- Suspension install, any gotcha???
- part number for inside air temp sensor
- gs300 antenna
- Reprogram Remote Key?
- Help please Re: hood strut/piston/support
- still having trouble :(
- Drift Aristo! pics
- Those who drive in cold weather
- rotors and brakes on ebay
- Wondering what kind of exhaust this is.....
- Just bought a 2000 gs400- problem with nav screen
- What is this?
- which key is whic
- Gauge Lights
- big problem with my GS!!! please help
- 2002 GS300 help
- Bad contact in cluster??
- Post pics: 1stGen w/ stock JDM ARISTO front
- Lords and Ladys....
- Been searching..Shocks and Springs
- how much would it cost for a new paint job
- Nakamichi radio ?
- GS 300 Radio Question
- Gauge lights question plz help
- Not Sure If This Is Typical Amp Failure??
- Few pics from HIN San Jose.
- GS300 Has strange shudder
- IS300 fogs
- New Member introducing myself (so cal)
- lil bit of a problemm.. (locked my keys in the trunk)
- Coming to a Stop and the car dies
- Single-outlet exhaust
- car doesn't want to start
- cracked wood grain
- *need help rear bumper*
- Cluster Lights
- Problem with my speaker box
- whats wrong with my car?? missfire??
- 1 st gen gauge cluster removal
- selling my gs300, what do u think?
- 1jz in a gs3
- Serpentine belt tensioner question
- will jzs147 suspension fit supra?
- Brake Rotor Size ?
- the light that says im in Drive, doesnt work anymore
- to find out some info
- turbo kits
- What type of wheels are these?
- What color should I do my steering wheel
- Vibrating
- Why do some 93-97 white gs's have a more prominent contrast to the grey and white?
- compatibility
- JIC suspension
- want the new oem beep sound
- 20's or 18's
- WHere to Find a ECU
- How do i put an HID kit into my IS300 fogs?
- Just bought this in Japan :D
- Wow These Cars Hate Snow
- Antenna
- brake bleed problem 93 gs300, brake light on along with trac light.
- Rear caliper size???
- WTB: Drivers Side A-Pillar Piece (interior) for 2001 GS300
- Problem - dead battery in 1 weeks time!
- 1993 gs300 transmission question
- is this good for a replacement
- thinking of rims
- Re-attaching the rear seat GS300
- wanna clean out your system?
- Why GS300
- Club Lexus Represent!!!!!!!!!!!
- Manual transmission into 94 Gs300 is this possible?
- 1st Gen Wood Steering Wheel swap
- Window regulator DIY instructions wanted!
- water in egr valve
- Selling GS300 - what you think it is worth?
- WTB: 93 Shifter bezel
- 2JZGTE question
- How can you tell your power steering pump is working??
- Car Smoking
- Soarer Trans in 1st gen
- need to know what tire size for 16" rims
- Re-Polish my wheel lips??
- my motor shaking at idle
- problem....please help
- coming out slowly
- Lexus says 4, KBB says 5
- honda/acura beeping
- Kewl GS3 mod
- Has anyone tried royal puple in their tranny??
- g-teched my car today
- Will 255/55/18 fit on a 1st Gen?
- Sears Tire Center Sucks!!!!!!!!!!!!!!!!!!!!!!!!!
- Is Tranny
- I'm hearing 3 not good sounds from beneath the hood
- I am getting a 93 GS300
- Alignment Specs
- cant get my throttle body off
- Engine pull in 95 minutes
- why is my throttle piece stuck open???
- whats going on with my motor!!
- Camber kit
- Radiator options
- Best source & price...
- MKIII diff swap
- Thought you guys might enjoy this.
- Starting Trouble
- 1st Gen aftermarket HU(1996GS)..Has anyone......
- Post a Pic of your after market HU
- Canned Mufflers, or straight pipes?
- 1st Gen Gs Dash kit.
- Es 300 Rims
- AeroTect Head & Foglight overlays.
- ****Lexus keys****
- antenna motor
- transmission vibration??
- wheel stud length??
- stock stereo questions!
- Engine parts help
- 01 GS300 airbag diagnostic port
- new, tried search but couldnt find info on RSR springs
- stereo removal...93 gs300
- Does this fit the 1st gen?
