Curious if these rear upper control camber arms will work on my SC?
I know the chassis on the SC and the Supra are identical....I'm curious if these arms will work my SC rear?
http://www.ebay.com/itm/93-97-TOYOTA...ht_3484wt_1392
Need more camber adjustment and there's nothing specifically for the SC available unless you dump money on the Ikeya's so..This is what I ended up with. Just need someone to approve it and confirm that it will line up and work before I purchase.
Thanks y'all!
Thanks y'all!
cut and re-weld whaa?!?!?! I had no trouble putting these on my SC? I havnt adjusted them or put the coilovers in yet but they fit like stock?!?! I Actually have the fronts and rear from TC sportline dot com??!?!
CLICK HERE
AND HERE, THIS FELLOW ALSO USED THESE (scroll to the bottom)
CLICK HERE
CLICK HERE
CLICK HERE
Oh no, I perfectly know what you mean by those bushings. I had replaced every single bushing on mine including the engine and tranny mount hoping to get rid of this loud clunking sound when I shift to R or D at cold starts, and even at warm start when the car is at an angle, then it got worst when I lowered my SC, I would even hear the clunk when I'm driving whenever I'd let go of gas, and nothing solved it until I recently replaced my rear upper control arm bushings with polyurethanes... After seeing the OEM bushings out, that's when I realized how stupid of a design it was, and stupid me also cause the rear upper control arm bushings were the last thing I did due to it being very hard to deal with lacking tools... I had to do it at the military base's hobby shop for a complete access to tools...
