Timing belt vs chain
I just had the timing belt replaced on my gx470. I was told that there is a chain that will protect the motor if the belt goes bad. is this true? and should I have replaced it anyway according to the manual? thanks
If the belt goes bad then it's lights out for the engine. There is no chain that "protects" the engine. If you had the timing belt replaced then you are fine, so long as all the other timing components are in good working order. There are are two pulleys and a tensioner that if they go bad then they can make the belt fail. How many miles on your GX?
...don't forget about the Johnson rod. It's a critical piece of something or other.
https://video.search.yahoo.com/video...sigi=11vt747gb
https://video.search.yahoo.com/video...sigi=11vl28dqu
thanks everyone for your help, I really appreciate it. I have one more problem. every 500 miles my check engine light comes on. the code is p1442. the vsc, rsc, lights come on also. I cleared them, but this didn't happen til after the timing belt replacement. any ideas? thanks cptjack1
Or you can buy the bypass and simulator and never have to worry about it again. Dorman isn't the greatest quality stuff.
thanks guys, my next question is: is the air injection pump one of the normal culprits for the p1442 code? when ordering this pump where is a good place to buy it? I have someone who will replace it if necessary, and lastly exactly what does it do and just how important is this item for the engine? my wifes Toyota has a evap leak code for years and it doesn't cause any problems. I replaced the fuel cap last week to see if that helps. as I think about it the code came on after a fill up. I really appreciate your help. cptjack1
by the way, where is the secondary injection pump? I also have 125k on my gx. the primary pump is the one under the intake right? It looks like a fuel filter housing for a piece of farm equipment. thanks again.
mooseboy84
Oct 31, 2015 11:35 PM
gslover603
Feb 2, 2007 02:55 PM
