PDA
View Full Version : SC400 / 300 Classifieds
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139
  1. CA wtb aristo tt downpipe
  2. FL FS: 95 red tinted tail lights and muffler
  3. NY Fs: Misc parts
  4. FL gte polished intake manifold f/s
  5. CA Apexi AX75f82 2jzgte turbo kit
  6. CAN-Other Wtb: 1992 sc400 maf
  7. WA N/A-T ETS Turbo Kit!
  8. FL WTB: 5speed sc300 clutch pedal assembly
  9. FL 20" Volks Progressive TS for sale BRAND NEW!
  10. CO WTB - Stock Nakamichi AMP
  11. FL Wtb sc300 rain guards!!!!!
  12. FL FS: Tan 3 spoke steering wheel.....
  13. CA w58 5 speed conversion los angeles (can install)
  14. CA WTB: Center/Y-pipe for SC300
  15. CA WTB Carpet
  16. WI single 4 wire o2 sensor
  17. CA Sparco Milano Prestige Seat (Black Leather)
  18. FL NEED 97 + Front BUMPER
  19. CA WTB: 92-94 Tailights
  20. MD USDM 2JZ-GTE Engine Harness for OBD2 SC300 (Already Converted).
  21. TX wtt turbo for coilovers
  22. TX WTB SC400 stainless brake lines and rotors
  23. CA WTB: 2jz-ge Crank wheel/ crank timing gear
  24. CA steering wheel, control arm, driver side mirror,open diff,starter usdm cams
  25. CA Sc Tow/trailer Hitch
  26. CA SUPRA TT suspesnion/ stock sc suspesnion cheap will ship
  27. CA Brand new 92-00 lexus sc 300/400 front and rear brake pads
  28. MD FS: 1jz wit trans 600
  29. CA WTB CHEAP fan shroud
  30. NJ FS: B&M Tranny Cooler
  31. NJ FS: Complete Turbo Kit for the 2jz-ge. NA-T is right around the corner...
  32. FL HKS Twin Power DLI
  33. NY NA-Turbo parts
  34. MD FS: 94 SC300 Partout
  35. NV clutch pedal/brake pedal
  36. FL WTB: black center console
  37. CA need left cover behind steering wheel
  38. NY 95 sc400 engine,harness,ecm
  39. AL WTB obd-1 Mass Air Flow Sensor PLUG ASAP please :D
  40. IN complete r154 setup nothing needed
  41. CA OEM 1996 sc30 wheels and tires
  42. PA 97+ OEM body kit plus more
  43. VA FS: TWO Factory Nakamichi 12 Disc Changers
  44. TX Turbo parts (boost controller, etc...)
  45. NC WTB 5speed bezel and booth
  46. FL wtb clutch pedel and a slave and a master cylender
  47. NC 1992 SC300 - Blown Engine!! Help!
  48. GA WTB - Upper and Lower driver door trim, both front seat garnishes for tan interior
  49. FL WTB Soarer Engine Harness and ECU
  50. MD Fs plastic high beams like new condition
  51. CA WTB Brand New or Near Mint Used SC Headlights
  52. FL 1Jz part out,.... UPDATED
  53. CA FS oem black 5 speed shift knob
  54. FL 1993 Lexus Sc300 5spd.
  55. FL Soarer Parts! SMIC, Trans, Diff, Brakes, etc LOTS MORE
  56. CA 97-98 tail lights CHEAP!
  57. TX Greddy Shift knob for Supra TT or SC with getrag tranny
  58. CA WTB: lexus oem wheels (or TT) that clear bbk
  59. CA WTB: non-sagging driver's side door hinge
  60. WI Complete 95 LS4 BBK rotors, lines, calipers, brackets, screw, and pads
  61. VA FS: Steering Wheel, airbag, motor/trans mount
  62. GA Front clip needed, any 97/98 SC, black preferred
