Alignment After Eibach Install
Old Sep 4, 2006 | 09:12 AM
Flipsonic's Avatar
Flipsonic
Default Alignment After Eibach Install
Since camber is not adjustable, is it necessary to wait a couple of weeks for the springs to settle and adjust toe?
Old Sep 4, 2006 | 09:34 AM
IS_250's Avatar
IS_250
it would be just best to wait a couple weeks for them to settle. unless your toe is drastically off, which i bet it isnt.. it wont hurt to wait a week or two.
Old Sep 4, 2006 | 09:35 AM
omgitsroy's Avatar
omgitsroy
from an engineering standpoint.. shouldn't springs not settle? good springs shouldn't settle becuase they would be in the plastic portion of the youngs modulus
Old Sep 4, 2006 | 10:34 AM
menech's Avatar
menech
actually springs fall into Hooke's law since they are linear materials...e.g. steel
Old Sep 4, 2006 | 10:46 AM
FunGuy's Avatar
FunGuy
THere are two types of springs, Progressive and set.
Old Sep 4, 2006 | 10:58 AM
menech's Avatar
menech
ahh, just checked the eibach page - seems they use progressive and not linear springs...so I don't think my comment applies anymore
so no idea on the engineering, but from having them on my car I know they did settle after about a week or two and were lower than the day they got installed.
Old Sep 4, 2006 | 04:18 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
The difference is not the material, and the comments about Young's modulus and Hooke's law both apply, just to different parts of the process.
Progressive springs are wound so the end that is wound closer goes into bind sooner. When those coils bind, the effective length of the rod shortens and the spring's rate rises. Linear springs are wound at a constant pitch, so the whole spring goes solid when it hits bind.
It's very important to understand a spring is just a torsion bar wound in a coil for packaging convenience. This is why cutting a spring raises its rate - the torsion bar is shorter, so the rate must rise. This is also why using a variable pitch when winding the coil results in a progressive rate. As the spring goes into bind, you progressively shorten the length of the torsion bar until the entire spring goes into bind.
Last but far from least, your dampers (shocks) hate progressive springs. There are no progressive dampers, so the engineer is forced to compromise damping rates based on a lot of factors, not the least of which is amount of time spent at a particular load. It's a big juggling match, and only rarely does it end up being good for the enthusiast. Far more often it is aimed directly at the "average" user who is most likely to complain.
Old Sep 4, 2006 | 08:00 PM
omgitsroy's Avatar
omgitsroy
i like answers like these
Old Sep 4, 2006 | 09:13 PM
Gernby's Avatar
Gernby
lo bux racer's answer's are always informative, but I fail to see how it answered Flipsonic's question... LOL
I would wait until the entire suspension settles in with the new springs. The springs won't change, but the bushings and upper spring perches will over a few hundred miles.
Old Sep 4, 2006 | 09:29 PM
koolaidman's Avatar
koolaidman
shouldnt have to worrie about adjusting toe. what u should be worried is camber considering when installing u can get +-3degrees
Old Sep 4, 2006 | 11:28 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
No you won't. There isn't that much camber gain in the suspension.
Old Sep 4, 2006 | 11:33 PM
IS300eR's Avatar
IS300eR
lobux cliff notes are for sale through PM's. j/k
Old Sep 5, 2006 | 12:55 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
I already answered flipsonic here.
mshmsh
Suspension
Jul 17, 2013 09:01 AM
350nub
Suspension and Brakes
Nov 29, 2007 09:17 AM
jy2003is5spd
Dec 2, 2002 05:07 PM
johnsc400
Aug 18, 2002 06:13 PM
