View Full Version : SC400 / 300 Classifieds
- NY WTB: JDM 2JZGE AUTO harness
- CA wtb fireball mega exhaust
- CA 99 Front Lip
- FL rubber sc300 a/c lines,tt motor mounts w/brackets all new,rear sump drain line fiting
- CA welded diff for sale !!!
- IN C&R Racing Radiator Aluminum
- IN xs power t4 turbo manifold 2jz ge/ Aeromotive fpr w/ gauge/ R154 transmission
- FL WTB: 1jzgte exhaust manifold
- GA WTB plastic piece under auto shifter
- ME 0 mile Front Supra TT Brake setup
- CA FS: Complete Set (4 Qty, Front + Rear) Oem O2 Sensors - Denso PN 234-4211 & 234-4619
- CA oem 1993 sc300 parts for sale
- NY 97-2000 Rear Bumper with Extensions
- FL very nice cammed,low low mile, rear sump 1jzgte nicely built& fresh!!
- CAN-Vancouver WTB 97+ oem sides skirts
- FL Xspsi6 left over part out,gte parts,slicks etc etc
- NY 95-96 lexus SC taillights pair...NICE with harness
- CA BUYING: 2JZ-GE Intake Manifold
- OK WTB: SC400 Brakes (F&R) Complete Struts, Shocks, Springs (F&R)
- NV WTB: Sc400 Tan door panels and window regulators
- FL w58 Clutch kit/2JZ/1JZ/Catch Can/MSD Tach Adapter
- NV Hks Racing Adjustable wastegate 50mm/40mm
- CA gte cams,precision pt5858 ball bearing,sc3/4 to 2jzgte harness
- NC FS: Air Bag/HUB/ H&R studs
- NY Clearing out sale - lights, mirror, door handle, amp
- MO FS: 2jzGE vvti out of a 2002 Lexus IS300
- NY 92-94 fog lights
- CA Wtb r154 tranny or full swap
- CO Sc300 Sc400 Modified knuckles and tie rods
- WA Wtb: Stock springs
- NH WTB: 1jzgte head
- AL FS: Complete Bushing Kit for Front control arms
- AL FS: Fuel pump ECU SC400
- CA DDM 55 Watt Slim HID kit for SC. 6000k New
- CA FS: Crower 272 cams with lash caps 2jzge non vvti
- CO WTB:Aristo Stock Twin Turbo's
- NY wtb 550cc injector
- TX AEM v1 EMS, IAT, MAP sensor, Boost Solenoid, and AEM wideband.
- CA So Cal SC300 injectors (Cleaned, Flow Tested) New NGK spark plugs, Walbro fuel pump
- NY WTB: Suprastick
- NY wtt 2000 gs/sc black 3 spoke steering wheel
- MI WTB 97+ grill
- FL FS: new delphi 1000cc injectors
- MO Check it out!!!!
- AZ FS: 2JZ headgasket and valve stem seals $35.00
- NC FS: Door wood trim, center trim wood, etc-Cheap!
- CO Sc300 + Mk4 Supra w58's, tt mounts, Coilovers & 1jz parts
- AL FS: Complete seat belts w/o buckles
- AL WTB: Extended stud with lug nut
- GA ?? re determining 94 production date
- CA ***NEW Carbon Fiber bucket seats***
- FL WTB: MAP ECU V1,2 or 3
- FL Nice sc300 fan shroud and reman alternator!!!
- KS Eaton M90 Supercharger Setup
- TX Mint 1992 Tail lights $150 shipped
- VA WTB 92-93 Cluster Needles, WTB Climate, WTB Pioneer Radio
- NY BL DP/MP - Greddy Boost - Diff - G Force ECU
- CA Fs: Driver side glass high beam
- CA FS: MKIV Supra seats
- NY Wtb 25mm spacers
- NV wtb: t4 Turbo manifold
- NY WTB: Tan Drivers Seat Belt
- TX 2JZ-GTE VVTI 6 speed ECU
- NY FS: SC300 GATED shifter assy
- NY FS: 99 lexus SC400 interior REAR upper window trim BLACK pair cheap
- AZ 1998 Steering Wheel, Air Bag and Column Cover MINT
- TX Black passenger window switch with tan buttons!
- FL J&S Safeguard (Knock dector/safeguard) // Aristo 2jzgte ECU
- FL have a sc specfic 2jz gte harness f/s
- OH FS: Headlight pair from 1998 SC400 excellent shape
- CA Pair of good condition fenders for sale.
