View Full Version : Suspension and Brakes
- Well this is interesting...
- Question on Rear Brakes for SC400
- Help with Supra TT Front Brake Conv. on SC300 (Shim and Fitting Kit?)
- Is it a good idea to do the ls brake upgrade without the ss lines?
- Oh my god ny i can't do it anymore
- Coilovers for my Soarer. Which ones are compatible?
- Noobs & Novices: Suspension & Alignment 101
- What suspension to go with?
- ABS module replacement
- Need some help freshening up my suspension!
- How much are the stock rims worth?
- Compatibility on Brakes & Springs?
- Front Lower Control Arm Problem
- Coils or springs
- FYI: Coilover Rebuild
- Replacement Brake Pads
- Leaking Coil
- Adjust toe on rear
- How to replace rear left suspension?
- Starke coilovers
- exhaust
- Squeaky Brakes,
- Will Rotora 6 pot clear?
- 5spd trac system????
- rubbing problem
- GT Spec??
- Power steering question per the pressure side
- replacing rear rotors
- Adjust eccentric bolts
- spacers and stock wheels
- SC400 Suspension
- Daizen control arm bushings, anyone kno?
- Which lowering springs for Supra Shocks
- Coilover instalation problem (UCA)
- Outter tie rods
- Need help with rims & tire size
- My new Wilwood Big Brake Kit!
- Outer Shell for Lower Control Arms. Where can I buy?
- Need help adjusting my new stance GR+ coilovers for my SC400!
- DIY adj. upper control arms?
- getting an alignment while low?
- Popping sound while backing and turning
- Remove the rotor
- Powered by Max coilovers?
- Need your air ride expertise on a leak!
- struts
- solid diff/subframe bushing measurements
- Picture Request. Spacers for SC400
- Question on Supra Suspension Set Up
- Has Anyone Ever Heard of These Springs?
- JIC Magic Tie Rods?
- in theory i can use these motormounts..right?
- Are these the right shocks?
- Any idea where I can a single megan lp coilover for the rear?
- Where to buy 97+ control arm bushings?
- Bump Stops
- clicking noise
- end links wont come off....
- Polyurethane Bushings
- ABS/TRAC Delete: Sizing Information for SS Brake Lines
- Help finding compatible camber kit
- What brand new rear struts on '92 SC 400
- JIC from a JZX90 Toyota Tourer on a SC?
- Front Passenger side strut keeps going bad
- Is my alignment going in and out? ride quality changing
- What is the tq spec on the front uca's?
- H&R 20mm spacers installed
- Lowered on nf210's w/tt wheels now I need a spacer?
- Supra TT Brakes and Master Cylinder Upgrade
- Installing LS brakes, what do I need to go purchase beforehand?
- What would cause my driver rear to set a lil lower than the pass. rear?
- Is this stock height or are my springs just saggy?
- BBK question
- HELP! Do They All Handle/Ride Like This
- Brake Pedal Travel
- How to remove stock shocks on 92 sc400
- strut mount question
- Sway Bars?
- Looking for height sensor control arms
- Air suspension Wiring diagram/pinout for UZZ31
- ?? for guys on nf210's can you still run stock alignment?
- imput on spacer for sc300??
- Adjustable Sway Bar End Links
- Tanabe springs idea/help on awd
- Rear Camber Adjustment.
- Megan Street Coilovers
- Brembo fitment on sc3
- Guys using UAS setup.. which coils are you using?
- Front End Clunk Resolved?
- where to buy camber kit
- 1gen GS300 coilover
- Sick of scraping!
- Strut bars for us...
- Are megans coilovers worth it
- Car "Wiggles" At High Speed
- Low yet comfortable... possible?
- Sway Bar Bushings
- steering wheel vibration
- Camber Bolts Question?
- earl's ss lines?!
- suspension Gurus needed.. please see inside
- Is Starke Coilovers Good?
- Supra tt oem springs for sale
- ls400 bbk question
- LS Brakes
- Tighten up steering?
- Looking for soft and low coilovers
- Help!! Front Wheels Shake in Reverse!!
- solo bleeder screws?????
- Brake Booster interchange
- steering rack bushing change waste of time.
- Coilover advice!
- Rear strut bar.
- help! testing ball joints,I have my new lca's
- Entire Front End Rebuilt
- raise/lower coilovers
- Supra steering rack VS SC300
- Grinding when turning sc400 1995
- Question about wheel and tire sizes for racing
- sc400brakes troubleshooting, new installed, advice needed
- BBK Options
- Got my bbk upgrade..!
- new updated cost of Lower control arms $540.00
- Tokico Coilover kit from suprastore?
