Tips on removing rear suspension arms?
I've been trying to remove these with a pitman and other stuff to replace a wheel bearing. They seem really tight and pitman only fits one. Anyone who's done this, can you tell what you did to remove these?
Thanks for the help. I was definitely not expecting what happened when I got the first one. Huge bang. The damn things are tapered near the back - scared the **** out of me. Just 1 left, gotta grab a different size tool. Broke an adapter on the bottom-most one with the 19 nut and bolt. I think I had to put 80-90 lbs on a 25" cheater bar.
Got the last one out after several hours - no puller would fit. Is the metal cover behind where the brake rotor is...necessary? I pretty much bent the hell out of the bottom to get room.
most people remove them when they do the tt upgrade anyways
it sorta helps with preventing debris from tearing up rubber boots and all that
The two lines connected to the hub race. How do I remove them? ABS speed sensor line and ebrake line.
Edit: this is what I get for thinking that the image wasn't attaching
Might be easier to remove the cable from the tunnel. Need to loosen up the ebrake, there is a screw holding the tension on the cable under the leather boot. Once it is slacked off, under the car by the drive shaft you will see where it connects to both sides. You can pop the cables out at the junction.
This worked to free it up, though I had to take off the hub from the axle and hit it from the inside before it came out completely. Lots of rust and grime. Hub clearly wasn't sealed.
tsxnbp
06-19-15 04:25 PM
