View Full Version : SC400 / 300 Classifieds
- NY FS: Garrett T67, CF wing, 98 steering wheel, AEM FIC, 2jz vvti parts, injectors etc..
- FL FS: 2JZ-GTE coils, crank pulley, BL downpipe
- CA WTB CD MAgazine For 19995 SC400
- FL fs: tan carpet
- CA FS: Gas Lid, Fogs, Airbox, Window Trims, Visors, Seat Button, Knobs, Covers
- FL Xs power turbo kit brand new PICK UP ONLY
- CA WTB : Vertex or Origin front fenders
- IN WTB 1JZ Idle air control
- OR wtb: 5 speed gauge cluster with working needles
- CA TRD frames, Toyota emblem, CF E-Brake, Grenade Shifter, Custom Cam Cover.
- DC wtb any front bumper pref 97
- WI Do- luck Stb
- IL FS: HKS 248 Camshafts **CHEAP**
- TX WTB- W58 flywheel
- WI WTB: passenger side mirror fixture
- CA WTB : Front Passanger White Quater Panel
- CA WTB: Fuel Pump Controller
- CA WTB: center carrier bearing and transmission mount for 5spd
- FL Wtb: a few misc interior peices
- FL 92 lexus sc300/95 toyota soarer parts
- MA Needed Rear Calipers for SC300
- CA WTB:Bulb Assembly for SC300 Side Maker Light
- FL wtb SC300 driveshaft for manual trans
- wtb SC300 driveshaft for manual trans? ASAP
- CA Wtb used fender dwp
- WI IMF V8 headers
- CA FS: Tial external wastegate
- NC wtb: jdm 2jzgte harness
- WI custom sprayed front Srtut tower bar
- NY FS: 1jz parts cheap
- AL WTB: Passenger side vent assembly
- FL WTB: Manual SC300 Driveshaft ASAP
- IL wtb: front crossmember
- NY Garrett dbb T67 turbo
- CA WTB: W58 or R154 tranny
- TN FS: JDM 6 speed 2JZGTE ECU and JZ-R154 Bellhousing
- WI working climate control
- MN WTB Gas fuel door cover and Driver Side Inner door panel
- TX Stock OEM W58 Clutch (pressure plate and disk)
- FL WTB sc 300 fender pass-side
- NY Brand New TT denso Fuel pump
- AZ 1jz A/T soarer/chaser ecu for sale!!!!!!!!!!
- FL WTB - '93 SC400 AC Compressor
- PA FS: Eibach Pro Spring for SC400
- MD FS: Headunit and CD Changer
- TX WTB: SC300 Power Steering Pump
- IN 96 sc300 oem trunk hood and spolier
- FL F/S mkiv tan seats
- GA wtb: brake lamp failure module for 95 sc300
- PA WTB: RMM 3" downpipe JZA80
- HI WTB 92-94 maf sensor
- CA FS: JIC Magic Strut Tower Bar
- MA LS400 Rotors
- PA WTB- LIP for front 97+bumper
- CA 95-96 taillights ***SUPER CHEAP!!!***
- CA FS: 92 Tails, 12'' subwoofer
- NJ wtb key fob transponder
- CA 2jzge MT ECU, 2jzge NA MAF, 6 speed tach, greddy turbo timer, smic, more
- NY TT resistor pack
- CA Adjustable Front Strut Bar
- CA wtb 92 sc400 intake
- MN JZA70 1jz partout. tranny stuff gone
- VA WTB: lower control arms
- CA 2JZ-GE Motor w/ most (if not all) of the sensors
- MD 1998 sc300 VVTI swap and turbo manifolds ARP
- FL FS: GT42, HKS vpc / gcc combo
- NY 1998 NA supra VVTI coil packs and wires
- IL Fog Lights and high beams, clear and in good condition
- MD FS: Black Glovebox from 97 SC300 *$75 shipped obo*
- NJ WTB some stock parts of SC
- CA **FS: 97+ Front/Sides/Rear/Extensions/Grille/etc.****
- FL GE motor, cruise control, BL 2.5 MM HG, NA PS Resevoir + more
- MI WTB: Stock Antenna setup
- UT WTB: TPS sensor
- WA cusco strut bar
- CA FS: miscellaneous SC300/SC400 parts
- NV WTB: Driver Door Panel (Seriously!)
- MS Wtb: 1jz alternator asap!!!!!!!!!!
