View Full Version : Suspension and Brakes
- Are the Tanabe NF210 drops in front and back even or uneven?
- LS400 brakes on SC400 question!!!
- Eibach Pro Kit + Tokico (HP) blues -- need new bump stops or need cutting?
- Need help finding a Bolt/ part number
- New Supra Calipers/Rotors
- Does this look like a sticking caliper or something else?
- Shudder under braking
- clutch swapping
- another coilover question
- my first real "help" thread (brakes and struts)
- Got an aftermarket Big brake kit and your wheels won’t fit. DYI
- ebay cross bar? yay or nay
- Tanabe NF210 or Eibach Pro Kit?
- Ball Joint Boot
- Best prices on Tokico shocks?
- 3rd alignment and still don't know what it is??
- What else to replace when doing springs / shocks /struts?
- Brake calipers from NAPA
- IS300 intake manifold question
- 1992 Sc400
- what to do about shocks?
- SC 300 break system
- Why do fully threaded coilovers allow adjustment by the spring perch, too?
- Lowering springs?
- Noise after replacing LCAs
- I have a brake related question
- brake fluid/flush
- TT Supra Sways
- Supra Brake Lines
- Subframe & Diff spacers- Powered by Max
- Tire size
- Show off your brake calipers design!
- Coil Spring Insulators
- MKIV/Tanabe GF210
- Steering rack good/bad?Not solid at 60+
- longer wheel studs question
- Supra LCA
- SC300 and SC400 differences
- sc300 drift setup
- List of wheels that fit TT and LS400 BBK
- tanabe sway in with energy suspention bushings installed
- lowering question?
- Stuck control arm bolt....any advice?
- A couple of pics of #2
- Tokico HP w/Espelir
- Supra TT Eibach Pro Kit springs?
- Part ID Please: Are these LS400 Calipers?
- Creaking / squeeking noise from rear. Did a search, but didn't find all the answers..
- Tightening up the Suspension?
- Got some coilovers on my new SC3
- cracked Drive Shaft Flex Disk
- Cracked rear sub frame?
- Suspension Drama
- Is Supra steering rack shorter ratio? Swappable?
- Correct Torque Values?
- How low are you on your GixxerDrew/Bilstein/Hypercoil setup?
- CL SC3-4's On which type of aftermarket suspension are YOU riding on?!
- problem with myprothane bushing kit
- NPG and Racing Gear Coilovers
- SC400 -- bought Tokico HPs...what else do I need?
- Bleeding Problem
- Need some inputs..
- On crank up Gas smoke fills the air !!!
- New Alignment and Height Adjustment
- Squeaking/clunking noise from rear suspension
- last piece of the suspension puzzle
- sc300/400 tanabe coilovers: where can i buy them???
- where to get ls400 "lexus" caliper decals
- help on a brake decision
- Dreaded rear clunk
- Calling anyone with stance gr+
- fixed warped rotors tonight / no wheel removal
- sc coilovers
- H&R Coilovers buttom out. Anyone?
- Significant difference in ride quality between Megans and GixxerDrew setup?
- upper control arms, ive searched
- >>>Ok...This should be easy for you guys<<<
- spring and shock delima?!
- soarer front calipers/pads
- new rims
- Tanabe Sustec Pro's Dilemma
- Exploded view of the rear suspension?
- need both passnger and driver side mirioes wih good glasss white
- Supra LCA. Will I notice a Difference?
- LCA help!
- LS400 brakes and no ABS
- Newest Mod!
- Serious shaking problem
- help?
- Spring Fitment
- Lowering Spring question
- Stopping wheel hop
- Need Assistance: Strut Dust boot/bellows
- about to buy my first coilovers
- Finally Lowered
- Problems After Lowering With Espiler/Tokico Setup Tire Wear and Loose Rear-end
- Help on this leak.
- Need the CL confirmation on Bilstein repair, quickly.
- I cant believer I just won!:)
- LS400 rack into SC300?
- New here to the SC community! Wondering if a TT suspension upgrade do me some good?
- New 400 Owner here with a few questions.
- Got my brakes from R1
- used coilovers ?!
- Can someone clearify this for me? TT Supra suspension (ive searched)
- Rear wheel hub nut
- Lower Control Arm Bushings - Which is front - Which is Aft?
- HKS Hipermax D Coil Overs
- Supra or SC stance coilovers?
- How do you know if you have to change out control arm bushings?
- brake question
- Suggestions for lowering/stances/
- LCA Bushing Bore Size?? Help!
- tein basic coilovers???
- What are some things to know before you buy coilovers?
- Help ,FRONT drivers side lower than passenger by a inch, NOT COILOVER settings
- End links / stabilizer bar links removal
- sway bar question
- ??? bout rods
- looking for a front swaybar
- Adjusting the parking brake
- Pondering New Suspension
- New Daizen Steering Rack Bushing install (2010)
- Quick question about TT suspension
- bc coilovers here...
- WTF, my Hyperco spring cracked?!
