View Full Version : SC400 / 300 Classifieds
- OK Black Heated Leather Seats From My 97 SC400
- OH Biggu's 1jz/2jz/ SC 300 garage clean out *tons of pics*
- TX Stock TT and SC300 Parts. Turbos, Intake, Throttle Body, Fuel Rail, etc.
- VA WTB Stock Headunit, Right High Beam, Rear Speaker Deck
- FL New oem steering shaft u-joint & flex coupler 45.00 shipped!!!
- FL alamost new Moog outter tierod ends 30 shipped for both!!
- FL WTB: 600-750cc injectors/ side feed,high impedance
- TX F/S: MKIV stock suspension
- TX F/S: oem front lip
- WA WTB - Tan Front Heated Seats
- FL WTB Black interior for sc300!!!!!!!!!!
- AL WTB: 1JZGTE manifold gasket
- AL 1 set of us stock 2jzgte cams
- CAN-Other WTB: air suspension.
- FL wtb soarer 1jz auto ecu
- NC FS: HKS cat back exhaust
- AL 97 driver side fog light
- CA FS: strut bar
- CA lots of parts sale.
- AZ FS: passanger and driver window switchs
- FL MKIV OEM Supra Suspension
- AZ wtb sc300 fan shroud with intact plastic clips
- FL Turbo parts for sale
- CA WTB: Black Door Panels, Front & Rear Seats
- FL black 3 spoke steering wheel.
- PA MKIV Tanabe GF210 Springs, GE 5 spd ECU, bumpers, ASA wheels
- NY WTB: 2j-ge distributor plug
- NJ WTB: Driver Side Mirror (WHITE)
- CA Injen intake used
- NY 97 Sideskirts and 97 Fogs
- CA WTB:2j lower oil pan & pick up
- CA FS: JDM Window Visors
- FL Wtb rack and pinon bushings asap!!!
- NY 97 Sideskirts - Green
- FL FS: Holset b.e.p. back housing
- TX 97 grill/fog black sc steering wheel -DFW
- CA wtb: throttle position sensor for 2jz-gte
- CA DaveH NA-T Turbo Kit!
- AZ NGK Iridium IX spark plugs for 2JZ-GE
- GA WTB: 97+ SC300 driver side tail light/Bumper
- CA Lexus 5spd driveshaft out of a SC300
- CA WTB: 97up DPW Front Bumper
- AL 97 taillights
- FL Fs: Black interior parts averything has to go.
- NY Black Part Blowout - get it before it gets junked
- CA WTB 92 sc400 power steering pump
- CA Zex nitrous kit with remote bottle opener and more..!
- OH WTB: GTE Powersteering pump
- CA WTB: USDM TT OEM #1 Injector
- CA FS Blitz Nur Spec R single catback
- NY 97-00 cluster $50 bucks
- CO Black 3 Spoke Steering Wheel
- CO 95-96 Taillights With Harness
- WA Wtb: 1jzgte harness
- CA fs:3 spoke steering wheel/airbag and ls4 brakes and drilled rotors
- MN Turbonetics 62-1 turbo ballbearing t3 stage 3 .63 housing
- GA FS: Powered by Max aluminum subframe collars
- CA WTB: 2JZ-GTE cruise control sensors
- GA FS: Daizen Poly Bushings
- AL 97 taillights
- ID WTB: MINT tan carpet, rear sub grill & backs of seat ( if possible)
- TX 97+ OEM Bodykit For Sale!
- MD WTB Yakima Rack
- CA Complete big brake upgrade $275
- NY Black Interior Partout
- AZ Wtb: passenger side headlight
- TX 1995 Rear Bumper
- NY SC400 Motor Partout - whatever you need
- NY FS: 95 SC400 Coolant Reservoir
- IN WTB good climate control for 93 SC400
- CA FS: Gas Fuel Tank Door Lid
- FL Wtb: R154
- FL WTB 97 grille
- FL 9006 6000k 35w hid kit 33.00 shipped!!
- WA WTB: Idle Air Control Valve (IACV)
- TX Selling aftermarket seat covers and five speed shifter trim
- GA WTB 96 right rear tail light
- VA wtb: radiator, gte coils, vertex kit, coilovers.....
- GA FS: W58 Transmission $250 *Pickup only*
- CA Supra TT Rear Brake Calipers and Rotors
- CA onxy black 97+ OEM kit w/grill
- NY Mint Black 99 3 spoke steering wheel with airbag
- AZ WTB: Windshield washer reservoir(95 sc300).
