View Full Version : SC400 / 300 Classifieds
- GA FS 92-94 SC400 Tail lights
- OH wtb sc300 door harness
- GA Beech Performance 7M IAC flange
- CA wtb w58 tranny
- CA 2jz Boostlogic Crank Pulley
- IL FS 92 SC300/400 airbag tan
- CA Chrome interior door handles--driver and passenger side
- CA FS: Black 97+ door moldings
- 97 and up lexus sc front bumper
- FL ngk wideband w/ sensor 115 shipped!
- NV WTB: Soarer Griffin emblem
- FL HKS Coilovers/ Blitz nur Spec
- IL wtb 5 speed cluster or cluster face only
- MD HKS F-Con V Pro 3.2
- MI WTB: 97+ Door Moldings
- FL WTB Passenger door lock assembly
- TX WTB R154 2JZ bell housing and 1JZ flywheel
- MD WTB. Low beam dust caps
- FL Timing belt, pulleys, clutch,cams, fuel pump
- IN Wanted a Battery Tray
- TX WTB: Driver's Side Window Interior Trim
- AZ FS: Driftmotion Rebuilt 1990 Toyota R154 Transmission
- FL wtb black door panel
- NY WTB: OEM SC400 16" Chrome
- MD Parting out 93 sc300 and 95 sc300
- FL FS: 2jzgte to sc300 PNP harness
- IL WTB: Black OEM Supra TT front seats
- TX Bnib Pop touchscreen Climate control and rear sump oil pan.
- CA Custom 3" Mandrel Bent Straight pipe exhaust w/ 4"tip
- OR WTB: 97+ grill, moldings, fogs, highbeams
- OH FS OEM Springs and Struts
- VA Ceramic 1.00 A/R Divided T4 housing - Fits Precision 6265 or 6765 exhaust wheel
- TX I'm looking for a oem 97 and up bumper!
- TX hks dragger, 2jzge drewgo manifold, bw s366
- CA WTB 97+ SC300/SC400 Front bumper and sides
- CA WTB : 1UZFE Crank Pulley - Harmonic Balancer
- NJ Wtb1997 Sc400 Differential
- CA wtb: complete ac unit with all lines
- NY WTB: Cheap stock Sc400 intake box
- CA F/S Titan Motorsports Billet Tensioner 2JZ SF BAYAERA
- PA WTB Coilovers for 1998 sc400
- CA wtb: 2jzgte w/ r154 flywheel
- AZ FS: Southbend Feramic Clutch Kit for Toyota R154
- CA Fs: Full Black Interior
- AL Fujitsubu Catback,LS400 Calipers, Supra TT Pump, Buddy Club Seat Rails,Fenders
- NV FS: 98 cluster and 98 gated shifter with ash trey
- NJ WTB stock 1jz blow off valve or...
- CAN-Toronto Engine Undertray Set - 2 pieces
- CA BC Racing Extreme Low Coilovers
- TX Wtb: 2jz crank pulley/harmonic balancer
- NY FS: 97+ tails and skirts, Supra TT parts, Nak, steering wheel, shifter, etc
- FL swap harness dr tweekd
- CO ODB1 Aristo 2jzgte ecu and 97 Supra 2jzge 5spd ecu
- FL WTB black driver door panel need it ASAP
- PA WTB: Lower door trim panel....Any color
- MD WTB: supra tt auto differential
- CA 97+ door moldings, black door panel, trunk 92-96 spoiler, Aristo 3inch downpipe
- CA JIC Magic Twin Stainless Steel Cat-Back Exhaust: 92-00 SC300 - $800
- AL AEM v2 and alot of misc parts
- NY FS Black 3 Spoke Steering Wheel
- FL Getrag
- TX Complete W58 Swap, Front and rear control arms (Prothane), Misc other parts
- CA Fiberglass AC Bumper & Black Grill
- GA Steering Wheel Tilt / Up & Down Motors , Rear Sump Oil Pan
- CAN-Other WTB black door panel's & window trim's
- CA FS:Dark gray steering wheel with woodgrain
- TX FS/FT: XS-Power, TiAL, RC, HKS
- CA sc300 sc400 door panels
- FL Garage sale:Rear sump oil pan, Greddy bov
- TX Start Up Prob.