- CA FS: eBay lights, headlights and tails
- WI complete front brake kit
- MN WTB:97+Door Moldings
- CA Fs: Hks fcd (std)
- FL 2jz alternator 60$ shipped
- CA FS/FT Supra seats, G35 wheels, ls400 BBK trade for stock. SFO
- WI Solid Shifter Bushings and EGR Block Off Plates
- CA wtb. jic magic kit sides and rear only
- MN WTB: Flasher for 92 SC400
- CA FS : Blown hood struts
- FL 1jz going single part out
- WI Rota d2's 18x9 +30 5x114.3 (sp1 knock offs)
- MD WTB/WTT: Spoilerless White Trunk for 92-00 SC
- FL Brand new Toyota 2jzgte water pump
- CA WTB front bumper support
- NY 2JZ-GTE Stock Twins
- IN Some SC300 Parts For Sale
- CA MKIV Supra Silver TT Wheels + Newer Kuhmos!
- CAN-Toronto Aristo ECU
- CT WTB 97+ fromt lip
- CA FS: 98 SC300 Spoiler, Cluster, Gated Shifter More
- TX Engine cover
- NY FS:720cc Greddy injectors
- IL Complete Passenger side door part out
- NC WTB SOARER ECU (manual trans) or auto
- GA FS: 97+ Front bumper, FP ecu
- WI Black Supra Steering Wheel, Defi EGT, Tial 44mm WG
- NY WTB: SC300 throttle body parts
- IL Ls400 Brake set, Megan Coilovers, Rear lower control arms
- CA Fs: Safc2 blue
- CO WTB 1zj single turbo manifold
- CA WTB: 95-96 front bumper w/ fogs and grill
- VA FS: 97+ Rear bumper + extension
- NC WTB: 1jZ/2JZ map sensor
- AZ FS: SC300/400 OEM trunk carpet ** Black **
- CA sds standalone ignition system so cal !!!!!top of the line
- FL wtb non turbo radiator shroud
- CA WTB used alternator
- FL 45k Usdm twins,Hks Sld,Greddy Egt
- CA For Sale Used SC400 K&N Air Filter $35
- AL wtb:92-96 throttle cable
- CA FS: (1) 97+ Right Side Fog Light
- NY Fs:hks fuel rail
- NY WTT: Super RARE ZEE's wangan wing for GT wing
- CA WTT: My homemaid Homelink visor for your clean visor
- MD FS: WDP Debadged Rear Bumper from 92 SC300 $70 obo
- NY 720cc Greddy Injectors
- IL WTB Front Bumper Cover SC300
- CA WTB: rear black OEM seats
- GA Project Sale-A-Thon!!
- FL WTB 1jz auto ECU & ignitor
- WA WTB: 92 SC400 driver's side axle shaft
- CA 92-94 OEM lip
- CA wtb garrett gt35 smaller hotside .63 i have an .82
- HI Wtb: New set of sc300 motor mounts
- CA FS: Front Lower Control Arms w/ Energy Suspension Ball Joint Bushings
- VA FS:97+ fog lights
- VA FS: 97+ pass taillight cheap! (broken)
- CA FS- Nardi Classic
- FL FS: W58 Trans,Clutch Pedal Assembly,Front Driveshaft and more stuff FOR SALE
- TX WTB: MAFS (mass air flow sensor) for 1992 SC400 in working condition
- NC 2JZ-GE ECU/Supra MK3 M/T Driveshaft and other SC parts
- FL WTB shine rear bumper and sides
- FL WTB: oem/toyota starter for sc300
- GA LS400 Brakes/Rotors Turbo FMIC Parts and leftover Sc300 parts
- CA WTB: Shine Auto front bumper and 97+ passenger tail light
- CO WTB (known good) 92 sc300 fuel injectors
- CA TW: gt3071r 2jzge turbo kit + EXTRAS!!!!
- VA FS: L-shape plastics
- IL WTB:Tunk Deck, 97 Front Bumper, Passenger highbeam and more
- CA WTB 1992 Lexus SC300 ECU
- CA Wtb grey seatbelt
- IN 96 2jzge machined short block
- MD f/s 1jz parts
- IL Oem Lexus sc cd changer
- IL Sc 300 or 400 Headlights 2 sets
- IN oem crank pulley good shape
- GA wtb:yellow box brake failure module with pigtails for 95 sc300
- CA WTB : 15mm and 20mm spacers
- IL fs: traction control unit,intercooler,4" intake pipe
- TX (WTB) SC300 inside door handles..
- CA FS: Black OEM style spoiler and pre 97 rear bumper
- NY FS: HKS mushroom air filter, HKS oil cap, black leather console and door rests.