- NV 2 door panels both mint 1 grey 1 tan
- VA WTB-Black 97 Front Bumper
- CA WTB- Origin Body Kit, 97 SC400
- NY FS: passenger side door handle and mirror
- OR SAFC2 Great Condition $160 Shipped
- NY FS: Heater Valve - 40 shipped
- NY FS: 92 5 Speed ECU- 40 shipped
- TX Leftover parts from 1JZ swap. Twins, DP, Belt, starters, airbox, etc
- FL WTB Lexus Soarer R154 tranny ASAP!!!!!!!!
- AL 440cc injectors top feed
- FL Chrome Lexus Emblems
- SC Part outers! Rear subframe bolt?
- CA FS: 1995 Tail Lights / Tail Lamps (pair)
- TX WTB: jdm window visors
- CA FS: Black SC300 '95 Rear Bumper
- CA FS: Lowering Springs, Shocks, Mounts, and Boots
- MA Window/door/mirror control switches
- IL WTB: 97+ LH Window Regulator
- NY Complete Black Interior
- IL BoostLogic EGR Blockoff plates
- TX FS: 95-00 SC300 starter $55 shipped OBO
- TX WTB: non-leaking or rebuilt PS pump!
- CA WTB r154 extended shifter housing
- CO FS: Gated Shifter
- CA FS : Starter off a 1997 SC300
- TN FS: Aristo 2JZGTE; Engine, Trans, ECU, Extended Wiring Harness
- AL WTT: Transmissions, injectors, complete motor, flywheel, torque converter for.......
- IL 1997 conversion
- PA WTB SC Body parts
- CA 91-00 Lexus SC300 Complete 3PC Kit - VERTEX style
- WA Wtb sc400 shift solenoids
- MA Corbeau, Door panels, Greddy, HKS, Injectors, speaker adaptors/ dash kitetc.
- TX WTB front SC3 manual drive shaft
- OR FS: Aristo TT ECU $150
- FS: 99 SC Headlights - Pair
- FS: Cup holders - Center and Butterfly
- TX hks manifold and wastgate for sale
- IL Very Rare 97-2000 Oem 5 speed Cluster
- MN LS/GS/SC430 Diff Pumpkin
- TX Interior partout, Spruce grey.
- NJ WTB rack and pinion
- MA 97+ high beams, 98 climate control, 98 spoiler light
- TX WTB: passenger JDM window visor
- LA 93-96 MAF $75 shipped!
- FL WTB Clutch Master Cylinder 95 SC300
- TX WTB: 1jz idle control valve
- ID WTB: Fuel System for Turbo Swap & E85
- NY WTB: White DWP Drivers door
- NY FS: 92-94 and 97+ Climate Controls
- CA WTB 92sc400 alternator
- NY FS: 97 Conversion Parts - Side Skirts and Grill
- CA 97+ sc300 rear Spoiler los angeles
- CAN-Vancouver WTB stock fenders
- CAN-Toronto Sill for sale - KSport Air Ride Setup - Complete
- MA WTB: 2JZGTE Engine Only
- NJ WTB:95 SC400 Power Steering Line
- NY FS: MKIV Eibach springs with AGX's
- CA OEM STOCK springs and shocks CHEAP!
- TX WTB: 1jzgte intake manifold runners gasket
- CA WTT:FREE '97-'00 Foglights.
- mk4 Front break Kit
- NY FS: 97 Grill
- NY FS: 97 Fogs
- NY 99 SC Front Bumper
- AL stock 1jz turbo
- NY FS: 99 sc3 cluster with pig tails
- NY FS: Homelink visor
- AZ 1995 front bumper with fog lights
- IL WTB seat parts
- NV WTB: Carbon Fiber Trunk for SC
- VA WTT my Woodgrain Nardi Steering wheel for your Headlights
- FL WTB Rear SC Nakamichi speakers
- CA WTB: sc side and rear kit asap
- NJ WTB : Tan drivers seat
- NY lexus parts
- NY SP63 T4 Turbo
- MD High end NA-T parts, rebuilt GE block, head, VVTi head, etc.
- VA Wtb - 1995 sc300 maf asap
- NY FS: 97+ Conversion Parts
- NY FS: Gated Shifter
- FL 2JZGE Custom FFIM with fuel rail and injectors.