- CA fs so cal: soarer badges front and rear
- SC short shifter, beech performance
- CA Supra TT brake kit
- CA Gixxer Drew Bilstein setup
- TX Fs: Hks bov
- GA WTB: Front LCA's
- FL WTB: Front bumper grill for White 95 Bumper
- NY NYC: NA parts for sale
- GA Radio / CD Changer / Amplifier
- NJ FS: 1jz single turbo,mani,wastegate, 2jzge single turbo manifold
- FL WTB q45 TPS, throttle body, greddy tps adapter
- GA 1992 Sc 400 parts
- SC walbro 255-T70 turbo-SSQV(type) blow off-oil/trans cooler-New DEI exhaust wrap
- AZ FS: AN4 feed line and flange
- GA looking for someone in Atlanta
- OH Wtb rhd handbrake lever.
- CA WTB: SC 400 Front lip with brackets
- CA wtt: brand new vertex replica bumper
- PA Injen Short Ram Intake SC300 2JZGE
- CA Wtb fujin lip for 97+
- CA Fs: SoCal : Black Interior (Door panels + misc interior parts )
- LA FS: NEW Cross Drilled Rotors Front - for SC, not Sure What Else They Fit
- NJ Wanted: 95-96 tail light harness
- FL NA turbo parts fos sale
- CA fs: trd leather shift knob
- CA wtb- stock camshafts
- CA WTB: NA-T kit
- TX WTB: SC300 parts
- CA WTB: Supra TT Front Calipers
- FL FS: 95-96 Taillights!!!
- PA FS: Sc300 Transmission Crossmember
- WA WTB: SC Tan Interior Door handles
- TX FS HKS FCD, W58 flywheel & clutch, 2JZGTE -10 fuel rail, 2jzge parts, BOV and WG
- KY WTB 3 spoke steering wheel with airbag
- CA Climate Control $100
- WTB driver side rear hub assembly
- CA FS: TTC Performance 2JZGE 268 CAMs with BC Springs/retainers
- FL Wtb:97+ fogs
- CA WTB: 5 speed pedals/speed sensor/ reverse sensor
- KY WTB 97 to 99 fogs
- CA no vouch/not SC specific.
- LA FS: New Shine Auto rear CF Diffuser.
- TN WTB pass 95 sc400 window regulator
- MD Ls brakes/98-99 sc300 engine harness/98-99 perforated rear seats etc..
- NC FS: DS and PS window switch (grey) $55 shipped!
- FL Gated shifter knob,tt supra new upper rad hose
- FL 2jz AC compressor
- NY FS: many sets of 97+ side skirts and REAR bumper sets
- NY 92-96 SC300/400 flush mount spoiler NO light RARE....
- PA 1993 SC300 Front Lower Control Arms Pair $60 - Stock Springs $40
- FL Wtb: Climate Control
- CA WTB: Brake Hard Line
- CA norcal bay area wtb stock downpipe
- SC Fs 92 engine wire harness with schematic
- CA WTB black center console cup holder
- CA Obd1 sc300 to 2jz-gte engine harness
- GA Sc 400 lexus
- CA LS400 front calipers BAY AREA Cheap
- GA Parting Out 1992 Sc 400
- CO 2JZGE FFIM NA-T w/Q45 flange
- DC Good newish sc300 oem clutch fan and blade 35.00!
- CA FS: Perfect condition top black cup holder
- GA FS - Black/Gray Home link visor, 96 Fogs
- FL 97+ Trunk Wing
- IL WTB: R154 Bellhousing
- FL f s full 3 inch midpipe/catback dual exhaust system
- FL f/s new KYB GR2 shocks SC300
- FL FS: 1jzgte jzz30 Auto Trans, Twins, Harness, Downpipe
- AL wts supra tt tc and landcruiser tc
- FL FS or FT: Nakimichi Head Unit
- PA WTB: SC400 driveshaft with good carrier bearing
- CT Wanted: V8 IMF Header - New or Used
- KY WTB: Desperately need rear bumper cover
- WA WTB - 97 Tail Light (Passenger Side) & Rear Bumper small moulding piece
- NY fs: 1jzgte jza70 M/T ecu
- CA sc300 2jz 5 speed tranny
- CT WTB: Right (Passenger) Rear SC400 Caliper
- FL wtb:A/c vents or panel with vents above radio
- GA WTB 97+ grill
- CA FS: 96 tails.glass high beams
- CA Wanted: floor carpet
- NJ FS: 92-94 8k Fog light LED bulbs
- NY WTB: 2jzge auto transmission
- PA FS: 2jzGE a/t ECU
- CA Front Lip- unifinished project
- CA gte head decked ported valve job shimmed new valve seals will ship!!!!
