- What are my options for front shocks
- HELP - Height Control Switch not Responding
- Lexus GX470 2007
- Radiator- Timing Belt Kit- changing fluids??
- Odd stereo issue..
- Diagnose faulty backup camera?
- Finding a Good GX at a good dealer.
- 1" Lift??? Dont want to give up too much ride quality.
- Remove the rear Hatch inside panel to replace back door lock assemblythe
- Rack assembly leaking
- 2008 GX 470 I have a new on on the way!!!!
- KDSS Light Illuminated on Dash
- Brand new owner! Struggling with aftermarket wheel choice.
- Looking for a replacement GX470 Mud Flap
- Timing Belt DIY
- Sleeper GX Build
- Torque Specifications
- Intermittent Engine Whirring/Zinging Sound
- Side airbag recall 2004-2006
- Early GX470 as a comfortable bad weather "beater"?
- Brake bleed
- Considering buying used GX 470
- Long term fuel trims really high and P0430 code
- Possibly sticking Caliper 04 gx470
- Bent Suspension Mount on Rear Axle
- New to us owner...
- Suggestions for a smooth ride
- Trying my BEST to avoid the minivan
- Oil pan replacement
- GX Wiring Diagram Wiper Washer System with Rain Sensor
- GX Wiring Diagram Starting & Charging
- GX Wiring Diagram for Sound Systems with Rear Entertainment
- GX Wiring Diagram for Sound Systems W/O Rear Entertainment
- GX Wiring Diagram Power Distribution / Power Windows
- GX Wiring Diagram Interior Lamps incl Horn / Rear Wiper
- GX Wiring Diagram Exterior Lamps incl Tow
- GX Wiring Diagram Engine Control
- GX Wiring Diagram Door Lock
- GX Wiring Diagram Air Condition
- Oil Analysis report
- Do you have any nominations for links for the 1GX FAQ & DIY Thread? Your help needed!
- VSC TRAC, VSC OFF and Check Engine lights with code P0057
- Help - cannot open passenger door after changing actuator motor
- My interior redo madness.......
- Looking at buying 2004
- Sewellparts.com
- 2016 Navigation Map DVD Gen 5 U40 15.1
- New GX470 Owner
- ML stereo volume briefly stopped working
- 2005 gx 470 rear suspension
- Keys please
- 2005 GX470 Aftermarket Radio and Rear Seat Entertainment
- Just bought my gateway GX! A few questions
- GX470 Rear Door Gas Strut / Spring Mod
- Timing belt 2007 Lexus GX470.
- GX 470 Seatbelt / Seat belt assembly malfunction
- 2004 GX470 heater blower
- kdss failure
- Need help replacing on replacing Windshield Washer pump
- VaisTech MML Quick Review
- GX470 Intermittent Start Problems
- Wiring Diagram? Reverse Light Wire in Cab?
- Window issue, binding
- power steering issue
- front & rear shocks
- K&N air filter damage?! Please help
- Suspension issues
- Spark Plugs From China
- Anyone buy a remanuf Denso alternator?
- gx470 2007 dash dimentions
- Range indicator won't reset after fill-up
- Poopy P0420 Code
- 2005 gx 470 rear air bags
- 07 GX 470 Drive Cycle
- Water too Deep
- Shock Options
- Quick intro.. new owner!
- All new brakes...shaking persists
- Gas smell when starting the vehicle
- Buying Advice on 2008 Gx470
- 2007 GX470 Dual Zone Heater Problem
- GX470 Build for Overland (build thread) pic heavy
- Biggest Tire size for 18x9 0 offset for stock gx
- Did I really just brick my navi?
- Rear Suspension Airbag Issue
- Hood Struts/Shocks Which Ones ?
- TPMS Troubles
- GX470 Remote Oil Filter Bypass Install
- Timing belt vs chain
- Strange Noise From Behind Dash
- Home made LED bulb replacement
- Fumoto Oil Drain Valve
- Which wheel do u think looks better on a White Gx??
- how to replace the bulbs in the suspension control switches 06gx470
- Is GX going to ride better then a 4Runner
- Leatherette seat covers?
- Help Diagnosing Issues?
- refreshing the ride
- Vsc light on check engine light on
- 2006 gx470 led door lights
- 2015 Nav Disc
- VAIS Tech up to 25% off, just bought MML
- GX470 or GX460?
- How to remove/reset error code on a 2007 GX470 tire pressure monitoring system
- GX470 at 10,000 ft on Michelin Latitude Tour
- Brake Master Cylinder Leak
- Does this look Right?!!! Bilstien 5100 with stock springs
- Blinker Question
- After market spoiler possibility?
- Cargo Measurements?
- 3rd row seats
- AC Switch Button
- Had to share this find...
- Interior smells like mold when GX is running?
- Help Me Buy- Testing Function of 4 Wheel Drive
- 2005 Rear Door Glass Water Leak ?
- Brake Controller
- I'm in the club.. new owner of 2005 GX470 Sport
- Rear Calipers torque spec
- 2004 GX470 radiator
- My GX was totaled
- 2008 GX470 for sale in Washington with 3,800mi.
