View Full Version : Suspension and Brakes
Pages :
13
14
15]
16
17
18
19
20
- struts
- IS250 rear brake replacement (GREAT DIY with lots of PICS!)
- Are these normal in Power Slotted Rotors
- AWD bc racing coil...
- F-Sport Brakes vs. IS350 Brakes vs. Others
- What coilovers to get?
- springs
- is this normal on an AWD?
- f-sport springs and shocks...ride comfort?
- Megan Coils making sound?
- The Battle of the Chassis Braces!!
- How long do the brakes last?
- Change in Specs for Front F-Sport Sway Bar??
- Brake Pad Wear - Front to Rear difference
- Rotor replacement...
- HELP! with discounttires code?
- F- Sport Springs Review/Opinion
- After installing BC coilovers I am having vibrations
- BC Racing Coilovers woohooo.
- F-Sport Sways w/ Stock Springs & Shocks or ...
- F-Sport Springs Noob Question
- GTSpec rear 2 point brace
- Just installed my F-sport Brakes!!!
- Big Brake Kit (BBK) Installation
- centric brake pads, anything good?
- IS 250 AWD vs IS 250 Brakes
- Power Steering Failure
- "powerslot" rotors, are they good rotors?
- F-Sport Sways same as Hotchkis?
- 2009 IS250 AWD and 2009 IS350 RWD sway bar same?
- F-Sport Spring Install....HELP!!!
- Help- retrofit brakes
- Is my dealer telling the truth?
- Harsher ride after brake pads and rotors surfacing
- Tein CS Drop height
- is350 f-sport shocks/springs compatible with is250?
- improve the handling?
- Brake dust on the front wheels?
- H&R vs. Eibach Springs - Comparative Review
- F-Sport Springs and Tein Silencers
- Can F-Springs be installed at local shop (?)
- Rusted Brake Roters
- Polishing the 350 Calipers?
- What Springs Should I use for my IS 250 AWD?
- Suspension Upgrade
- Which Lowering Springs?
- Spring vs. Rear Sway Bar
- IS350 Front Sway on IS250 RWD
- brake pad question
- Which tools to install rear sway bar ?
- Hydro-pneumatic suspension progress
- Tanabe SUSTEC PRO FIVE Owners
- brake pad?
- where can i buy brake spray?
- life expectancy of stock shocks
- OEM brakes pads or Low brake dust
- Soft-metal rotors? Have you ever heard of this?
- F Sport sway bar
- Going from Tein CST to Megan LP Should I?
- Has anyone had brake pad fail due to dust build up?
- Ksport coilovers or Tein Coilovers?
- BCR Coilovers for IS AWD setting thread
- Possible to swap Lux package suspension w/ Sport?
- pic/info request: BBK bracket
- brake help?
- F-Sport Springs on IS350?
- Need Help ASAP!
- Anyone else unhappy with ride quality on their EIBACH Pro-Kit ?
- f sport springs question
- How much did you guys get your IS350 brakes pads for?
- install or not
- BC racing, Tein CS, Megan, or Tanabe coilovers???
- Stiffest Lowering Springs?
- ★★★★★ Official BBK Thread ★★★★★
- F-Sport BBK with 18" wheels
- Project Kics Spacer
- Street Brake Pad
- H&R Drop pics inside :)
- LEXUS sticker/decal for 350 caliper
- F-Sport Springs in snow
- Brake Rotor and Brake Pads is it under warranty?
- F-sport shocks and Eibech springs?
- Coilover spec help
- what color brakes should i paint?
- technical suspension question
- F-Sport BBK Brake Pads Tips?
- Queston: DIY coilover or lowering spring Install
- DIY Lower your AWD IS250
- NEED HELP! Spring install, IS250RWD
- 09 AWD shocks
- Got excited, so I took pics...
- BC racing spec VS Tein CS
- New to coilover, Megan coilover own please help.
- Caliper paint Recomendations
- Shocks: F-Sport vs. Tokico
- Best Spring Drop??
- H&R Springs + F-Sport Sways?
- ppl w/ HKS Hipermax III CLX, pls chime in
- Please help...others who have lowered! Less HID coverage at night
- Coilover+Air Suspension=Ksport worth it?
- HELP!! Got springs installed and leaning really bad..getting rubbing!
- Decided: H&R Springs! Question about install
- new to coilovers!
- D2 coilovers VS. megan coilovers
- 250 to 350 brake upgrade
- Please analyze my alignment results
- Looking to drop my IS350...please help
- Just ordered coilovers!!
- Used coilovers?
- IS250 AWD - are Eibach springs okay for it?
- eibach is350 tire wear!
- What do you guys think are the best coilovers?
- Question about rotors
- Eibachs on IS350 - your opinion
- Question on sway bars
- Springs VS Coilovers VS Air Suspension
- F-sport shocks and oem springs combo?
- Need Springs
- I am torn between the S tech or H&R springs.. HELP!
- TSIB Front Brake
- i need a drop... what springs should i get??
- Weird noise after install springs (not clunk)
- OEM is250 rwd springs on is250 awd????