  63. NY Fs:1000cc delphi injectors cheap!
  64. CA FS: Brand New Carbon Hood
  65. MD Wtb uncut sc300/sc400 lexus key with remote
  66. NV WTB, stock SC suspension.
  67. TX RARE PARTS 99+ steering wheel & 97+ sun visor
  68. OK Huge sale! Look! Nos, precision turbo, hks turbo timer, momo, spal fans, more!!
  69. VA WTB: MKIV Remote Shifter Assy, Howe Racing 82870 Throwout Bearing, and more
  70. OH SC300/400 Ksport Coilovers
  71. FL FREE:Stock Sc300 mufflers
  72. TN WTB: drivers vent, arm rest insert, gauge bezel, other stock parts
  73. TX complete authentic vertex widebody = 1600
  74. TX WTB: Need W58 Parts ASAP
  75. FL WTB: center Air Vents, passenser Door Handle
  76. CA wtb reservoir tank
  77. CA WTB driver side fender
  78. CA FS: black passenger side 97-00 door molding
  79. IL looking for a project car
  80. FL 92-96 Autp Gauge Cluster Whole or Parts
  81. FL Synapse 40mm Wastegate
  82. CA PRE 97 Front Lip, Passenger side fender, oem tan steering wheel, SAFC1 CHEAP!!!!!!!
  83. UT WTB: 3 spoke tan steering wheel
  84. FL WTB : sc300 auto drive shaft, pass door, 97+ kit
  85. CA wtb sc400 driveshaft
  86. VA wtb: tan armrest driverside
  87. CA WTB 97+ front bumper
  88. UT Needed: Back Glass for '95 Lexus SC300
  89. NY I'm looking for supra TT Calipers for my SC
  90. CA FS: 1992 SC400 OEM Seats
  91. CA 1998 SC 300 Head unit
  92. MD Window regulator and actuator and control arms
  93. NV WTB: 1uz-fe VVTI
  94. AZ FS: OEM TPS Throttle Position Sensor for SC300
  95. IL F.S. Parts off my SC300. (steering wheel, ECU, spacers...)
  96. FL Unorthodox Polished Racing Cam Gears
  97. CA WTB Driver Side 1997+ Fog
  98. MD Fs black front seats
  99. NY FS:lOW MILAGE ARISTO/SUPRA TT AUTO TRANNY
  100. CA WTB Driver's side headlights from 99
  101. TX FS:MVP 2JZ-GE exhaust manifold
  102. FL Need Tan Seats, 02 Sensor, Radio Center Bezel, 97+ Foglights, Keyless Remote, BFI Mod
  103. MD HKS Drag Coilovers
  104. FL WTB driverside tan door panel
  105. GA FS:KYB Rear Struts, Custom Sub Box, and SC Heater Core.
  106. CA FS: 3 spoke steering wheels
  107. WI WTT BNIB Autopwr Ti exhuast for coilovers complete 4" with 3to4" convter
  108. FL WTB Vertex Front bumper
  109. GA FS: Polyurethane Rear Sway Bar Bushings
  110. CA FS: 97 door moldings
  111. MN working climate control FS
  112. VA 2JZ-GE and W58 5 spd
  113. MN WTB driver side exterior door handle
  114. IL WTB: Cheap SC300 project car
  115. TN Wtb r154
  116. CA FS: pre 97 Sc lip
  117. TX WTB: 2jzgte single turbo manifold
  118. CA WTB: 97+ drivers side tail light, and grill
  119. CA WTB: Lexus SC300 rear camber kit
  120. TX WTB: Passenger side fender sc400, 92-95 ?
  121. WI Free stuff: BFI ver.1 with snorkle, stock mufflers
  122. CA WTT: Bride Interior, for Black Supra seats and stock rears
  123. FL FS: stock 95 SC300 axle back exhaust
  124. LA wtb sc300 stock amp
  125. PA FS: OEM Parts - Twin-Turbo's, Taillights, Headlights, & Exhaust