- O2 simulators?
- What did you buy for your GX on black fri/cyber Monday?
- Airbag light on after new stereo installation
- Poor man's lockpick.
- Tire Pressure
- Pinched CPS Wire Harness behind AC Compressor
- slipping
- Rear Height Control Failure
- TPMS Flashing
- 07 GX 470 Codes
- Interior LED Bulb Replacement
- Seat Belt Indicator
- 2004 GX470 belt moulding
- New(ish) GX Owner
- 2004 GX470 New dash pad
- My lift
- Finally got my GX 470!
- HELP Please!
- 04 GX: anyone replace either exhaust manifold (or both)?
- GX470 Transmission Replaced
- Will 265/70R 17 Tires Fit My GX ?
- Spark Plugs, can this be fake?
- 2007 GX 470 Alternator
- What Suspension setting do you use?
- Anyone use USASPEC BT45-TOY Bluetooth Adapter?
- Did I do ok?
- New Owner
- 2009 LX 570 vs 2009 GX 570
- P0420 / P0430 - Where to Start
- Navigation / audio system upgrade options for 2007 GX
- Transfer case issue?
- GX470 (2004) rear door/hatch tool kit?
- How much of a price premium should I expect for low miles?Bluemunds cost estimates
- Power steering fluid
- Dashboard Job
- Good Tire Story; ++ for Michelin
- Need some advice before buying 2006, 2007, or 2008
- Rarity of a Sport Package GX
- grinding type noise
- temperature gauge reading on cold days
- Anyone install a new radio and speaker?
- Roulette Wheel sound from cold start up?
- New brakes and shocks. Need some help.
- Got my new dash today.
- Test drove 2007 GX, question about braking system
- Buying a 2005 GX470 from CarMax
- Introduction
- 2007 GX, 140K miles, Timing belt?
- Loud "failing pump" noise coming from rear left area
- Tires Michelin Vs Conti
- Ac Problem 08 Gx470 Please Help
- Backlit Buttons-lower left panel
- Rear wiper arm replacement
- New to me 2009 Gx with some rust, need advice
- Keyless FOB for the valet key?
- Rear Suspension Problem
- Down assist gone after tranny fluid change
- Stereo Options for 2006 w/MLand Nav
- Sad day for me.......
- Dreaded Drone
- 2007 Nav/radio console fit in a 2005
- Introduction and Production Date question
- Check the connection of the air conditioner msg but everything works!
- Bottom engine plastic circular caps
- Bottom engine cover fasteners
- Install Nitrous on 2008 GX470?
- Saying Hello
- 2005-GX470 - Air Ride Replaced -- STILL NOT WORKING
- VSC Trac VSC Off lights on
- Wheel/Tire Fitment on GX
- Bilsteins rear shock part number
- Questions Regarding Buying 2003 GX470
- Purchasing a 2007 GX - what to look for
- Right wheel skids on very hard braking
- Bad front differential?
- Head light bulb Replacement/Recommendation
- Head light bulb Replacement/recommendation
- What's the Best Way to Rust-Proof My GX
- Bottom out ?
- 109.000 miles and maintenance items
- 255/80R17 - Stock Wheels?
- Thought Process - Modding the GX
- Touch Screen Replacement
- Front Differential Oil Leak
- Changed the radiator - tip
- New GX460 Interior
- Replacing the whole suspension
- Lifting my GX
- New member intro thread from Montreal
- 04 GX470 cranks but does not start. Starts second try
- HELP - Bulb fell in Running Board Housing
- Front shocks
- Questions before I install lift
- Front Brakes Are Rattling
- IPhone 6s and Bluetooth
- Headlights for sport package?
- Year 2003 gx 470 rear seat skirt
- Engine compartment plastic retainer clips
- headliner removal
- Loose Part of yr 2003 GX470
- How to turn off key lock "beep"
- High mile 2006 - What is it worth?
- New to the forum BW GX470
- Front Door Over-Extension Issue, Window Bind
- Front door panel mold repair
- GX470 lift points
- 2003 GX repair quote
- I'm in search of a GX!! Advice needed!
- Nav GPS Update - Worth It ?
- Binding when shifting into 2lo or 4 h
- Largest size spare tire under the truck?
- Clear coat peeling - What can I do?
- ECU reset after Air fuel ration sensors replaced.
- Don't use OEM 4runner springs for suspension conversion.
- Inner cv boot part number?
- Stereo Mode Advance issue
- Powerseat rail issue (pic)
- Removing rear bumper cover
- Does your crossbar have any play?
- Lexus Dealer called, new dashboard is in to replace cracked GX470 dash, tips for you
- Catalytic Converter Sulfur Smell Fix?
- Differential Oil
- trunk chrome trim for 08-09
- No sound from speaker, is it blown?
- Was the GX470 ever available in basic trim?
- 4Runner to GX470
- Night Fury Photoshoot
- VIDEO TUTORIAL: How To change your turn signal light bulbs and how to upgrade to LED
