- need some help out here guys.
- Replacing SC A/C evaporator, expansion valve and heater core - Am I missing anything?
- Key & Tumble / Ignition Switch Same as Supra?
- Random AC Light flashing sometimes....?
- Why does our EFI relay get hot?
- Sc400 poor idle
- ECU & Transmission issues
- Weird starter issues
- Manifold question.
- 1JZ Starts, Idles, and Dies
- swap questions
- SC Transmission Pan
- O/D light flashing, Code 42, No 4th gear
- highest hp na 2jz
- Car died after 30 miles on a full tank
- proportioning valve location
- Setting TDC with the DM crank pulley
- Sc400 starter replacement issue CEL&overheating solved
- Ignition Timing on SC400
- My '94 baby
- DIY Aftermarket Fuel Rail Installation on 1JZ w/ Pics
- Rubber Exhaust Hangers
- sc300 1jz vvti swap tach not working
- Having issues with USDM OBDII TT ECU mod
- SC400 VVTi Intake airbox & intake pipe
- 95 Sc300 radiator bubbling issues
- Need advice on adjusting clutch
- Just got my DM SC300 5 speed pedal package...any assembly guides?
- Must sway bar end links be a matched pair?
- power steering
- Headlight Cleaning and Defogging DIY
- '94 SC400 TPS part #?
- manifold remove
- Replacing shims for aftermarket cams
- US spec engine with JDM Mines ecu ??
- Driveshaft center support bearing bolt spacers
- radiator fluid leaking. need to replace a pipe
- What kind of power are you making?
- Eaton Detroit locker??
- Throttle body relocation on 2JZ-GE
- plummeting mpg
- 95 SC400 stuck in park, no power windows, roof, or steering Please Help
- Oxygen sensor questions
- Ordering some 5 speed conversion parts, missing anything?
- sc300 wont start anymore!
- Fuel pump differences?
- helpp (SWAP)
- I am so bummed. Tranny frustrations.
- will this injector work?
- Ignition switch ques.
- HELP!!!! My car fins fine untill put in drive or reverse!!!!
- Preferred Turbo kit?
- 1JZ SC300 swap finally done needs tweaking! Help?
- Issues after 5spd swap
- 1UZ spark plug torque?
- Grounding problem SC300 '92
- SC400 new fuel pump, ECU bypass, stranded again
- Cracked manifold worth fixing?
- what would you call this clip?
- are all transmission mounts created equal?
- 1992 sc300 with 95 bumper and fogs
- Stumped on clutch/trans issue on 2jz/r154
- Rear drive shaft
- 92 nat bogging issues
- SC400 Transmission Dipstick - Do I have the Wrong One?
- 1jz harness missing alternator plug and wires??? help asap!
- Supra or Aristo trans in my SC300?
- SC300 1JZ Starter Problem
- Thermostat question
- Help with AC compressor and clutch.
- Boost leak/ Turbo failure?
- Removing resonators on Sc300? Effective for sound as on 400?
- 99 sc300 aristo swap driveshaft help needed
- Which standalone is for me?
- Civic AEM V2
- ECU questions
- 17mm Bolt Above Thermostat Inner Threads Stripped Help!!!
- 1jz
- sc300 with 350z straight pipes
- Anything wrong with this R154?
- Help with 2 things. Starting issue/timing belt & water pump questions
- Serpentine Belt Question
- A.C. parts replaced after compressor failed but still not fully cold
- Code 14 fixes? i need help!
- overheating issue
- jzx100 (chaser) into 93 sc300
- SC400 Trouble
- Cluster problem
- A/C refrigerant level
- where is the DIY for fuel pump relacement
- Shaky, loss of power up hill.
- IS300 Fans - How to wire them
- Mechanical trouble already???
- 97 SC4 Engine Idle/Whining Issue Update
- 2JZ Dimensions?
- Just dropped in a gte
- Question on GS400 3.26 rear diff in a gte swapped auto SC...
- SC400 no power, burning, rough idle
- 97' SC400 Whining/Whirring from under Hood
- Ac compressor question about 2jzgte/1uzfe compatibility.
- 1jzgte vvti (JZS171) ECU PINOUT
- SC570 (LS1 SC300) cammed idle.
- 1997 Sc400 Ecu Pinout
- Am I forgetting any maintenance items?
- Anyone used Driftmotion's 1JZ aftermarket timing parts?
- Map ecu 3
- R154 Clutch slipping?
- Help with Power Steering Pump
- 1jz harness has extra body plugs?
- 1999 sc300 tune up
- titan motorsports cams vs gsc cams?
- how do you get door moldings off
- help me with 2 things lol
- 1jz with 2jz-ge auto tranny?
- How to: Fix your door opener actuator rod lower end
- '93 sc300 transmission fluid
- Removed rear differential, I think it is making noise, is this normal?
- 97 fogs on a 93 sc
- 2JZGE NOS Direct Port Nitrous setup coming soon! Any input?
- SC400 Max Fuel Pressure (help please!)
- SC300 Coolant Reservoir Cap
- Sputtering & stalling issue... won't stay running!!!
- Heater control valve
- where to buy 1jz torque converter?