  126. AR FS: JDM Stock twins
  127. FL Some Free Parts & Aftermarket and Stock Parts SC
  128. TN FS: 97 steering wheel w/ airbag
  129. TX WTB: need both front Tan Sc seat
  130. TN WTB axle back exhaust/mufflers
  131. TX '97-99 oem spoiler - black
  132. OK K&N Air Filter $35 shipped
  133. MD Wtb tial 50mm wastegate with v band/1jz manifold
  134. NY FS: GTE Valve Covers (Non VVTi)
  135. WV wtb: map ecu piggyback
  136. MA 98/99 sc air bag ecu
  137. FL WTB: 2JZ-GE Motor & W58 Transmission
  138. NY new in box Compustar Pro P2W900FMAS
  139. IL passenger tan door panel, center vents
  140. KS Full set of TT brakes, I rotors, pads and braided lines
  141. VA WTT:My 97+ Spoiler for pre 97 spoiler
  142. IN Carbing Strut tower brace F.S.
  143. FL F/S :Cheap Custom SC300 Exhaust:
  144. FL wtb soarere harness and ECU 1jzgte!
  145. IL 93 sc300 brake booster and master cylinder
  146. AR WTT: 97+ spoiler for Pre-97 spoiler
  147. CA wtb 2jzgte auto trans
  148. KY wtb 2jge in kentucky tri state area
  149. CA 97+ bumper
  150. GA WTB: 1jz spark plug cover
  151. CA 225/30/20 front tires cerritos ca
  152. LA WTB - Power Steering Pump + Possibly More
  153. MD Spec Stage 2+ Clutch Kit (Disc, PP and OEM Hardware) + Spec Lightened Flywheel.
  154. MN JZA70 1jz ecu, ac compressor, 1jz rear sump
  155. CA Sc300 93 good steering rack with ends and daizen rack mount bushings
  156. CA Front sc300 control arms with daizen bushings installed
  157. CA WTB: Passenger side Mirror.
  158. GA WTB: Tan floor mats for SC400
  159. CA FS: 95 tails cheap
  160. CA Fs: Near mint 99 passanger headlight
  161. IN 272/272 crower cams cheap
  162. NY FS: 98+ SC OEM Ashtray assy WOOD style....NICE
  163. NY FS: 98 SC400 OEM driveshaft w both couplers...PERFECT
  164. MD Mint condition headlights
  165. IL FS: AEM Adjustable Cam Gear $50 shipped/paypaled
  166. CA FS: Greddy Profec B-II Boost Controler
  167. NJ wtb 95 throttle body
  168. FL Race Car Part out TONS of parts Stock and high performance
  169. CA FS: OEM Front Lip
  170. NY FS: 92-00 SC Black E-brake boot NICE
  171. NY FS: 92-98 SC Black REAR seat upper & lower PERFECT & CLEAN
  172. NY FS: 92-00 SC Rear seatbelt buckel trim in BLACK....RARE
  173. NJ Selling AFC NEO and Innovate Wideband
  174. TX 5spd 4.08 diff,Pioneer headunit,2j timing belt ,HKSssqv etc...
  175. TX Greddy Emanage Ultimate, JZZ30 1JZ harness
  176. CA Fram Airhog air filter (reuseable)
  177. IL WTB: Pre-97 Rear Spoiler
  178. AL wtb:1jz ECU stock or modified
  179. VA four replacement needles for cluster for 60 shipped should fit 92-97 sc and gs model
  180. OH RKM SSQV Version 2 Black + CP-e adapter flange
  181. NJ wtt kei office coilovers
  182. GA Soarer motor mounts
  183. CA 99SC300 Cluster & gated shifter 4 sale.
  184. CA Stock 16' chrome Wheels & Megan Racing Supra SC300 Coilovers up for grabs.
  185. CA rear spoiler for sale.
  186. TX aristo oil sump/oil pan = 90