- WA WTB - Coilovers
- CA Tan Leather Seat Covers - SC300 / SC400 - Complete Set - BRAND NEW
- CA TANABE NF210 Lowering Springs for SC300 - BRAND NEW IN BOX
- CA Brand New 97+ Grille
- CA 97+ SC300 SC400 Front Bumper Cover For Sale
- FL Axle back exhaust
- CA FS - Strut Tower Bar $50
- NY 2jzGE FFIM flanged for q45TB
- AZ R154 5 speed Trans
- MD Stock shocks/springs, RSX-S seats, Auto 2JZ swap driveshaft, Supra parts etc...
- NY FS: Aristo Harness, Cams and Incectors with Rail
- FL 5spd Crossmember & Trans mount
- PA 2jzgte Ignitor
- CA SC300 / SC400 Brake Parts for Sale (Calipers, Rotors, etc)
- AL WTB: HKS bov, piping 3", AEM digital oil gauge
- OR SC300/2jzge 5-speed ECU
- NY jdm toyota aristo automatic transmission
- FL WTB: JZ - R154 Flywheel
- FL r8 style headlights and glass high beams
- CO 2JZGE FFIM Intake NA-T w/Q45 flange
- CA FT 2jzgte Rear sump for a 2jzgte Front Sump
- CA SC300/400 AIT AC style front bumper and VIS Vertex style sideskirts
- FL Custom 92-94 5spd Shifter*Goose Neck*
- CA TONS of Misc. Parts from MKIV and SC300... + extras !!! ALL WITH PICS
- CA WTB: SC300 Climate control unit WORKING
- FL wtb: 95 auto ecu
- CA WTB right side Fender
- FL Wtb fuse box in the bonnet
- VA WTT TEIN HA coils for spring/shock and Nardi
- FL Pair of good upper control arms 55.00 shipped!!
- MA Rear Supra TT springs and SC300 fronts
- OH WTB: Driver front headlight
- WTB sc400 Ecu
- IA WTB: 92-99 very broken front bumper
- CA WTB: 1997+ SC300 front bumper ASAP.
- FL WTB: Interior passanger side door handle.
- FL FS: TT rear brake set
- CA FS:1996 SC300 Garage Sale Bonaza!
- TX turbo kit needed DFW area
- LA emanage blue turbo timer
- CA WTB 1j cam bearing cap
- FL clean pass side headlight
- IL 2JZGTE Ebay downpipe (Brand new, never installed)
- WTB 92 sc300 fan shroud
- CA sc400/sc300 parts
- CA WTB> black gas tank door
- FL WTB: 1JZ Soarer ECU A/T
- MA Need a fender
- AL WTB: R154 slave cylinder, flywheel, shifter, and fork!
- CA WTB: 5spd W58 Flywheel
- PA Ebay Taillights, Tan interiors pieces, door hinge, window, other
- FL wtb 1jz auto tranny
- CA WTB 1JZ Coil Pack Cover
- CA WTB 1JZ/2JZ PS Pump Fitting
- NC Sc high beams
- NY few parts for sale sc300
- TN WTB: 1998 SC400 Differential
- CA wtb...sc300 radiator asap
- TX 96 OEM Tail Lights/ 96 OEM Trunk Spoiler w/ 3rd brake light.
- SC 3 bar map sensor & swoosh turbo timer
- CA WTB: Mint Conditions Complete Black Interior for SC300
- TX MSD 6A CDI Ignition with Tach Adapter
- IL Stuff for sale more to come !!!!!!!!!
- WA scxxx pass window switch, shifter bezel, & dash
- CO AEM EMS 30-1101 For Sale...N/A Supra and Lexus SC300
- NY 93-98 Supra TT Front rotors D/S
- WTB: W58 5spd for 97 SC300
- CA wtb 2jzge block
- CA WTB: 97+ Stuff // Vertex Style Kit // Front Lip
- International 1JZGTE manual soarer ECU
- FL FS: My OEM pre-97 front lip to fit a 97+ front bumper
- NC 2jz-GE parts for sale
- NY WTB 2jz-ge FFIM
- NY FS: 97+ Parts
- LA WTB: Mint Amber A/C LCD
- NC WTB: SC300 Fan/Cluch setup
- IA Supra TT Calipers/Rotors
- FL Stock sc300 Intake Manifold / Stock Injectors
- NY scrapping my car
- CA FS: SC400 Brake Rotors [NEW CONDITION]
- FL complete R145 (2jz/1jz) swap
- NJ FT: white wingless trunk
- CA SC400 ps reservoir
- VA WTT : Seibon CF for OEM HOOD
- NY FS: 94 SC300 5 Speed Engine ECU
- FL mkiv n/a wheel w/bald tires 400.00!!
