokico Illumina Advanced Handling Kit for mk4 Supra
- New brakes?
- Need help and suggestions on rebuilding front end
- 94 SC300 rear suspension troubles
- Power Stop brake kit
- Bushings ?
- figs rear toe arm or battle version rear toe arm. which one would get?
- 96 sc300 roaring below 30mph
- Replacing worn sway bar bushings
- Brake Dont Stop The Car - Help Please
- Question on full suspension
- Fitting LS400 brakes to a SC400-Detailed how to do.
- My options for lowering my car, Help!
- 97 sc300 front lca Figs bushing install (SMALL WRITEUP)
- Difference in brakes?
- 1997 front upper control arms
- Need help again!
- Need help again!
- Still no new options or am I not looking good enough??? Ball joints
- Help, please!
- LS400 Brake upgrade SS hoses for SC400
- Airtekk BBK
- suspension done!
- sc300/400 Suspensions/Coilovers.. help
- Lexus SC300 brakes, need help please.
- help with my scary ride.
- 92 sc300 suspension question
- SC300 rear knuckle bushing out
- Ultra Racing Tower Bars (F/R)
- New Custom FSB for my 98SC430
- LCA's 1997 SC400 replace with supra LCA's?
- mono-ball stud for lca's?
- Rebuild calipers
- 97+ bushings on supra lca?
- Weird brake problem
- Rear subframe bushings - has anyone replaced? (pic)
- eibach sportline lowering springs
- please name part #13
- Will Supra front sway bar end links fit the SC?
- Sc400 Camber Kit
- 326 power coilover need review about them
- Tanabe NF210's on SC400
- Help with ls400 brake swap
- HKS pillow ball bushings blown!
- What's the stiffest spring rates people are running?
- Brake job
