Antenna
I have a 94 gs 300 an my antenna doesnt work its never worked since ive had the car an would like to fix the problem. When I looked at the antenna from inside the trunk there was 2 wires cut black/red pink/blue. Are these the 2 wires needed to power up the antenna? i also have an Alpine head unit. Thanks
Why cant they be spliced to their corresponding colors? Pink/blue goes to Accessory switched power and black/red to ignition switched power. You could hook them both together and to the radio red wire it should work although antenna may power up when key is in Acessory instead of ignition.
SCereal
Jan 12, 2012 05:02 PM
rattler96
Aug 19, 2008 12:59 PM
Kyle Harty
12
Jun 5, 2003 11:23 AM
