- Dripping Water Normal?
- Valve cover gasket leak ?
- VSC Off light comes and off under acceleration
- intermittent starting on 2003 gx470
- Low gas light on dash dead - what type of bulb do i need?
- Help!! I'm at a loss. Brake Lights stuck on
- brakes
- is this transfer case leak ?
- Will Lexus replace the cracked dash?
- 2010 es 350 navigation
- Hello, my first post here, looking at a used GX470 in Bay area have a few questions
- Lexus GX470 - Best location for 6" x 14" x 2.5" deep DC to AC inverter
- Air flow “control boxes” failed, now what?
- cv boots and axles replacement
- Have Techstream working - Now how do I ?
- 04 gx470 suspention questions
- Tires for your GX
- Kill Switch
- GX470 kill switch
- ML amp wire diagram
- GX470 - Dealership recommending service
- Bulb Problem?
- Do I really need to change all these parts?
- AC 115 relay for compressor?
- where is ac avap temp sensor on 03 GX located?
- Grab handle color?
- Mark Levinson Audio system non-functioning
- changing rear shocks gx 470
- Big 3 upgrade(battery,engine,alternator)
- Need help on GX ac issue cold to warm and back
- Trailer Lights not working.
- Clunk in doorpost
- Instrument Cluster LED's on 2004 GX470?
- GX a/c getting warm when sitting/cold to warm few seconds while driving as well
- Anyone else keeping an eye actuator leak and just checking t-case fluid regularly?
- 2003 IS300 front blinker light replacement
- No Crack Dash Board
- Question About Dashboard (yes, another one)
- Dashboard making noises?
- 2007 GX470 Air Suspension Early signs?
- GX470 Tires
- My navigation system stopped working
- GX470 Advise
- Satellite for 2009 GX470
- Backup Camera Stopped Working?
- Need Help with 2nd row seats in GX470 2004
- 2006 RX 450H Lift Gate thud
- Contacts Transfer
- GX470 2008 Backup Reverse light Water Condensation
- DVD player in stuck mode
- New to me GX470
- GX 470 steering wheel vibration above 60 mph....annoying
- '04 GX470 PS Pump Replacement
- 2008 GX470 - Fuel Filter Replacement
- Replaced battery now the three passenger windows will not open
- slipping transmission on 2007 lexus gx470
- GX470 trans fluid WS exchange, from top of truck
- Lexus GX470
- Dash Replaced but now Navi Shows my Location Wrong
- Brakes suddenly stopped working
- GX470 Lexus thump, my .02c spline joint, drive shaft
- Vaistech MML vs. SLB3 (Bluetooth)
- Towing mirrors, mirror extensions
- Sticky dash
- LRD Off Road
- Check Engine, VSC, Track Off Lights Stuck On
- Factory Aux not working-- 2008 GX
- For Sale: Tan Third Row Seats out of 2009. Like new
- OEM Wheel Color
- Adding Dynamat behind subwoofer
- gx470
- Lifting my 06 GX470
- Need Brake Pads where to get them?
- Rear wiper partial sweep coverage
- Post-carwash leak onto driver side floorboard
- Car dropping problem
- What would you pay or suggestions
- Engine cover fasteners
- Safety First
- Tires - Cooper A/TW?
- Yellowing headlights on a 2005
- l did a thing, blown amp on 04 GX470
- 2004 Blizzard Pearl paint peeling
- Leaking Rear Air Suspension
- Alternator going bad? Now what...
- Anyone know what this is/goes to?
- rear passenger door lock failure after battery drain
- Timing Belt - to change or not to change
- Steering rack replacement DIY
- Silver GX with bronze rims
- MAF Cleaning?
- Suspension
- Looking for Advice on Suspension Airbag Replacement
- GX470 - Soledad
- Rust & Corrosion Preventive? (coast driving)
- Do I need the covers around airbags?
- Just bought garaged '05 470!
- Radio suddenly sounds terrible
- Finally found the "rumble" noise.
- Engine Whine w/video
- New To Me 2008 GX
- Abnormal driveline whine/howl
- Fog lights as DRLs?
- Got the dashboard crack TSB completed
- rear air suspension problem
- 07 GX470 RPM Question
- Rear Brake Caliper
- new rear and front propeller shaft
- Power steering fluid change on high miler
- Rear Axle Vibration-New Owner
- timing belt
- Bleak Rumble from back Wheel/Tire on 0-5 mph
- Transmission Issue
- 03 with dipstick trans fluid first low then high?