- TX FS/ Custom Rear Strut Tower bar for SC's
- MA WTB: Left/driver's side taillight 97-00
- MN WTB:97+Oem Side Skirts & Rear Bumper
- NY FS: Goodridge G-Stop Brakeline Kit Stainless Steel
- CA FS: Left headlight and Black 92-96 spoiler w/ 3rd light
- NV WTB: stance or megan coilovers
- TX (((( Authentic Apexi BOV )))))
- FL Maf sensors, V8 and regular + stock GE motor parts
- FL For Sale: JDM Supra 6 speed TT ECU, MAP sensor, and brand new SPEC clutch
- NC FS: 1UZFE SC400 engine w/ trans $400
- FL Need sc300 manual driveshaft or mk3 supra front section
- CA WTB: Vertex side fenders vented 25mm and Origin roof spoiler
- FL HKS HiPower Exhaust (NEED IT SOLD TONIGHT!)
- NJ "Stage 2" setup for sale.... for NA-T's
- KS Bunch of stuff left to sell Everything is OBO
- IL Sc 300 or 400 Good Trunk shocks $35 shipped.
- FL us spec TT 2JZ ECU
- TX ((((((( 2JZGTE SPARK PLUG Cover )))))
- CA WTB 97+ door moldings
- FL WTB 97 cd Changer!
- IN 2jzge complete gasket kit topand bottem end
- GA WTB: 1JZGTE TPS Plug
- MN 2jzge Intake Plenum + throttle body
- CA Please read classified forum rules
- FL WTB: Passenger Headlight
- CA WTB: power steering pressure hose
- FL WTB Black Driver Door Panel
- CA FS: Spoiler-less trunk PICKUP ONLY $100
- FS - USDM MKIV Supra TT Fuel System, ECU, MAF, Camshafts - $700 obo - Chicago area
- TX WTB: Sc300 5 speed driveshaft
- FL WTB 1jz valve cover gasket
- CA OEM 1UZ-FE ECU - 1992 - $100 shipped
- CA WTB : Ignition Control Module
- CA Brand new 97 grill... $60
- TX WTB: 97+ passenger headlight must be mint
- CA cannards
- CA Sc300 Support Radiator Cover
- NY WTB: PS Pump Reservoir
- MA Wtt pearl white 97 rear spoiler
- FL WTB: 95-96 Passenger Tail Lght (Only Need Outer Lens)
- IL WTB 97+ Grill and Fogs
- NY wtb 2jzge Na-T parts
- TX WTB: SC300 cruise cont. OR auto trans cable...
- MO WTB: Mint 93-96 dash wood trim and passenger's side vent.
- VA Wtb: differential spider gears assembly
- CA sfbay; MK4 TT supra Megan racing downpipe
- FL Gauges, lights, steering wheels, front bumper wise sport lip.. plus more..
- CA I have a set of sc400 custom JDM dual exaust for trade plus cash
- MD WTB: 2 Vents Above Climate Control
- CA **FS: Mint 92-95 OEM Tail Lights**
- KS Decent parts
- VA WTB: Stance coilovers
- OH WTB: flywheel
- FL Looking to buy 2 front fenders
- IL sc300 parts
- CA wtb: clutch fan and throttle cable
- CA FS: Tan Interior Pieces - L/R Rear Window Trim, Tan Visors, Center Leather Trim
- PA FS 99-00 Black Air Bag
- WI Ls bbk
- WA FS: Stance GR+ Coilovers and TT Supra Endlinks
- WA NEW: Carbonetics LSD w/ lsd fluid
- AZ FS: Black interior pieces: upper window trims, center console
- MI FS:SC400 Tensioner, Idler pulley & NAK CD magazine merged
- MI FS: SC400 P/S Pump and hoses
- NE WTB: Drivers Side window regulator
- CA *WTB: 92 Compatible SC400 MAF*
- MA WTB: 92-94 parts
- FL WTB 2JZ GTE OEM pistons
- CA WTB SC W58 shifter
- CA 1993 sc300 2JZGE motor parts - leftovers
- FL WTB 97 oem side skirts and rear lip
- NY SC300 Steering wheel, tilt motors, ignition lock, headlight+wiper switches
- FL WTB old key case
- AZ FS: NRG 2.0 Quick Release Hub black
- AZ Pioneer 12 disk changer, amplifier and sub amp
- CA WTB : Engine Lower Fuse Box cover / Fan Shroud
- CA fs: tein flex coilovers
- AZ WTB: NEW OEM Outer Tie Rods
- TX WTB/T: 1997+ SC300 header and cat.
- FL OEM Factory air box 1997 SC300
- FL FS: 1992 SC400 Factory Work Shop Manual + filters
- FL WTB:97+pass side Fog light
- NY fs:720cc greddy injectors and HKS fuel rail
- IL Sound Performance Precision turbo about 500 miles, Polished
- WI sard and hks stuff
- NY FS: 92-00 Lexus SC300 2jz OEM 5-speed Transmission swap Kit
- FL Wtb: Exhaust....duals
- MA OEM springs
- FL WTB 97+ Rear Taillights
