- This or that?
- Help please
- Clearing heads nd taillights
- lookin for left outer tie rod
- Code 25 fuel lean
- need help takin out my starter
- change starter w/o the coolant issue - 1.54hrs ttl
- my new covers and visors
- tranny warning light issue
- Seat brackets
- JZS147 Aristo-Swap Downpipe Options
- Saw this for sale, made me LOL :)
- wheel??? 20x10 and 20x8 1/2 ???
- Does any1 have a front bumper
- Some picture's of my 1st gen
- re: I need some help from all of my 1st gen guys....
- FINALLY! No Longer a stock GS....
- Professor Sheepdog BOV
- Which of these piggy backs for a turbo GS?
- Sneak Peak on my GS....
- Will g35 rims fit
- Will g35 rims fit
- seats
- Stuck antenna
- Enjoy and relax to Yolanda Be Cool
- Rattle-Can vs Maaco
- Megan ez coilovers
- rain guards
- Fuel gauge question
- DIY transmission fluid?
- 205/55/R16's on stock GS wheels?
- ball joint intergrated with arm?
- ls400 cluster
- New jersey help with gs
- Coilovers
- can somebody tell me a little bit about these wheels
- Are lexus oil pumps self priming??If not How is it done??
- Alternator Options HELP!
- 20x10in in the rear.....
- Help! Might have to sell my 1GS 3 weeks after buying it.
- Is it worth painting the bottom half of the car
- Check engine light diagnose?
- mines ecu
- Can I use instrument needles from 94 ES300 on my 95 GS
- 93 GS300 question pls help
- jzs161 front end on a jzs147?
- GS300 GT45 Fuel/ECU questions
- Phone antenna removal help
- steering
- Shop that does swaps
- Seatbelt light on- seat dead
- 1jz swap ?
- 94 GS 300 wont crank
- Floor Mats/Carpet
- coilovers
- Does it make sense?
- will be picking up my GS in 1 week.
- Anyone got pics of the shaved tie rod bolt to fit LS400 bbk?
- ABS Light problems!!
- Window Visors
- Key FOB
- Rear Camber Issues!!
- Electrical Issues I think
- Rough idle....
- Anyone got pics of their GS with this particular wheel offset?
- transmission problem ??
- Anyone seen this car before?.
- last pictures of my car before basic
- Aristo Wale tail
- differential question
- Less is More: Conservative GS Modding
- alternator wire conection GLOWING RED HOT
- Question: Can I use a 2nd Gen Key on a 1st Gen?
- My gs is over heating!!!!!!
- Please use classifieds for FS threads
- Rear door window question
- Automatic steering wheel problem
- wheel hub/bearing question
- top end rebuild write-up?
- ECU Grounds and locations?????
- Mine's ECU on ebay!
- HELP running Pig ritch at idle and lean at boost??
- Does anyone get 15mpg too????
- How much to swap
- 1993 GS300 with fault codes 21 and 24
- Looking to Build a Portfolio
- 06 GS not returning to idle (sometimes)
- 1GS at the Nurburgring!
- Need a favour from someone, suspension help
- fuse question
- jzs147
- Please use the classifieds for FS and WTB posts.
- Gs300 Swap Help
- CV Joint Replacement
- GS300 Run rough,NO Check Engine Light,No A/C, but O/D off light works
- 93's Rear windows wont function.
- Radio Install using preamps on aftermarket radio
- gs300 rear brake pads
- SC300 struts
- Need help with exhaust system
- Is 242k too many miles?
- Length of R154 shifter extension for First Generation GS300?
- Bushing kit?
- Strange problem: Can you shed some light?? Litteraly!
- Changed Instrument panel bulbs
- whats the width of your tires on 20"s?
- Strut bar question
- EZ Help Small Issue!
- offset question
- Tire fitment??
- anyone wanna see the worst aristo ever
- To buy or not?
- Meth kit.
- My new cluster
- gs300 audio
- Aem Gauges
- Rear windows wont move. help please.
- Any Ideas?? Please READ :)
- kill switch
- Any 1st gen meets in socal?
- Performance Exhaust & Induction Kit
- GS300 problems - Help needed!
- Anyone knows how to translate the aristo schematics???HELP
- 5 speed write up?
- 147 runs 10.6
- 1996 gs300 wiring diagram/pinouts (R154 swap help)
- New intro.