- SC400 Transmission Whine in 1st Gear (A340e)
- Differential Fluid Change and Trans Fluid Change at the Dealer
- Defeating/Bypassing the Coolant Level Sensor?
- Code 52 Knock Sensor on 92 SC400
- 1JZ custom patch harness, or just splice/solder?
- need lsd diff installed
- Drag Tire Recommendations
- AEM EMS v2 Timing Problem NA-t
- LS430 Diff?
- Alarm reset not working
- SC400 P/S Buzz question
- O2 sensor resistance (cold)
- Electric Radiator Fan Install simplified?
- Tranny Swap
- Is this an R154?
- Found a few promising turbo engines, help me pick one
- 1.5jzge just need a little info
- possible blown head gasket not entirely sure
- 1jz people I need help!
- Isis fuel pump
- Gas Tank Pressure needed?!?
- Need help, Electronics not working!
- Lean @ Idle, Trac light
- 1JZGTE Tach Fix 92-94 & 95-96
- Complete Diff bushing kits now available. Multi-piece design for the SC
- car missing need help please....
- Car shuts off when i turn off the A/C
- 92 SC300 Pouring white smoke
- what radiator do i have?
- 1jz wont fire aem gurus needed
- So hot in PHX... Need A/C Help!
- 1JZGTE VVTI IN SC300 wiring question
- Help, about to pay $355 for Vapor Canister!
- 1jz auto help
- sc300 2jzgte help, grounded alt.
- smoking and stalling
- SC4 cooling fan behavior
- AC Pro kit works! Definitely worth $$ IMO
- how to troubleshoot heater control valve?
- driveline vibration after 5-spd swap help me diagnose
- Na-t or ls/t56 swap?
- Help sc400 overheating with a/c ON
- from 810 to 560 in one night. bad idle
- Sc400 intake measurements please
- Help my 1jz auto dies!
- DIY LS1 Motor Mounts, LS1/T56 Swap
- Anyone tried Duralast VC120 Vapor Canister?
- catalytic converter
- 2JZGE Bottom Mount Turbo Manifolds?
- Idles at 0-100 rpm but No stalling. Help
- Electrical issue
- timing belt slipped
- 1JZ swap start up on AEM V2
- I need to rescue my SC - I turn the key to ON, and nothing works.
- Greedy Blue/ Ultimate ECU Reviews?
- '93 w58 swap into '92 auto
- problems in my sc 300
- SC 300/400 gte swap AEM Ecu question.....
- Starting issue/funky idle....
- at 45 mph car quits running, would not start
- r154
- is the 12v fuel mod good
- Where in 2014 can you find the 1UZ-FE Knock Sensor Sub-Harness?
- CX Racing Turbo kits chime in
- What harness is this? 98 SC400
- Fuel pump upgrades, mount corrosion
- Brown liquid from intake?
- 98 SC400 Knock Sensor HELP
- Fuel Problem Help Please!!
- Common 1jz problems?
- EGR: to delete or not to delete?
- Interest in SC400 Vortech supercharger write up
- o2 idea for 1jz
- 92 300 misfire question
- Transparent Timing Belt Cover for 2JZ
- Accessories on 2jzgte swap
- 95 SC300 Battery not charging, but batt and alt check out
- 2jz vvti in to a 93 sc300
- 2jzgte, need vsv help!!!
- Surging idle in park or neutral
- Alternator Replacement write up/w Pic's
- is this the TRAC i pulled out?
- injector #1
- SC400 1JZ running hot
- 1uz wasted spark coil on plug conversion
- Sc400 Rear Cam Cap Replacement
- miss fire
- 1uzfe power steering question.
- Need timing belt advise from forum
- 97 side
- What would you do? Swap an engine into a 300 or manual tranny into 400?
- MAF sensor outside of resistance specs?
- Engine/Tranny Swap
- Engine quits no electrical power
- 1992 Lexus SC400 smoke coming into cab??
- Anyone ever thought of using a p28 honda Ecu for 1uzfe?
- TECHNICAL sc400 5speed conv. questions
- Please Help, only car
- Need Help: 2JZ-GE NA-T w/ 7M CPS, TT coilpacks, AEM V2 (for GTE)
- Tampa Bay SC400 needs help - have an hour of time?
- Transmission starts in 2nd gear problem
- engine rotation direction?
- 1JZ Soarer and MKIV TT PS reservoirs the same?
- Help! Transmission noise?
- Any ideas for an exhaust?
- Engine revs when it’s hot.
- putting on 97 sides
- People who have TT Auto trannys, post your knowledge here
- Should I rebuild this free 2JZGE?
- All 1jz Holset hx35 experienced please chime in
- Weird Idle/Bucking/Stalling Issues
- Misfire symptoms, no CEL. OBD1 2JZGE
- NA-t head gasket option?
- Vortech Supercharger wastegate idea
- Need Help with 5ps swap on 98 sc400
- radiator options?
- over heating
- O/D light flashing on 93 SC300
- clutch recommendation?
- sc300 2jzgte swap
- Mishimoto Aluminum Radiator
- Car Not Starting Up
- more power
- Whos done a 5sp swap on 98 sc400 vvti
