Caliper paint Recomendations
Old May 15, 2009 | 03:53 PM
acefalcon2's Avatar
acefalcon2
Default Caliper paint Recomendations
Anyone has reccomendations on caliper paint.... i've tried to paint mine and... it loooks... awful... because some of the brush actually got stuck in the paint.. and yeah... at the end of day.. the whole brush came off... sshould i actually strip the paint and then repaint using another brush or what?
Old May 15, 2009 | 04:04 PM
radicalrev's Avatar
radicalrev
Definitely strip the paint to get rid of the brush that got stuck....and buy a better quality brush at an Art Store.
Old May 15, 2009 | 04:05 PM
dangy's Avatar
dangy
Maybe I mis-understood but you used a brush? Use a spray can.
Old May 15, 2009 | 04:06 PM
acefalcon2's Avatar
acefalcon2
most people say that the brush ones are better... rather than the spray! which spray to use?
Old May 15, 2009 | 04:08 PM
Coconut's Avatar
Coconut
G2 would be the best DIY caliper paint kit. The paint is actually epoxy, which is very durable and the color won't fade. The kit comes with a brush and but you can spray it on as well. The paint will "self level" after the second coat.
I would recommend sanding off the old paint. You don't need to sand all of it of, just enough to take away the shine and rough up the surface.
Old May 15, 2009 | 04:10 PM
acefalcon2's Avatar
acefalcon2
i think i might strip the paint...
Old May 15, 2009 | 04:13 PM
acefalcon2's Avatar
acefalcon2
do anyone clear coat after the Decal?
Old May 15, 2009 | 05:26 PM
L-S-D's Avatar
L-S-D
yes u should clear coat after
Old May 15, 2009 | 05:36 PM
passnu2's Avatar
passnu2
I have never put clear coat and IMO the brush on is better. The brush that comes with those kits "sucks" so get a good 1" or 1.5" brush. Dont be cheap and it will look good. The brush on kits will last much longer then the paint on and you dont need to put clear coat over it
Old May 15, 2009 | 05:38 PM
acefalcon2's Avatar
acefalcon2
so i use the 150 grit and paint striper to strip the paint... then get an extra brush from other place... to paint them eh?
Old May 15, 2009 | 05:41 PM
YooNiBaLL's Avatar
YooNiBaLL
yeah, do that pasnnu2 said. it works well. what color you painting it?
Old May 15, 2009 | 11:39 PM
stbest85's Avatar
stbest85
After watching a buddy do his with brush i decided to do mine with Spray. After putting a clear coat i thought it looked as glossy. Overall it was easier and looked smoother than a a brush. You can buy the Dupli-color spray can of any color along with a high temp gloss at any auto zone store. Just remember to prep right. I used 3 cans of brake cleaner, a steel brush then finished with the grade 3 steel wool. if you are putting on decals especially on a 350 calipers just make sure the front calipers smooth face is cleaned (steel wooled), several light coats of paint and clear coar and enough time to dry. Good luck.
Old May 16, 2009 | 12:55 AM
rs/ss's Avatar
rs/ss
Brushed on paint is self leveling and IMO more durable. I suggest a clear coat over decals. Great easy mod.
Old May 16, 2009 | 06:38 AM
acefalcon2's Avatar
acefalcon2
is a 150 grit paper enough??? i am going to clean it up today and then maybe buy the dupli-color one... but i think G2 is better.... and maybe get it done next week... install it as well
Old May 16, 2009 | 07:39 AM
Shoganai's Avatar
Shoganai
If you already got the paint just get a better brush