- GA LS400 brake kit/// IMF long tube headers for 1UZ
- MD R154 MKIII Turbo Front Driveshaft
- MD 1j/2jzgte Coilpacks, Greddy Speed Cut, MSD Tach Adapter, Walbro Fuel Pump 255lph
- CA WTB- single turbo/fueling parts and r154 clutch
- CAN-Toronto Mines ecu map-ecu
- TX 1jzgte MAF for sale
- CAN-Toronto 95+ SC400 glass highbeams
- TX WTB: Valve Covers
- AZ Selling Leftover Parts
- PA Center HVAC Vent for scx00
- FL WTB Aristo 440cc Injectors!!
- NC Cup Holder, Cams, Manifold
- TX 1jz vvti t3 turbo kit complete ready to run
- TN fs new climate control lcd
- NC FS LS 400 BBK $180 shipped! (spare set)
- AL WTB: 2jz GE coil/sc400 TC
- AZ FS: HKS style 50mm Wastegate
- NJ FS: Both interior door handles.
- CA fs so cal: sc300/400 headlights
- FL WTB: ds62 igniter!
- IA Rear spoiler 97-2000 SC Peal white
- SC WTB: R154 Transmission
- FL For Trade: Tan Center Console
- CA WTB: Spare tire stem for steel spare wheel
- NJ WTB: Black SC trunk
- NV 1993 5 speed harness
- SC FS: Greddy 1JZ clear timing gear cover
- TX WTB: 97-99 SC300 Exhaust side valve cover
- KY WTB 1jz r154 flywheel
- NY 97 sc400 diff & one piece driveshaft
- MN WTB: 97+ Sideskirts / Door Molding
- OH WTB: Your stock Nakamichi 4" speakers
- CA Wtb: Carbing strut brace/bar
- PA WTB: 93 SC400 drivers side front catalytic converter
- CA wanted vvti harness.. 98 99
- Anybody selling coilovers?
- OR TopSpeed Dual exhaust
- OR 5spd cluster for your conversion
- AZ vertex rep front bumper
- PA JET Tuned 1uzfe ecu for trade
- IA O2 Sensors, Radio/Console trim, & interior parts
- NH GE parts
- CT W58, gte parts, na supra wire harness, ge vvti bottom end
- AZ FS:JDM Aristo twins
- NY Not enough history
- NY Aftermarket Headlights/Highbeams/Tail lights
- CA WTB: 2jz-gte + R154 trans
- TN F/S Rideskinz lips, 97 bumper
- MD Low miles twins, oil pan,pipings, tt p/s pump etc..
- FL front upper control arms w/prothane bushings 70.00 shipped!
- WA FS: 1UZ-FE, harness,ECU ,trans from 1992 SC400
- CAN-Toronto Fs Toyota Aristo harness 1jz&2jz Compatible
- TX WTB 97+ Passenger Tail light
- CO 3 inch downpipe, SAFC, UR crank pulley, HKS VPC, Bee*r
- NJ Wanted: A set of 95-96 tails w/harness
- FL 1jz starter for sale
- CA FS: Black Interior, Gauges, Rear SC strut bar EVERYTHING OBO
- FL FS: HKS cam gears, HKS timing belt, Polished Q45 TB, 440cc & 550cc injectors
- CA fs 2jz fields harness
- MD FS: w58 core/ parts transmission
- FL wtb front lower control arms asap
- CA fs so cal: 1996 tailights
- PA WTB Passenger Side Inner Door Handle
- SC WTB water valve vsv housing
- AR 92 sc400 door panel & ecu
- MD WTB: Seats
- GA WTB 97+ Front Left LCA
- GA WTB Rear Back Glass 94 SC400 Atlanta/Athens GA area
- CA ALOT of SC300 parts available: NA GE or TT GTE Block - Motor - Head - W55 Trans ETC!!
- MI Wtb Dwp fenders
- FL SC Cluster parts
- FL SC 400 Woofer
- NV seats
- SC 2jzgte ECU (aristo) for sale
- VA WTB: 1jz auto ecu
- FL WTB: Rear exhaust hanger set/pair (By the muffler)
- TX WTS/WTT: SC4 Manual Swap [24hr]
- FL FS: Tan Airbag & IACV
- GA Supra TT sway/stabilizer kit
- CA FS welded diff anyone.
- PA WTB: Looking for Exhaust System
- TX VVTI coils wires and igniter for COP swap
- CAN-Vancouver FS: Carbing Strut Tower Bar
- TN Round 2 - WHOLE lot of parts from MAF to Charcoal canisters to trim and more
- AZ Genuine Walbro 255lph GSS342
- TN WTB: 97+ sides
- FL Custom catch can & new powder coated wiper arms!!!
- FL FS in FL 1996 sc300 black steering wheel w/airbag
- CA FS: 97+ lip(rideskinz) and a set of ls400 calipers BAY AREA
- NV re-key
- NM FS: OEM Springs from a 92' Sc400
- TX WTB: 97+ front and skirts
- AZ WTB: This little weird outer door panel cover.