  187. CA Looking to buy 5Zigen Fireball Megas.
  188. TX vvti injector full set = 70
  189. TX Timing Belt Idler Pulley - 15
  190. TX 99 vvti 2jzge auto tranny - $70
  191. CA WTB: griffin emblem!
  192. CA 97+ fogs w/hids grille dwp side skirts rear bumper & extensions tan visor w/homelink
  193. OK WTB: Stock Lug Nuts for 99 SC
  194. FL Wtb: Sc4 ecu
  195. International WTB: 1997 rear tailights
  196. FL 1JZ Soarer Auto Trans +Misc Soarer Parts!
  197. WA For Sale: Huge List-Aftermarket and OEM
  198. FL Tein HA coilovers for trade(Local only at the time)
  199. International Custom Microsuede JDM SC400 interior
  200. IN 2jz block bored honed skim milled and tanked
  201. International SC400 1UZFE Vortech Supercharger set up
  202. NJ WTB:Black rear seats
  203. MD AAP TH400 tranny and Gear Vendor OD unit
  204. NJ F.S Espelir SPRINGS
  205. NY Fs:aristo tt automatic tranny
  206. FL FS: New Cs Like Short Shifter
  207. CA WTB: Headlights from 99 or 00 SC
  208. VA WTB: 92 1uz-fe
  209. PA sc300 int. parts, 1jz tanny, and more
  210. MD Mk3 r154 with driveshaft
  211. CA Innovate Xd-16 Wb BNIB
  212. MD Stock Lexus SC Wheels For Sale
  213. MD 2JZ ECU's 5 Speed/Auto 1995-1996,1997, 1999
  214. AR WTB: worn out front control arms
  215. CA WTB: 95 Tail Lights with harness and bulbs
  216. CA *DC/SSF/SF*-set of 96 OEM complete suspension
  217. CA Wtb downpipe socal
  218. TX Comeplete power steering assembly - $60
  219. TX 97-99 sc300 igniter module = $+ free shipping
  220. CA WTB: Black E-brake Handle
  221. TX Wtb hks dli
  222. MA wtb you old head lights/ tail lights
  223. PA FS/WTT Intercooler & Gauges
  224. TX WTT mkiv wheels ,twin turbo's,etc
  225. CA WTT: 750cc RC injectors for 2jzge
  226. CA 1999 Black Side Skirts, No door moldings 99 Rear Bumper!!! PICTURES!!!!
  227. CA WTB: 1jz coil packs/ boost cut defender/ shroud
  228. MD 97+ OEM SC3/4 Drivers tail light
  229. CA Socal FS: miscellaneous sc400/sc300 parts
  230. CA FS: Soarer airbag 4 spoke wheel
  231. CAN-Other WTB: driver side door latch actuator
  232. CA 1999 Lexus SC300 4 Sale
  233. CA WTB: Big Win Lip, 92-96 rear bumper, spoiler
  234. CA 1993 SC300 Front bumper(w/lights) & Rear bumper
  235. OH FS: Greddy type S
  236. CA WTB: Used Trunk Struts
  237. NC WTB Supra TT Sway Bars
  238. FL Pre 97....SC400 Lip
  239. MN WTB: Stock Pioneer sub amp
  240. NJ WTB:front end parts/windsheild/interior parts
  241. VA FS: Both headlights from 95 SC400
  242. CA WTB: LS400 BBK (calipers, rotors, SS brake lines ...)
  243. CA Complete 5sp Rear end
  244. WI aftermarket partout turbo's bov's rims tail heads soarer stuff and more
  245. CAN-Other wtb: 92 SC400 MAF
  246. CA WTB 97+ lower door moldings
  247. NY Fs:98+ vvti turbo auto tranny
  248. IN wtb valves intake and exhaust must be aftermarket need asap cash in hand
  249. CA Real Auto Couture kit for sale So Cal pick up only
  250. MD FS: 2JZ-GTE Auto Transmission