- Looking for Aristo Wiring Schematics>>HELP!!
- Merry Christmas
- Can't bleed rear brakes after TT brakes swap...
- where is thermostat
- Sluggish needles. Suggestions?
- Is it possible there are no JDM bumpers left?
- Removing rear bumper
- vibrating/shaking of car
- anyone know????????
- Early shifting, slow throttle response
- Gs....tire size question????
- 1st Gen Fog Lamp Bulb size?
- Gauge cluster problem(i hate sylvania)
- Bad bad 147
- My ride
- New to forums
- Muffler Question
- Need help finding a motor?!!
- Went to the junk yard today
- Still looking
- stalls, won't start for a day, then starts with white smoke and stalls again!
- which sensor will cut fuel pump on 1996 gs MAF?
- Some pics of my car...
- In young life with an 1st Gen.
- my 1st gen.
- sc400 12 disc cd changer compatible?
- This is who I am LMAO
- what i did last night
- Engine misfire after engine wash
- Shop recommendation near Seattle for Coilover Instal?
- repair or sell?
- crank no start issue
- engine codes ?????
- Problem starting must jiggle gear shift
- Project: headlight Mod: version 2
- Bye Bye First Gen!
- Grille and headlight mod
- good and reasonable coilover???
- Swapping ist generation engine and tranny to twin turbo...
- Rant...NNNYYYAAAA!!!
- gs300 batter light
- sc300 shifter
- Headlight cleaning
- Problem removing headlight housing
- some exhaust help please...
- Bored on a Sunday afternoon.. 1GS + 2GS
- changing dashboard lights to LED
- 93-95 tailights
- Junction headrest
- car vibrating inbetween 20' and 40' miles mph
- HKS Hi-power or Dual Exhaust
- changing steering wheel
- doin a 2jzgte swap..need help on parts..krasier,kene,anyone!!
- More ideas? Come give your input.
- Fs: Jdm gs300 visors
- turbos
- Only modified JZS147 in Colorado?
- Window help Please!
- Fixng the needle outage problem...
- battery drainage issue
- Pic Request (if possible) 245/35/20 on 9.5 wheel
- How much do you love your JZS147?
- power steering pump question
- lug nuts question
- GS 400 amp question
- What turbo is neccessary for this?
- need help with speedometer
- Front bumper help!!!
- Supra 6sp LSD in GS300 pumpkin?
- Sliding around in the Lex.
- bored just some pics
- Serpentine belt install
- 02 sensor gte swap
- SC430 Wheels
- Driftmotion's SS braided PS line fits our cars!!!
- 1995 GS300 Ecu needs to be reset after high revs????
- Gas milage
- power steering problems
- VPC/SAFC Combo with Aristo ECU?
- Anyone interested in a RHD Aristo in the US?..Cause I have one...
- Feels weird
- Who knows what size battery does our master transponder key take?
- Merry Christmass to meeeee
- Cupholder part number?
- Back to square one... Hmmm...
- I'm thinking about getting 20x10" rims for the rear.
- gs exhaust interchangeable between 1st and 2nd generations?
- what can i do with my engine
- looking to pointers on 2jzgte swap
- Been Dancing around posting this...
- why doesnt my temp gauge work
- what size are the fog lights on 1993 gs
- dadude
- Will a cressida radiator fit the jzs147?
- how much does a 2jzgte swapped gs300 sell for?
- joe and mel
- Should probably stay away from VIP...
- wiring harness???
- HEY CL! DOes anybody know how to change the rear bearings?
- Slow Cranking start
- Chaser4lif Gs300(2jzgte)
- Member Into - Pics & Problems
- the dude (wants to add cold air or other performance stuff)
- 93 gs..what can i do
- Just some pics. I got bored Part 2
- swaping interior
- Getting new headlights and tail-lights by JoTech??
- Needles, Needles, Needles!!!!
- 1GS from the 808
- For the guy asking for 22's...
- My 95 GS3 Lowest & Loudest 1st gen in Bk
- Please Help!!! Driver & Passanger weatherstrip seal and trim replacement
- Brake pad 'clap' after MKIV front brake swap
- what is the bulb size for the dash lights?rpm's,speedometer,etc
- Electrical issue? Need help/suggestions
- Name that wheel
- Don't know why the 1st is not more popular!
- FYI on Run flats
- 94 GS300 header?????? which one....
- Windshield Wiper help!