- How the Ride with Tom's Coilovers?
- Another LS brake swap
- hammering the shock tower
- hey help with suspension on 400
- How do I maintain my suspension?
- Supra suspension on sc400
- mk3 rear coilovers? anyone have luck getting them on?
- Adjustable traction rod question and some other things worth mentioning.
- supra TT sway bar problem!
- Where to buy TT rotors-factry/slotted/drilled
- 92 SC300 Front End Rebuild Questions
- Is there anything better than Gixxer Drew for the money?
- HELP! Rear UCA REinstall nightmare!
- Another LS400 brake upgrade with pretty pictures
- Eibach Springs and Kyb Agx Struts - Possible buy
- planning for Targa - suspension advice
- tire size
- Master Cylinder...which one?
- Some questions
- Crush washers for SS brake line install?
- Coilover Install Guide - Pic Heavy
- NEED QUICK REPLY - LCA Castle Nut size/pitch
- Help me decide which Coilovers I should use
- LS400 brakes
- Factory Alignment Specs for 97 SC300?
- Need just a simple strut/shock/spring answer please
- help with tein ss all advice appreciated
- Coilover Decision
- TRD pads, rotors, braided lines and painted calipers
- MK4 TT Struts install HELP!!!
- Problems with H&R Coilovers?
- calipers semi loaded?
- SC300 parking brake rebuild kit... ever seen one?
- No more screeching in the wheel but,now....
- I'm starting to hear a fluttering sound on the passerger side..
- failed my inspection!
- 97-00 Control Arm Bushings
- brake light
- Are Stance Coilovers fully or partially threaded?
- Are Stance Coilover fully or partially threaded?
- Please HELP Stuck on LS4 Brake Install
- best coilover to go low without bottoming out.
- Looking for: Stock sc300/400 springs
- piston dust boot question
- Any SC owners on Air Suspension?
- problem power steering fluid bubble????
- Knocking, due to stripped thread.
- Brembo Front Brake Disc Part Number: BR25555 To big?
- control arm question
- Supra shocks not copatible with '92 SC300!!
- edit delete
- Sway Bar Link question
- where to buy tein ss parts?
- Steering Wheel Locking during a turn..!!??
- Lost of power during accelaration?
- LS400 Brake installed and Picture
- camber kit?
- 88Rotors----NOT for sc4's
- Quick Question and yes i searched!
- Supra Parts For Suspension
- front control arms (interchangeable?)
- Steering issue...bushings?
- Dashboard lights went out and a red "BRAKE" came up...
- Supra TT Rear rotors-cross drillled? slotted cross drilled? Standards??
- 92 sc300 steering wheel slop
- squeaking coilovers
- Stock struts/shocks gone?
- sc400 front and rear suspension noise
- Official Lexus SC Coilover Thread
- Oh God, not another clunk thread...
- NEW PARTS for my 98SC
- GAB coilovers??
- re bleed?
- Sc300 Interchangable with Mk4 Suspension?
- Will these shocks/springs work..
- Finding a reliable suspension shop
- BIG suspension problems
- swaybars help
- Vibration from Front Driver Area
- TSB:Rear Suspension - Clunking/Rattling Noise
- Finally dropped the SC400
- Supra Suspension Questions
- What I have been upto week - 3 (LSD)
- SC300/400 Diff Surgery - Repair Manual
- Outer tie rods = no alignment
- What I have been upto this week - 3 (Bushes and LSD)
- 4 piston F /1 piston R = Proportioning Valve?
- Lowering Springs? Alignment?
- HELP! Spent $2000 on suspension and far from satisified!!!
- tt brake master cylnder
- Removing my front brake shims
- how low are you?????
- will 225/60/16 tires rub???
- tein, bilstein, what does "tein" mean?
- "Clunk" noise when backing up
- Looking to replace all rotor discs and brake pads
- Looking to lower my SC
- Eibach Pro Kit Spring Rates?
- Suspension issues? I'm burning through tires like a hippy's baggie.
- Will these Fit my car?
- rack and pinion poop up on me OPTIONS
- Quick question! Do our front strut mounts contain bearings?!
- polyurethane trans, engine, subframe and diff mounts/bushings for soarer
- Worried about lowering..
- Will Supra bushings fit SC control arms?
- ABS after 1jz swap
- so my inner tie rods are shot...
- Are TT springs and struts compatible with my 99?
- Have searched - utterly confused
- Has any one ever heard of these these before???
- IN BAD BAD shape...
- Big brake kit
- Having hard time removing the front struts need opinions
- Tt supra sway bars
- coils and struts
- need your opinions best aftermarket shock
- My LS400 Calipers with irotors Installation Not 56k Safe
- Car feels out of balance at 60mph but they were just done...
- Question about Supra Shocks on a Sc300
- Supra TT BBK, good deal or not?
- ABS Sensor Removal & Install
- Ball Joint taper.. 7 or 10 degrees?
- lower control arm bushings
- Steering shaft clunking when going over bumps???