- Starter access on the UZ engine
- TechStream software info wanted
- New to the GX
- Complete noob oil question
- Side mirror turn signal
- 2004 Model: 470LX Lexus
- Low Windshiled Washer Nozzle Pressure
- 05 GX470 backup camera
- VAIS Tech SL3b-L with RSES
- Stock wheel lugs/ lug nut size
- Lexus RX 350 / 450h OEM Screen Gone Blank
- gx470 2006 reverse light always on
- Rear AC Temp
- New to CL
- Removing clear coat adhesive
- Down hill switch on console
- To Flush or To Drain & Replace
- About to Purchase
- 2008 GX suspension air release
- 2009 GX driver and rear AC blows warm air
- Cursed GX Part 2 (Vibration and Mirror problem)
- No sound radio-Navigation sound OK, Service check: Audio H/U says "Chek" - GX470 2007
- Broken Reflector
- Bad Blower Fan
- FS threads go only in the classifieds, not here
- Easy Trails in UT
- GX470 vs GX460, Just bought a 2017 GX460
- 06 GX front passenger door check.
- Changing Front Side Marker Lights
- The Cursed GX cd/camera/clunk problem :)
- Roll Back & Sliipage
- GX470 ac compressor cycling on and off quickly
- Gx470 05 backup light always on
- 03 gx 470 condenser fan replace easy job?
- Anyone Remove Cig Lighter Socket?
- VSC Trac light on after alternator replacement
- Tire Pressure Sensors
- front axle assemblies
- Strut replacement (keeping air suspension) input needed
- gx 470 steering rack leaking
- Shop manuals
- aftermarket Reverse camera with oem nav?
- Lexus / GX470 / 2003 Making Noise Under Brake Pedal After Being Pressed
- 2006 GX 470 rear suspension stuck in "n"
- 2006 GX470 rear suspension conversions
- Looking at GX 470, GX 460. Thoughts/Advice?
- Help! How to remove interior panel near left knee?? Picture Included
- Suspension Control ECU - C1761 Code
- GX470 front spacer lift kit comfort/sport control
- Tpms 2008 gx
- Tilt-away steering wheel.
- Anyone here from Philly with 2006 Tan interior?
- 3rd Row Seating
- 2004 gx 470 possible purchase
- looking for a poiler for a 2004 gx470 in Canada
- New GX electrical problem - turn signals, srs, seat heaters, a/c
- drivers seat
- Side marker bulb burned out/replacement?
- Front and Back blinkers not working. Whats the issue?
- Stuck ingition cylinder
- GX in North TX Salvage Yards
- Crankshaft Seal Part Number
- Mark Levinson amplifier
- Drivers side AC not working
- What am I doing wrong?
- Looking at 2004 - thoughts?
- window molding chrome piece retaining clip
- Tranny temp procedure
- Replacing Nav with Non Nav?
- Intermitent driveline vibration & audio issue
- Wheel Upgrade
- 2009 GX VSC Problem
- 2004 GX wheel/tire upgrade
- I have a 03 GX bought the east & west DVD'S getting "I Agree "
- 2007 transmission fill plug.
- Front headlight HI LO suggestions.
- Removing driveshaft
- Super bouncy rear suspension
- '05 GX Side mirror not returning to position
- Truck turned off while driving
- Bilstein 5100 Part Number
- 2008 GX470 Rear speaker replacement
- Rear Door Rubber weather strip
- transmission filler plug where?
- Got new shoes saved $270 bucks
- Factory Bluetooth issue
- Intermittent AC control issues on NAV screen
- What is the best way to install a Winch on the GX?
- Alloy Wheels & Corrosion?
- Another Key Question?!
- Third row seats
- Air suspension GX 470
- High pitch noise (coil whine) coming from A/C, what can I do to solve this?
- Navigatin override
- zerks on u joint?
- Moonroof rattle
- Might sell the GX :/
- grid lines-parking
- looking at a '08 GX today
- Vaistech SL3b
- 2004 GX470 A Good Deal?
- AM/FM Radio Presets
- GX470 door lock wont open or close
- Bypass factory amp
- Anyone have a part numbers for the sport rook rack?
- Dome/Courtesy lights fuse instantly blowing
- I thought I would ask the crew!
- Being told my "clunk" is actually transmission going out. Help!!
- What Hose is this?
- Aux audio interface
- Front Turn Signal Goes Out Constantly
- Do I Need CAN Bus for Xenon Depot Xtreme HID Kit?
- How Much Do Third Row Seats Weigh?
- intermittent KDSS light
- P0007 Fuel Shutoff Valve control circuit high
- Brake Problems. Dealer Liable?
- Hello
- 03 GX no heat/ac issue as well sometimes
- Buying a GX, Totally New, Forgive Nub Questions
- Mods for your pooches
- Replacing Air Suspension with 4Runner Strut and Coil
- Center Console Doors Stuck
- Power Steering Rack Leaking?
- Servo motors/evaporator core replacement (2006 GX470)
- Radiator
- GX470 @nd row seat won't fold down
- Looking at used GX 470s - anything to be aware of?
- Rear gate door light issue
- Wheels and center caps
- New member, new GX!
- Do they have the air ride?
- Full Stop Shocks?
- Colorado Meet and Trail Ride 1-14-20017+1-15-2017
- KDSS - shock differences?
- New Member - PA
