View Full Version : SC400 / 300 Classifieds
- CA WTB: ARISTO coolant gauge sensor
- NJ Stock Suspension 97 SC3/ Daizen Bushings
- VA WTB: SC Driver Side Headlight
- NY FS: 92-00 Lexus SC300 & SC400 chrome emblem sets complete
- CA WTB Need an alternator for my '92 5-spd stock SC300
- TX WTB: SC300 clutch pedal!!!
- GA WTB left front ABS sensor 95 SC400 $30 shipped
- CA Espelir Active Super Down Springs and OEM shocks
- NY 97-00 Conversion Parts for Sale
- CA MKIV Suspension - OEM TT, OEM N/A, Eibach Lowering Spings
- NY Complete Black Interior
- CA My spare SC300 parts
- CA LCA sleeve [placeholder thread for iTrader]
- KS FS:Random Tan interior parts! Driver window reg... etc bumped out, relist after 2/14
- CA FS: Map Ecu
- CA Version:Select front bumper BODYSHOP SPECIAL
- NV wtb passenger side airbag in tan
- CA DWP 97+ OEM complete kit
- CA WTB stock sub and rear speaker.
- FL FS: LS400 Calipers $170 Shipped
- GA FS: Ignitors
- GA WTB-Rear Camber kit
- FL WTB Sc Glass Headlights
- GA FS: Fuel Pump ECU (2)
- NC WTB Lowering springs and shocks
- FL 92-94 Tails $60 DS Door Wood $20
- NC WTT/WTS SC300 trunk spoiler
- LA WTB: Passenger's side headlight
- NY FS/FT: 1jz soarer plug n play harness and sc300 5spd parts
- GA Tt wheels for sale...
- NY extra na-t parts
- CA WTB: axlebacks
- WI floor chassis bar will trade for shift knob or 1jz stuff
- FL 99-00 CD Changer
- FL WTB: 1uz Bellhousing
- OK FS: 1998 Taillights - $200 Plus shipping - bumped max, relist after 2/14
- TX WTB: Brown door trim (driver side)
- IL 2jz ge engine low miles good condi
- DE aristo intake mani and tb fs
- GA FS: Driver Door/ Passenger Door
- NY FS: Working Antenna
- NM FS OEM manual bezel and knob
- CA WTB : Clean Black Driver side fender
- AZ FS: Stock 2JZ-GE motor and w58 trans
- NY FS: Black Rear Seats
- MD 1jzgte - Intake Manifold, q45, greddy tps adapter, 3" Y pipe & down pipe
- CA FS: HKS SSQV w/ PURPLE INSERT
- TX Brand NEW!!! Genuine Garrett GT35R
- MD F/S 97-99 sc300 taillights
- CA upper control arms 1 driver side 1 rear passenger side $75 each shipped new starter
- CA ~HKS 60mm GT-Wastegate~ *supa cheap!!!*
- GA Fs: 1uz-fe ecu
- MD For Sale: Big Brake LS400 Upgrade
- GA Radiator Overflow Tank with Sensor
- CA FS: Mass air flow sensor (MAF)
- NY FS: Tan 3 Spoke Wheel - no airbag
- TX WTB sc400 transmission
- TX need driveshaft!
- NY FS: 92-00 Lexus SC300 2jz OEM 5-speed Transmission swap Kit
- CA stock 2jzgte & 2jzge parts
- CA Need coolant reservoir for 97SC4
- NY FS: 97 SC300 Cluster
- WI WTB: '95 style gauge cluster
- OK WTB: early 95 sc400 MAF and disc sleeve
- CA WTB: 99-00 Airbags Black & 97+ front bumper
- MD FS: Power Antenna
- MD FS: Inside Door Handles
- MD FS:1995 Good Pass Rear Tail Light/Cracked Driver Tail Light
- MD FS:Black 3 Spoke Steering Wheel
- TX WTB Complete 97+ OEM Kit
- NY FS: nice & cheap BLACK interior parts....pic inside
- NY FS: 92-97 SC300 2JZGE Long Block NICE & CHEAP
- WI 1992-99 lexus vertex style front bumper professionally painted black
- CA sc300 97+ Full OEM Kit bumper side rear bumper
- FL FS: LS400 Calipers, pads and New Rotors
- CA **FS: Door Sill Rubber Insulator/Rear Shock/Body Moldings/Wheel Well Plastics**
- TN NEW STOPTECH stainless brake lines
- CA 92-96 rear spoiler
- IL FS: 2JZ Bellhousing, Rear Sump Conversion Parts
- DC Chaser r154 fully built/full swap
- CAN-Toronto WTB: Coilovers
- CA celica gts steering wheel
- CA hks blow off valve adapter for twins bolt on
- MD 98 SC400 Partout
- WI front seats from a 96 (black leather)
- CA stance coils with 10 mins on them.