- Front Strut Question
- Just installed megan springs
- Is250 to IS350 rear brake conversion questions
- Brake dust!!!!
- Need new brakes and rotors
- Installed F-Sport sway bars (F&R)!!! Ride seems little stiffer
- Air during brake bleed...
- IS350 Sways
- Have you lowered your IS with the Eibach Pro Kit?? If so...HELP
- rear sway install
- Which Coils to use!!
- Coilover questions
- Brakes Rotors
- Pic request - might be asking a lot but...
- Front Breaks Squeaking, IS 350 Question>?
- IS 250 AWD springs?? Need HELP!!
- Buddy club coilovers project 2IS final review!!!
- Tein SS probs..
- F-Sport Springs - Left rear lower than Right rear?
- spring rate
- Get F Sport shocks+springs, or just springs on OEM lux pack shocks
- Review: BC Coilovers for IS250 AWD
- Fixed my F-Sport/Eibach Clunk! It was the JACK!!!!!
- Tein Super Street Coilover - Camber Problems
- D2 coilover or H&R coilover?
- Quite a big problem with my IS350 Brakes
- Need Rear Brake Pads..which is best?
- tsb brake question is250 2006
- Spacers and camber???
- How long should I wait for my springs to settle before alignment?
- Brake pad tsib....too late?!?
- Coilover & wheel/tire questions
- IS-F rear sway take-off installed! mini-review.
- new spring and shock combo
- IS350 calipers cheaper than IS250 calipers?
- F-Sports parts any good?
- IS350 front brake
- fsport springs drop on awd...make sense?
- IS350 brakes ...
- Just lowered my 250AWD Pics. Prokit springs
- f-sport sway?
- BC racing BR coilovers
- Coils Help
- Help! Tein Rubber Silencer Questions
- Anyone try S-Tech springs with F-Sport Shocks?
- Sway bars? Do I need both?
- camber uneven
- Spare Tire for BBK
- Need Help Sway Bar Install
- Aftermarket Shocks
- considering lowering car...affects on HIDs and AFS
- Project 2IS------BUDDY CLUB!
- IS350 front brakes on IS250 AWD??
- Tein S springs.
- Stech springs w/spacers issue
- is250 AWD springs
- Labor costs for lowering spring installation?
- After 2.5 years, no more clunking!!!
- Pic Request!! Tein H tech spring
- Accessing bumpstops easily ?
- F-Sport spring and struts - Who has them? Who likes them?
- Lowering a 2009 IS 350 with GS 350 Springs
- Crooked camber
- drop?
- Coil overs..... need some help
- F sport Sway bar!!!
- What do you guys think (about spacers)?
- BC Racing Coil IS250AWD Dropped
- Driveshaft Working Angle
- Tein S Springs
- Questions about New F-Sport Front/Rear Sway bar for AWD
- Pic Request: Eibach ProKit 250 & Tein S-Tech spring drops!
- Dissapointed with my drop (F-Sport)... What springs should I get? (pics included)
- Spacers before or after alignment?
- spring question!!
- Brake Bleeding Sequence/Brake Fluid
- F-Sport Spring/Shock Install Problem
- Megan Coilover Owners
- NOOOB question
- Lowering-retaining good ride
- Bad wheel bearing? Lexus techs please chime in.
- REVIEW: JUN-TW Rear Sway Bar
- Wheel Alignment and Camber Adjustment
- Need To replace my rotors....
- IS 250 AWD Road Magnets?
- AWD need new Rotors/Pads! help :)
- Carbotech
- After lowering Is350.
- 350 OEM BBK on AWD w/ OEM 17"
- Some questions for spring & shock.
- What springs drop evenly/ from 1" to 1.5"
- What tires on 2IS lowered?
- Tanabe Springs?
- New TSIB break make more noise???
- BBK Kits for upgrade
- Coilover's Owner
- Brembo Brakes
- eibach 250 springs on 350 clunk?
- swaybar questions
- 250 RWD - Adding 19s & Vertex full kit...best choice of springs? Tein S-Tech?
- ISF Swaybars - Parts + Labour
- Camber wear...solutions?
- DIY: IS250 front brakes
- SS Brake Lines
- TeinS springs
- best brakes
- JUN TW sway bar on an IS300
- Eibach or coilover?
- Go lower or not go lower?
- F-Sport Sway bar & Under Chassis Brace
- Hotchkis vs. F-Sports with 18's?
- Has anybody tried these sway bars?
- Tanabe Pro 5 coils or Zeal xs??
- brake pads...
- F-sport Sway Bar Intall on an 09 is250! Just a bit Different
- Average rate for spring installation.
- **eibach sportline**
- Fsport springs on 18" OEM wheels pics request
- OEM Brake Pad VS EBC Brake Pad
- F-sport Shocks vs. Zeal or KW
- Few ? about F-Sport Springs
- IS350 Strutbars?
- F-Sport springs!
- Brake upgrade ideas at good prices?
- New Tanabe coilovers coming. Owner input please
- IS350 (brake) Upgrade on IS250
- Sport Package Springs
