View Full Version : Suspension and Brakes
Pages :
13
14]
15
16
17
18
19
20
- Tein suspension
- Brake fluid - Recommended brand?
- Max Camber Adjustment?
- Calling all IS AWD owners!
- Stock Spring Rates for is 350?
- Front Camber Kit For ISX50
- springs or coilovers?
- GS300 brakes on a IS250C
- Question on Hawk Pads for '10 IS350
- Going to do the TSIB for the F-Sports Springs
- has anyone got this?? (THIS = JUN TW IS250/350 Front Upper Strut Brace)
- New Rotors (help)
- Softest coilovers
- Difference between 250 and 350 springs?
- help adjusting coilovers
- HELP! suspension clunking
- F-Sport Springs
- F-Sport Suspension or Coils?
- Just Replaced Brakes and Rotors...Might need to change again..
- Is250 awd cv boot leakin!
- Whats lower? F-sport springs or pro-kit?
- Swaybars
- installing springs
- Question! (suspension mods)
- Need help deciding on springs
- sway bar and f-sport springs installation
- Eibach pro kit VS. H&R
- F-Sport Brake Pads
- After Lowering Question
- Need Advice on Lowering my IS350 - Springs vs. Coilovers
- IS250/350 rear brakes
- Will this work for coilovers?????
- brakes need replacement?
- F-Sport Springs - Was great, now just ok
- Coilovers or Rims?..Opinions Please
- Removing front F-Sport Sway Bar and Ride Quality
- Finally installed my Tein S-tec's after buying them 2 years ago
- Brakes /pads for IS 250 / 350
- Any way to get F-Sport Brakes to clear stock 18's?
- Anyone else have rusty brake calipers??
- Tein spring silencers
- F sport springs
- Some help please with Eibach Springs
- Turning/resurfacing vs replacing rotors
- Akebono ProACT Vs Stock Brake Pads
- swaybar endlink question
- IS250 caliper - bolt hole spacing.
- Lexus "package" price
- Quick question on BBK
- Installed my BC Coilovers on my AWD
- IS250 Rotor Size?
- Tein S-Tech springs or H&R springs for 08 IS250 AWD
- fsport rear sway vs jun-tw front strut brace
- car is getting lower with time?
- hub-rings - are they necessary?
- TOM'S rear control arms + strut bar
- Koni Yellows
- Megan Racing Springs
- megan coilovers?!?
- Lowering the IS250AWD
- Lexus stepped up!
- Something Bent? Maybe
- Tein SS Kit
- F-Sport vs. Hotchkis sway bar
- Tape wrap for rear springs
- Noise in suspension!
- 275/35-18 tire fit the stock 18x8.5 rim???
- help....sway bar
- Eibach Pro Kit?
- New brakes no good!
- IS250 AWD Air Suspension system??
- lowering springs prefered?
- 2010 18" stock wheels and stoptech bbk
- Installing megan LP coils tmr ( help with settings pls )
- Difference in FSport Brakes for 250 and 350?
- High pitch brake squeal
- Shocks dead do I replace Eibach Springs too?
- CEL After Lowered?
- brake pad replacement options?
- Brake Rotors "Non-Servicable"?
- IS250 RWD + 20's +Fsport Springs??
- Is there any long term damage on coilovers if I leave it on the lowest setting?
- confirm
- F-Sport shocks and springs on AWD?
- My BC Racing coilovers are very noisy!
- F-Sport or Tein S-tech Springs?
- how do i know when my shock is blown
- IS350 recommended brakes and rotors
- brakes and rotor recommendations
- H&R Sport + F-Sport Shocks
- Front Camber Kit for IS350??
- KW Variant 3
- F Sport Shocks Will Raise Your Car Again? Or Do They Settle?
- DIY Parking Brake Adustment on an IS350?
- F-Sport Rear Sway install-Lube the rubber Bushings or not?
- Tein CST coilover clunking noise. Anyone have any ideas or clues
- Question about Megan coilover Dampening
- Recommended Rotors & Pads for IS350?
- Some Low for the Lex
- Yonaka Coilovers Tested - PASS!!
- Awd suspension
- Suggestions needed... (looking to get a set of cross drilled and slotted rotors)
- coilovers vs lowering springs
- tein s tech owners.
- Purple Erkel BBK
- NEW TSB: Noise with F-sport Springs!! Released 10-14-09
- H&R Spring Owners, chime in...
- installed Tein H tech..
- Are coilovers worth it?
- DEALER quotes RE: brakes.. WOW!
- Question about IS250 front calipers
- IS 350 F-Sport Sway Bar Ride Comfort
- OEM rotor weight
- So what kind lof lowering springs should i get for my IS350??
- how low can i go?
- OEM springs or shocks?? giving out already?
- Squeeking brakes? Look in here...!
- brakes screeching
- IS350 Brakes making noise
- Debate: Stance LX+, Stance GR+, Megan LP, JIC Coilovers
- Very loud creaking in suspension
- Stance LX+ coilover install and review IS 250
- Goodbye springs, Hello Coils!
- alignment specs
- cars with air?
- F sport Rear Sway Bar
- Coilover question
- Coilovers: Aluminum casing vs Steel casing
- Anything else besides F-Sport sways?