- NY FS: 92-00 Lexus SC300 OEM Fan shroud PERFECT
- CA Looking to buy: 97+ OEM Grille
- VA FS: Greddy Emanage Ultimate w/ universal harness
- NY FS: 01 RX300 wood steering wheel, GS300 airbag
- VA 2JZGE T4 Turbo Manifold
- CA 94 OEM SC300/SC400 Service Repair Manuals Vol. 1 & 3
- AL WTB Inside door latch cable, etc...etc..etc..
- MD FS: Wood steering wheel w/ airbag
- MD Tan Interior part out
- TX WTB: 1JZ Mid-sump Dip stick assembly
- GA Driver side door trim.
- CA 2 Trunks for Sale with spoiler DWP and Red
- DC 2jzgte/2jzge gates timing belt and drive belt
- CA Wtb strut sway bar
- MO 96 sc300 seats
- MO 96 sc300 doors
- MO 96 sc300 motor and trans 130k
- TX Need 1UZ Engine Covers
- CA WTB: Drivers Side Window Motor
- NY FS: 3-spoke steering wheel in Black for CHEAP
- NY FS: Rear Black seats - top and bottom
- NY FS: Mint ebrake boot in tan
- PA WTB : 98 Front Bumper
- MD FULLY BUILT 1jzgte non-vvti head (closed for ebay)
- CA WTB: 92 - 96 OEM Front Lip
- TX WTB - Front Bumper and Center Cupholder w/Lid
- FL FS: Stock Amp (not the sub amp) from a '93 SC400
- CA 1jz intake /charge pipes
- CO EBC Brake pads, some stock parts FS
- MA 92-96 lip
- MD Window Regulator, Stock Head Unit, CD Changer, Wheel Hub and more
- GA WTB - SC400 rear emblem!!!!!!!
- NY FS: Glass and Plastic Highbeams
- MD FS:1999 SC400 1UZ VVTII Complete Motor Swap
- CA 2jzge FOR 50 BUCKS???
- NY FS: 2jzge vvti part out and more.
- OH Biggu's garage sale.
- NC WTB some stuff
- FL Awesome
- FL Complete 2JZGE engine: Harness, Accesories, etc
- FL FS: LS400 Calipers (shims,pads and pins)
- FL FS: Urethane Upper Control Arm Bushings
- IL FS : 440CC MKIII Injectors, New TT Head Gasket, ARP Head Bolts
- NY Tan Parts for Sale
- NY Black Parts for Sale
- FL WTB:Power steering kit
- WA WTB coolant overflow / reservoir
- NY FS: LS400 4 Piston Front Calipers
- OH FS (oh): R154 supra shift housing + shift linkage
- CA FS: JDM Toyota Soarer Power Folding mirrors (complete)
- CA Fs: ls400 bbk
- GA FS: B&G S2 Sport Springs (SC300)
- CA HKS racing suction for supra / 2JZGTE
- CA WTB: 92~94 lower side moldings.
- OH FS: 1jz R154 flywheel
- GA Wtb 1jz map sensor.
- FL FS - Door Rod Lock Clip 69293-12050 (Passenger Door)
- MD Pnp 1jzgte harness /2jzgte engine for sale
- NY PART OUT 95 SC300 Complete car 5-speed, all parts are MINT
- AZ WTB: 5spd swap
- CA WTB clutch pedal assembly
- WA Wtb
- FL WTB: coilovers for sc300
- CA HKS Carbon TI Exhaust
- CA WTB: Working CD Changer for OEM Pioneer Headunit
- NJ FS/FT: stock exhaust for your aftermarket
- MD Fs/ft:lexus ls400 four piston calipers and freshly turned rotors
- FL WTB:Passenger front Lower control Arm
- CA FS: 2jzgte intake side & stock twins with manifold
- NY FS: Brand New Mishimotor intercooler
- FL Tan Driver Side Door Panel
- FL fs rear sump oil pan and 1jz gte block
- TX WTB: Module ECU Power Mirrors
- FL WTB A/C Console Unit ASAP!!
- NJ Jdm Aristo Twin Turbo 2JZGTE Engine Only
- MD WTB 97-00 factory front bumper, side and rear skirts
- CA WTB-Black 97 Side Skirts
- TX 90mm TB, 95-96 tail light
- GA Wtb: hood, stock suspension etc
- CAN-Other WTB: 2JZGE or 1JZ Alternator
- NY WTB: front bumper support beam
- FL (8) New IK22 Denso Iridium Spark Plugs
- CA WTB SC300 Cluster !!ASAP!!