- MD W58 w/ 2J Bellhousing
- TX WTB 2jz engine mount brackets for sc300
- VA web w58, r154 or auto trans
- CA HKS hi power universal
- CA BNIB uas air kit -SoCal
- CA WTB Miscellaneous Parts
- MI WTB: Power Steering Reservoir
- TX WTB: 97 and up oem front bumper lexus sc 300/400
- PA WTB: Racing Seat Brackets Driver and Passenger
- CA 1992 Lexus SC300/400 Tail lights
- MA SC300/400 Red 97+ Spoiler
- GA WTB sc400 dash cluster tach and speedo needles
- CA Yakima roof rack(2 bike attach, snowboard attach,fairing)
- AR Choice Sc400 parts for sale
- TX 2JZ-GE Motors, Bosch 044 Fuel System, GTE Head, Rear Bumper, Shocks, GS300 Harness
- IL TT Supra LCA's
- International FS: Soarer Side Indicators/Markers
- CA Left over parts
- FL Duraflex V-Speed Body Kit
- NY 1997 lexus black on black sc300 parts
- FL FS JDM Amber Side Markets
- NY WTB: Clutch pedal assembly & clutch master cylinder
- CAN-Other WTB: 8" subwoofer mounting bracket
- TN wtb sc400 chrome rim
- FL 97 alternator for sale
- TX WTT: looking for treadstone na-t manifold
- CAN-Vancouver WTB: Corvette caliper brackets
- CA SC400/300 Tan Floor Mats
- FL 1UZFE engine cover (free)
- CO Swap for free
- FL WTB 1JZ Flywheel
- FL WTB:W58 in central florida
- WI A LOT of 2JZ parts for sale GTE AND GE
- FL f/s the coveted Daizen sway bar set
- FL 97 Foglights for sale
- FL 97 sides, Black Carpet, Black door panels and more
- CA 1jzgte ecu connectors
- VA wtb oem pioneer head unit
- FL FS: Supra TT Brakes & Wheels (Local Pickup Central Florida)
- CA FS: 1996 Black Onyx front bumper w/fogs
- NY WTB: 97+ LEXUS SC Front Bumper UNDAMAGED
- FL 94 and below tail light wiring harness for aftermarket lights
- AZ wtb function over form suspension: need less body roll
- IN WTB: Black Seatbelts
- TX WTB: Complete SC400 Drive Shaft (inc. output flange and donut)
- GA Full 2JZGE Swap from 94 sc300 108k miles
- FL wtb window regulator 95 sc400
- CA WTB: SC3/400 cluster needles white or red
- FL WTB: JDM 2JZ-GTE VVTI Throttle Body
- FL 95-96 tailights with harness
- MD wtb aem v2 for 2jzgte and 1jz rail and injectors
- CA WANTED:1998+SC400 air box
- GA Bosch 750cc top feed injectors
- NY 92 sc300 Tailight pair with harness
- MD Low bem round dust cover
- CA 97+ clean black side lower door moldin "SF bayarea"
- CO 2jzge W58 bellhousing and flywheel
- AZ FS: OEM Toyota 1JZ/2JZ R154 Bellhousing
- AZ FS: Marlin Crawler/Driftmotion R154 Internals
- CAN-Toronto Lots of Goodies- Full 93 Sc400 Part out !!!
- AZ FS: Precision Turbo 46mm Wastegate
- MO WTB Sunroof Garnish/Trim (Gray)
- AZ FS: 1987Toyota Supra Turbo MKIII R154 Transmission
- MI WTS: GReddy Emanage Ultimate
- MN 1jz 11mm fuel rail
- CA WTB:1JZ/2JZ crank pulley - Harmonic Balancer
- CA FS: 2JZ Eagle H-beam Rods
- CA FS: SC400 Radiator Hoses (BNIB)
- CA WTB: 98+air box
- WA WTB: SC400 Shifter attatchment
- CAN-Other WTB mint front seats
- TX Wtb stall convertor for auto tt transmission
- TN WTB OEM SC400 lip
- NY FS: 97 Pass Tailight with harness
- FL 97 SC300 Mufflers
- CA WTB: 98+air intake SC400
- FL f/s 1997 fogs , glass highbeams , aeromotive -10an sized fuel filter
- PA WTB OEM 5 spd handle & 98+ ash tray lid
- CA >>>>BLACK SC300/400 OEM Steering Wheel w/ AIRBAG<<<<
- CA bunch of spare parts fs
- VA FS: TT valve covers spark plug cover and oil cap
- IL WTB 97+ passenger side Tail Light lens
- IL FS 92 SC400 Tail Lights, great condition
- International WTB: fuel pump & p/s pump
- CA FS: 97+ fog lights complete with harness connector
- FL Custom Upgraded 1jz Twin kit
- MD FS: 2JZ-GE engine partout/550cc Injectors/rail/Resistor box/OEM springs/Air bag/ Misc
- IL Eibach springs SC setup and KYB shocks
- IL KYB AGX Shocks with Eibach springs from Supra
- NJ WTB exhaust hangers left and right side
- NY WTB 97+ Lexus SC300/400 Side skirts
- CA 3" inch dual exhaust tips for sale
- NV wtb: spruce great door panels and window switches
- KY WTB R154 shift
- NY FS: Inside Door Handles
- FL '92 diff/ driveshaft/ body kit & other parts
- NY JDM SUPRA TT uncut engine harness $230
- CA my 3.92 rear end for your 4.27 or higher
- CA FS: GT4202 Polished/ceramic coated NEED GONE!