- feedback on Tein CS
- So who has dropped with Tein S-techs?
- LCA $280. at carson? were is the best price?
- suspension shutters at low speeds.
- Give me some advice
- UPS Dropped off some Goodies!
- Uneven length of coilovers to even the ride...?
- after market lower control arms sc400 95
- How to lower front 3/4 to 1"
- Bushing kit recommendations????
- Supra TT suspensiion-QUICK QUESTION
- Clunking and a little vibration
- Coils Advice
- Anyone
- Front swaybar endlinks cause pop?
- Extended Wheel Studs?
- Supra tokicos and eibach springs
- Bout to order some shocks, have a question
- My new SC430
- HKS Coil Overs
- Best place tp purchase Megan ez coilovers?
- 97 SC300 Stock Front Rotors: Slotted & Drilled???
- shaved calipers (ls400 bbk) - ugh ohes
- lets talk battle version and megan toe rods and trac rods
- Lowering route decided but now I need some opinions.
- COILS...Ksport Kontrol Pro for trade or best offer
- suspension noises
- Ball joint boot replacment that works!
- DIY: How to rebuild your SC rack & pinion. 20k pics (well alot)
- Clinging/Pinging noise, SC 400 help!!
- When to replace Shim kit?
- Stiff supra springs?
- I want new ones!!
- Supra TT Rims
- what coilovers go the lowest?
- Painting springs
- Experience with Battle Version?
- SC400 suspension revamp
- Rear UCA
- SC300 suspension overhaul ... Parts List and questions
- Prep calipers for paint? how should i?
- Bag over struts
- Delete
- What suspension? Spring and shock? Coilovers?
- Need Your Opinions on Shop Quote
- Where to buy Steering Rack bushings
- Replace OEM struts...need alignment?
- Steering/Tramlining/possible brake issues
- Steering vibration turning wheel left VIDEO
- Coil overs or normal setup
- Supra rotors on SC300??
- sc400 corner weight
- Custom tie rod spacers
- Alignment results 1997 SC300
- Want to go lower... good spring compressor?
- supra springs question
- taillights out, need help
- Which springs to remove fender gap on 275/35/19's?
- A Gixxer-Drew suspension abridged writeup with pictures
- Different Spring for Driver. Front?
- 1992 SC400 Rear Subframe.. Need some help.
- rear wheel problem
- Best source for Control Arms?
- Supra springs in front only?
- Spring Setups
- TT Calipers Leaking Help?
- Radiator
- Tutorial for wheels studs of front and rear SC3/4
- Bent Lower Control Arm. Help!
- mk3 tems shocks???
- Ugh... front end still rattling/clunking/shaking after new parts
- Spring Insulator Part #
- Looking at replacing stock struts...
- NEX coilovers, good deal or "you get what you pay for"?
- my new stance
- New Stock Lower control arm bushings
- OEM Rear Factory Lexus Shocks
- Do these lower control arms look different
- Installed some springs..your thoughts
- i need to be lower!
- For those of you with Megan Coilovers
- can we use this?
- TEIN coilovers?
- Lowering springs and stock shocks ?
- rear coilover problems
- Help deciding on Shock and Springs
- Is anyone on B7G Springs?
- Just got Eibachi Springs... I need struts...
- Interchangeable rear toe arms?
- What kind of shocks should I get
- What model lexus wheel hubs are compatible to the sc3/400?
- Are coilovers the same for 94-97 GS300 vs. 92 SC300... Help!
- TT suspension
- Coilovers which ones to get?
- Brand New Rotors
- alignment ??
- Supra springs and Bilsteins
- Ls400 brakes worthwhile?
- which rear brakes fit?
- The Best Coilovers for a SC
- sc300 suspension and braking from the beginning
- BC Racing Coilovers Help
- it's my Megan coils making the clinking,clanking noise.
- sc400 air suspension in my soarer ?
- Coilovers but no tools
- Titan rear sway bar ??
- Doing a swap
- SC400 Front Struts '94
- supra sub frame mounts??
- Steel braided lines ??
- SC300 compared to Soarer rear brakes
- In desperate need of help with steering / front suspension issue.
- Want as close to an LS ride as possible in my 93 SC400
- putting bigger rotors on a sc300
- wiring harness
- speed wobbles?
- Part numbers for ls400 caliper components?
- Titan sway bars...Adjust?
- MY PBM coilovers
- SC outer tie rod issues...
- Sage RCA or similiar
- Need help removing LCA
- Tanabe? DG5?
- Any good Racing Calipers for SC400??
- TT Spring Hitting TT KYB AGX Strut