- GA FS/FT: TT RS*R down Lowering Springs
- NY Name your price - bunch of parts I need to move
- MS WTB - ONE (1) front coil over
- CA NORCAL: SC300 part out Vertex style kit, Bride , coilovers, 18s
- CA WTB EBAY chrome high beams
- CA WTB: hood stuts w/ ball end screws
- NY WTB 97+ Fog Lights
- GA SC300/Soarer 3" catback single outlet exhaust
- GA FS: Daizen FUCA/FLCA bushing kit.
- MN Garage Sale (Tein, TMS, TRD)
- CA oem 1994 sc300 Front bumper, fogs, hood
- OK Wtb: Used '95 disc sleeve!!
- KS 97+ taillights
- CA FS: Driver Side 1997+ Fog
- CA WTB: 95-96 Passenger Side Tail Light
- IL WTB: SC300 Battery Tie Down
- IL 95 tails, Clifford alarm, Transmission cooler, 5spd ECU, Ignitor, Coil
- CA WTB sc300 auto Radiator
- FL Lower Control Arm Bushing Kit
- NC WTB SC400/TT PS res
- CA WTB power steering resevoir sc400
- CA WTB: Need Coilovers for my SC300 in the 626
- CA momo steering wheel "wood grain"
- IL WTB Supra LCA Front
- MA Stage 5 Competition Clutch Kit R154
- TN WTB: White drivers side fender, hood, and front bumper
- FL Looking for someone parting out
- CA FS - Magnaflow 3" Highflow cat BNIB
- TX Brake Rotors and Stainless Steel Brake Lines
- NY WTB- Windshield Wiper Fluid holder
- CA wtb soarer griffin badge and oem rear badges
- TN LS 400 calipers, Stoptech braided lines, rear brake setup
- OK Stock 550cc injectors with rail and intake pipe with MAF and filter for sale!!!!!
- WI jzx100 R154, ct15b
- TX FS: oem factory sc300/sc400 car cover....
- WI ATI ACS full kit for a 97 bumper or sale.
- CA FS: greddy emanage ultimate w/ jdm 2jzgte harness
- FL Wtb:Black or grey carpet
- NC badly need driver side tan interior panel
- CA WTB: 97+ Rear Bumper DWP
- CA Toyota Supra 93-97 Greddy EVO3 Catback Exhaust System
- NJ safc1 with patch harness and bcc
- MD wtb 1jzgte or 2jzgte direct swap into sc
- OH Exedy Clutch and Fidanza flywheel kit CHEAP
- FL Metra SC300/400 Radio adapter
- CA wtb: Engine mount 1jzgte
- GA WTB: Driver side door window trim
- AZ wtb: 1jz tps sensor
- CA Fidanza Flywheel $250 shipped
- CA Lots of parts 2jzgte,2jzge,2jzge
- CA FS: KYB AGX/Tein S-tech suspension
- OK Almost complete 5 speed swap for sale!!!
- MD Black T4 Turbo Blanket BNIB: $145 Shipped
- CA FS: 2jzge head, intake runners, chamber, plenum, throttle body.
- OH WTB: turbo oil/water lines
- FL FS: Front Upper Control Arm Bushings - Prothane
- NJ SC300 parts for sale
- CA FS-Black Recaro Pole Position (New)
- MA WTB: 2 hks hi power mufflers
- CA WTB: TT Rear Calipers
- IL WTB: Rear bumper absorber/foam
- WI WTB sc300 rear calipers
- CT Wtb true bolt on headers for 97 sc400
- GA WTB stock sc400/300 front springs+struts
- FL Blitz 700cc injectors
- TX 1jz twin turbo parts for sell. I went single.
- TX WTB WTB: GREY door panels
- CA 1jzgte m/t ecu and front sump lower oil pan
- FL WTB: headlights usdm asap
- NJ WTB: 1995 Sc300 brake booster
- SC FS: Black steering wheel
- CA WTB: splash shields & fender extensions
- DE WTB Black Interior
- FL FS GTE coils & cam sensor cheap
- FL FS stock Supra struts and springs
- CA SC misc p. a/c, R seats Ta, F/R bumpers, Greddy Boost gauge NIB, ENEos
- CA vertex replica body kit and bomex body kit for sale
- VA FS: OE 1995 Chrome and Gold SC300 emblem sets
- IL Black interior parts