- GS300 1998 Keyless Entry Issue - NEED HELP!!!
- Anyone have spare parts?
- Problem! Has this happened to you?
- RPM at Miles/Hour
- Spark plug wire part number
- taking apart exhaust system at home*read*
- Great Info For U All !!!!
- car hesitation from stand still(vibration)
- Kaaz Lip spoilers... fitment on USDM Bumper
- GS 300 window regulator (driver's side)
- rotors and brakes
- how do I disable my alarm permently
- fuel door wont pop
- alarm, stock wheel covers, 93 gs3 mint for sale
- Wheel settings
- o2 sensor/mileage relation
- City light mod for 95 GS
- Denso OEM O2 Sensors....
- need advice in purchasing a 93' gs300
- Bought Lexus GS300 93! 500.00!
- my predicament( WITH PICTURES)
- Put a philips 6000k in yesterday, yay
- Is it REALLY an advantage....?
- Went to a Dyno Day today.
- Light clip
- Angel Eye Headlight
- looking for some GS tips
- spark plugss
- engine cleaning
- Does anyone know where I can buy new headlight cover (lenses)
- airbag warning light
- Wheels
- Any blocking issues for adding turbos?
- Code Reader
- Alternator Fuse
- My *NOT* so ugly intercooler
- Front seatbelts loose
- Code 71 fix*how to*?/?
- Tire Size
- My UGLY intercooler
- Timing Belt
- Battery Discharge Warning light?
- JDM Headlamp HELP!!!
- Wood steering wheel...
- Which tires fit? 18" rims
- Audio Install
- getting really pissed off with the antenna(how to disassemble the motor)3
- HOWTO: Remove headlights 93-97 GS300
- I made some mistakes and I think I broke my starter
- How to make it more quiet?
- Unsmooth noise at idle
- my radiator keeps drying up
- Light fail warning light
- Almost done!!
- Seats 98 Gs400 vs. 01 GS430
- Help needed w/ driver's seat problems
- resonators
- is 1st gen gs RESONATOR straight thru ?
- i like
- I want to move my ABS.
- Headlightbulbs
- Options list 1993-1997 GS300
- Replacing fuel pump
- Need Help In Replacing Antenna . Stuck At Bottom End
- no air coming out
- warped rotor
- Bad News:(
- hey are these the 98 GS400 rims?
- Trac And Check Engine Light On ?
- test
- Car audio repair...is that an option?
- Merry Christmas to me look what I got
- turbo lag
- replacement antenna
- Thinking of buying a 93GS3
- Jacked up...Left rear tire spinin, right tire isn't....!!!!!
- Where to get Aero parts for my 1G GS300??
- Supra Turbo Calipers
- Manual transmissions in either GS300 or 400 in U.S.?
- 18" oem LS430 wheels
- dash lights
- A few night shots.
- i need a PART! HELP!
- What did i do to deserve this!?!
- rotors
- my baby's screaming at me :(
- Bryan aka LexAristo came to my house to show off something.......
- Cel 21
- Remote Starter input needed
- Common Transmission Problems?
- How are the Yokohama tires in snow..
- There's nothing to exitng about our trunk space
- 1st gen drifting..requested vid/pics
- GS V8 engine in first gen GS?
- ClubLexus Gen 2 GS member map:-)
- Fog lights transformation...need advice
- GS300 over 190,000kms?
- ABS light on, CAN'T get out of park HELP!!
- 2JZGTE Swap..........
- No cross posting allowed.
- WORKing on my 1st gen..pics!
- Butt warmers not warming
- Anyone have pics of GS with IS wheels on it?
- What type of bulb is this
- size of rims
- LexAristo on IGN?
- Window regulators gone bad?
- Work in progress still...no pun intended...
- making custom headlights
- Wheel lip needs re-clearcoated! Help!
- paint job
- Neeeeed Help
- Will these fit??
- 1st Gen parts online
- intercooler mounting question
- How in gods name would 22s fit on here?
- How do I raise my headlights?
- Biggest Rims
- Taking off front bumper
- So glad I found this forum!
- Pics of my current GS300
- vent visors!
- I'm hearing some different noises when I turn, need help.
- can i do the following with my lights....
- Noob
- 94 gs300
- Those who own 95 and lower fuel..need info!