- AWD on Springs?
- Front Camber Adjustment
- QUESTION : TANABE or MEGAN COILS ??
- Post Pictures and Reviews of your aftermarket Drilled Rotors with OEM calipers
- question about springs.
- tanabe coils making a squeaking like sound
- Stoptech slotted rotors!!!
- Weird problem...HELP!!
- HELP!! want to lower my car...which brand
- 2007 IS250 RWD Sqeeky Upper Control Arm
- Change Brake Fluid
- Tanabe TEAS
- Uneven drop on Eibach springs!
- Spring rates for the Advox and Advox Sports??
- How necessary is it to rebuild coilovers every year??
- IS350 Brake kit?
- HKS coilovers
- need more help with F-Spring clunking issues...
- picture request for springs
- Which coilovers if on a budget?
- Just got F-Sport Springs and Sway Bars! Can I do the install?
- fsport springs
- Tein S Tech question??please help
- Coilovers for IS250/350 fit on IS300 (asia/dubai version)-NEED HELP
- D2 Brakes.
- F-Sport Springs vs Tein High Tech.
- Brakes replacement/upgrade options?
- a stup!d girl question... (suspension squeaks)
- Front brake noise TSIB for '08s?
- Question: Stoptech or Rotora
- Helping a friend with spring and that lucky bastard...
- Getting F-Sport Suspension Installed Tomorrow!
- lexus calipers?
- Interior strut tower?
- TEIN Mono Flex coils
- stock ride height and FS suspension ID questions
- several spring and sleeve questions
- Brakes gone @ 23k?
- tanabe sustec pro5 coilovers
- Here's a question (coilovers vs. springs)
- IS250 Front/rear Brake Caliper Bolt torque ratings?
- H&R Rubs!
- clunking on eibach 350's?
- Nervous as hell... (installing F sport springs tomorrow)
- Part number for OEM front rotors (250 awd)
- Quick question to IS350 owners about your brakes
- BC Racing Coilover Review
- BC coilover review and install.
- F-Sport and 19's !!!!
- Supra MK IV Brake compatibility?
- Anyone slammed on D2 coils?
- Colored Brake pads?
- Any Recommendations for springs?
- Installing F-Sport Springs ?
- F-Sport suspension and ridiculous camber and tire wear
- Tein SS ride quality
- switching from 18" to 16" for the winter
- F-Sport Spring and Silencer ?s
- Brake Dust is KILLIN me!
- will these BBK fit on a ISx50?
- Tips on adjusting HKS coilovers
- #2IS Caliper Painting (merged threads)
- fsport springs bad ride
- Removing IS350 Font Calipers
- help identify brake part number
- F-Sport Springs vs X-Package
- resurfacing rotors necessary?
- What springs do you recommend?
- rubber silencers?
- Brake rotors for IS-350 (2006)
- Coilover install on Wednesday - help me set up my drop height!
- VSC light came on with lowered height?
- F-sports clunking only in right rear?
- Tokico D-Spec for ISX50! Finally Out?
- Looking for F-sport Sways
- Rear brakes / parking brake is causing me to fail my state inspection
- How will you know "BBK" will fit the aftermarket wheel?
- Replace rear shocks after 62,000 miles???
- Brake Fluid Exchange
- Whats the distance between YOUR fender lip & rim? (!the smaller the better!)
- Talk to me about Coilover Spring Rates!
- anyone has a problem with the HID adjust lower after install F-sway?
- Cheapest place to buy Eibach Pro-Kit?
- springs and shocks???
- How much should dealer charge for new brakes?
- Best Brake Pads for front & rear
- F-Sport Springs - Got Them - Here's My Opinion
- Second thoughts on lowering, might bring it back up.
- best comfortable coilovers
- IS350 OEM wheel stud length?
- 2005 Camry Solara wheels and 2009 IS250
- Spring Choice Help!!
- F-Sport Sway bar problem!!!
- IS350 brakes = ISf brakes?
- Suspension Torque Specs - Bushing Reset Info **LOOK HERE FIRST**
- Brake noise won't go away
- I just got denied for the 08 Dust-Free brake pad TSIB
- 250 AWD vs RWD ride height
- benefits of having the F-sport Sway Bars... let me know
- H&R Springs + Ichiba Version 2 Spacers on 17" OEM wheels
- Brake upgrade for 2006 is 250 awd
- Softer brake pedal after brake fluid change!!!
- F-Sport Springs and Tein Silencers
- Brake Pads and Rotor Pricing!?
- Did this shop try to sell me an alignment I don't need?
- Pic Request, IS 350 F Sport Springs H&R Springs
- 2009 Suspension Difference?
- Tein S-Tech Springs Question
- F-Sport Bilsteins - Still Not Sure - Owners?
- Anyone run stock brakes with slotted/drilled rotors?
- F-Sport Sway Bars - Got Them - Here's My Opinion
- KW coilovers for our x50's??
- Stabilizer Links
- front camber plate/kit
- Vibrations from BC coilovers for AWD.
- Tein Silencers
- Megan vs. BC Racing Coilovers ?
- I hear my shocks making pfffft noise, normal?
- which coil overs
- will 20x10 40 offset and 20x8.5 25 offset work on my is?
