why doesnt my temp gauge work
Old Nov 4, 2010 | 04:39 PM
aceboogie6's Avatar
aceboogie6
Default why doesnt my temp gauge work
i checked the fuse. i dont kno what it could be..i can drive for like 30 min and it still wont move and car sometimes over heats??could it be the thermostat
Old Nov 4, 2010 | 07:22 PM
KingpiN.SC's Avatar
KingpiN.SC
Could be a bad needle motor.. Does it ever move at all?
Old Nov 4, 2010 | 08:57 PM
aceboogie6's Avatar
aceboogie6
it budges a lil bit when i turn the car on/off.Could it be somethin with the therm? the car was sittin 4 a while..could it be stuck
Old Nov 4, 2010 | 10:56 PM
KingpiN.SC's Avatar
KingpiN.SC
Not really, the needle would still move. If you were in my area, I'd throw my cluster in there to see if the needle motor was the culprit. You could try asking around to see if anyone is willing to. It is extremely easy to remove the cluster.
Old Nov 5, 2010 | 10:04 AM
aceboogie6's Avatar
aceboogie6
alright so the mechanic just told me its the wiring..he said the wires from the harness are all over the place..i guess the person that put my engine in did a sloppy job..but how do i fix that
Old Nov 5, 2010 | 10:18 AM
link13's Avatar
link13
If the car sometimes overheats, you've got an additional problem that could be the thermostat or quite a few other things depending on what other symptoms there are.
Old Nov 5, 2010 | 10:23 AM
aceboogie6's Avatar
aceboogie6
thats it...i just got the water pump so i kno it cant be that..
Old Nov 5, 2010 | 01:54 PM
aceboogie6's Avatar
aceboogie6
and the oil pressure light is on the oil was just changed the pressure is good..
Old Nov 5, 2010 | 02:25 PM
link13's Avatar
link13
How do you know the pressure is good?
Old Nov 5, 2010 | 02:40 PM
aceboogie6's Avatar
aceboogie6
thats what im assumming as of i just changed the oil..but i guess that doesnt mean anything huh??
Old Nov 5, 2010 | 03:58 PM
link13's Avatar
link13
No, it doesn't. You may have low oil pressure due to an issue with the oil pump, you may have a bad pressure sensor, or perhaps there's a problem with the instrument cluster. At any rate, I wouldn't recommend driving it until you get it sorted out.
Old Nov 5, 2010 | 04:29 PM
aceboogie6's Avatar
aceboogie6
alright so im goin to test all dat 2morrow.i can test the sensors with a volt tester correct??
oardila99
GX - 1st Gen (2003-2009)
Mar 18, 2018 05:02 PM
etcortez
IS - 1st Gen (2001-2005)
Aug 8, 2013 05:16 PM
bighead222
Mar 3, 2012 08:29 PM
socalturbo
Jan 2, 2010 12:27 PM
redhanded7
Dec 10, 2007 10:26 PM
