will this injector work?
as the title states, anyone have experience with rc injectors? will this one work with my car ( 95sc300 na-t) I know its a low impedance injector so a resistor will have to be wired in. but they came with my car and the previous owner said they were removed because of a bad o-ring and he put the stock injectors back in. seems kind of fishy as I figured O-rings would be cheap to replace. but as far as I can tell there were no resistors wired in with the stock ge ecu. also what O-rings would be used? order a set from RC? any help is appreciated. here is a pic:
and here is a link to the website:
http://www.rceng.com/Peak-Hold-Injec...550-P15C5.aspx
Yes they will work just measure them to be sure, and you need a resistor box. The stock injector o-rings may fit, but test them first. If not then contact RC. But atleast they are 550cc's, so they are a good size for na-t to hold you over for a while.
Personally, I would sell them and just get a set of drop in high impedance injectors and skip the extra wiring.