- WI WTB: Alternator for 94sc300
- FL FS: 97+ grille
- International 97 SC400 Nakamichi Amp
- CA JZ Front Sump Oil Pan Assembly and Dip Stick - Spring Cleaning
- PA WTB: OEM 5 Shift Knob
- MO 1-2jz REAR SUMP oil pan/assmbly
- IL WTB: Cup Holder (The one between shifter and arm rest)
- FL WTB: Foglights for 97 SC300
- CA 92-96 Wise Sports Style Front Lip Spoiler
- TX MISC tan interior pieces
- AL Abandon Project Sale! AEM EMS, Dual Fuel Pumps, 1000cc Coilpacks Turbo Kit, Carbing
- GA (FS)Full 1jz swap
- NC WTB: W58 Speed Sensor
- WA Need a working IACV for 1jz
- AZ 650cc sard injectors 1jz $500
- IL 99 side skirts silver illinois pickup 250
- FL wtb gauge cluster
- TX wtb LCD screen
- CA Black cloth Supra seats $300 obo
- CA FS: Vertex widebody front fenders (+25mm) off of Ueno's personal Soarer
- OH wtb: s366 turbo
- TX WTB 2jzge motor set
- CA FS LS400 4 piston calipers - $120 - 91770
- GA WTB: Driver's Front Fender in Teal Mist Metallic
- NY WTB stock rubber intake, passide door handle
- CA Open box 1jz vvti power fc L-jet (new)
- TX WTB Passenger lower door panel
- CA interested in 5 speed swap parts
- TX Nakamichi amp plus Changer
- CA WTB: 97 Front Bumper and Head Lights
- OH custom trunk audio box with subs
- OH black euro tail lights 95-00
- CA 1996 CLEAN manual black interior with s2000 seats mounted
- FL WTB SC300 or SC400 Shell
- NY WTB Black Driver Door Hinge
- CO FS: Supra TT Flywheel
- GA WTB Door Handle and cables
- NY FS: 1997 SC400 Nak Amp
- LA WTB: exterior lower door molding
- FL 97 Gauge Cluster
- NY FS: Megan Street LP Coilovers
- NY FS: Apexi SAFC Neo
- CAN-Toronto WTB SC400 Transmission
- IL WTB 92 OEM lip, 97+ sides
- IN Interior pieces, black / tan
- need 1992-1994 sc300 5 speed shifter
- KS SC300/Aristo Parts
- PA WTB: lower door panel trim outside
- NC WTB: sc300/5 speed supra stock flywheel
- CO AEM FIC-8 $590 shipped
- NY WTB Exterior Window Trim
- WA WTB need shift boot
- CA (new) auto couture body kit
- CA 97+ front bumper with fogs and grill
- TX A/C and Volume Control Knob assembly with Hazard-Black Color
- TX 1999 Gated Auto Shifter for Sale/ Wood ash tray for sale
- TX 2jzgte xs power turbo manifold
- WTB: 1jz/2jz bellhousing and/or door panels for my sc
- CA vertex bumper
- WA WTB: 2JZ-GTE VVTI head
- AL WTB: SC300 fan shroud
- TX 2jzgte vvti MAF $165 shipped lower 48
- IA CX Racing Coilovers Brand New
- CA Brand new Auto Couture body kit, never mounted
- AZ FS: 1998 Temperature Climate Control Volume / Temp Knob Assembly
- CA Brand new Auto Couture body kit (1991-1996) - pick up only
- MO Injen CAI W/ MAF And 5 Speed ECU
- NV 95-96 taillights need gone 150 shipped
- MD WTB: 3" Downpipe and midpipe
- NY wtb 2jz th400 converter
- TX wtb w58 or r154
- OH FS: PowerHouse Racing Fuel Rail Kit Anodized Black (Brand New) 2JZGTE
- CA FS : JDM aristo 2jzgte engine harness
- CA Rep Body Kit with 92 spoiler
- CA FS : Injen Cold Intake SC300
- CA WTB Front Lower Control Arm Bushings
- FL FS: OEM 1JZ, 2JZGE, 2JZGTE, R154 Parts & Spoiler MORE *~*BESTOFFER*~*
- MD WTB MK3 Front Driveshaft
- VA FS: NA-t TT ECU Mod parts
- TX Greddy Profec B Spec 2 Boost Controller
- FL Bosch EV-1 14mm 1000CC Fuel Injectors with pigtails CHEAP
