View Full Version : SC400 / 300 Classifieds
- FL F/S factory front lip, black seat covers and headrest.
- WI wtb: looking for parts
- PA WTB: Drivers high beam lens / Touch screen head unit with Metra Kit
- CA WTB: rear sump upper oil pan only
- WI FS: SC300 2JZ-GTE Non vvti Harness
- FL WTB: A few parts i need
- FL FS: AP Engineering shifter kit, CX Wastegate, Fuel Rail, Timing Belt..Want gone OBO
- GA FS-New Rebuilt Front Supra TT Calipers
- IA wtb front lower control arm camber bolt
- NY F/S 2jz-GE Swap
- possible uncracked center vent available
- CA WTB: Widebody front fenders
- AZ FS: intercooler pipe, couplers, 40mm dump tube, wastegate spring, T-bolt clamps, o2
- NY black 3 spoke steering wheel
- TN WTB: Soarer MINES/BLITZ ECU
- WI WTB: 97-00 sc300 oem front bumper
- GA 97+ Fog Lights and Grill
- NJ WTB WTB WTB 92-96 Molding
- CO FS: 6766 ball bearing, turbo kit, AEM v2
- NC WTB 97+ OEM Sideskirts & Door Moulding
- CA FS: Stock 1J turbos, gated shifter, glass high beams for sale
- PA WTB Sparco Passenger Base Bracket and Slider
- CA FS: TRD Supra Strut Tower Bar $160
- NV AUS 850cc injectors
- MD 2JZ GE from 92 SC300 Engine FS
- CA FS: NEW Seibon Carbon Fiber doors SC300/400 Los Angeles
- OR WTB magnaflow 14829 mufflers
- VA TRUST Greddy Profec B Spec 1 - Electronic Boost Controller - Mint Condition
- OH FS: 1997 LS400 Passenger (ONLY) Front Caliper
- IL Black 3 spoke Toyota steering with with cruise and airbag
- CA Like New DDM Tuning 55w 5500k "Ultra" HID Kit
- OR WTB: clean headlights, 97 grill
- NY Fs:2jzgte cp pistons and eagle rods
- OR WTB sc400 ecu
- WI Carbon Fiber Fuse Box cover $150
- CAN-Vancouver WTB Headlights.
- FL 2jzge is300 COP conversion
- CA WTB nakamichi amp for 99 sc400
- TX 1994 SC400 Tan Interior pieces
- NV wtb- 1jzgte non vvti downpipe. asap
- NJ 1JZ PRECISION 6266 w/TIAL 44mm NEW
- CA FS - 5pd SC300 clutch and brake pedal assemblies, front half 5 speed drive shaft
- TX 1jz extended harness for sc and rear sump setup
- NM WTB: 92 SC400 Radiator reservoir
- TX wtb: 97+ front bumper cover
- MD 1jz Soarer ECU A/T Driftmotion rebuilt
- NC W58 Trans + other parts
- CA wtb: 97 sc300 gauge cluster auto >>>>>>
- TX BC Racing Coilovers
- CA FS: 97 OEM wheels /passengers upper trim oem black
- GA FS - Precision 6262 T4 Turbo
- CA WTB 2JZGTE Cast Manifold, T3 Divided (Preferred) or T4
- VA wtb aem boost and wideband gauge
- CA f/s used toyota alternator with regulator oval
- FL WTB: 2JZ-GE oil pan assembly (rear sump)
- NY FS:93-98 Supra or sc300 NEW tein-S springs and KYB gr2 shocks,2jzgte AEM V1 standalon
- TX WTS: Sc400 driveshaft good condition
- CA Dome and Map LEDs
- WI WTB: 95-96 or 97-00 sc300 taillights
- IL Random goodies
- IL FS: RX300 Black and wood steering wheel
- PA WTB: Supra TT Auto Diff w/ LSD 3.76
- NY WTB wooden steering wheel es330,gs300,rx300
- NY 97 sC300 Partout
- Aliga?
- FL FS: Tan 3 Spoke Steering Wheel & 4 Spoke Black Wheel
- FL Used Shine Kit for Sale
- CA WTB: used ebay mufflers "tanabe clone"
- VA WTB: Used 1JZ OEM Flywheel
- CA Turbo Oil Lines
- CA WTB: Auto Trans
- WA FS: Garage cleanout: Drewgo, DLI, Airsto and NA harnesses, Coils, Filter housings
- FL Fs: Tan carpet sc300/400
- MN 1/2jz rear and front sump oil pans
- International wtb steering column cover with Tilt in black
- CA wtb shifter housing w58
- CA Fs r154 with bellhousing and shifter
- GA SMIC, Gauge Cluster, & Wideband
- IL Toyota lexus driveshaft new oem factory coupling flex plate 37511-24010
- IL Boost gauge and G-tech
- TX WTB: Tan Front Passenger Side Seatbelt
- OR Cleaning out garage, SC300 OEM Parts
- CA FS: 4" intake, BNIB VVTI oil pump, Engine girdle
- CA WTB: r154 front shaft
- PA WTB 1997 SC400 Alternator and Power Steering Pump
- CA For Sale Mint/Excellent Condition Duck Bill Rear Spoiler For SCs. So. To No. Cali
- FL FS: Tan Leather Seats, Wastegate, R154 Pressure Plate, & Timing Belt OBO CHEAP
- CA 80mm Q45 TB + TPS adapter
- NJ 97 Sc300 parts Bumbers, sideskirts etc...
- MD Glass High Beams - $80 Shipped
- WI WTB: front lip and driver front fender
- NM WTB: 92-94 SC400 coolant reservior
- OH 1996 LS400 Front Calipers (4 Piston)
- CA Wtb injectors and map sen.
- WA FS: 2jzgte oem pistons and rods
- IL New EBC Green brake pads - Supra TT Front, SC rear
- PA 99 SC400 perforated steering wheel
- FL FS: 97 SC300 Part Out
- PA Megan Racing LP Coilovers low miles and LS400 BBK
- PA sc300/400 to Chevy v8 LSX swap mounts.
- WI Wtb 92-94 sc300 custom taillights and more
- NY FS: Custom 1997 Tails
- TX FS:Tan Passenger side lower door speaker cover
- IL FS: Black 3 spoke Lexus steering wheel - NO airbag
- GA WTB: front and rear gray seats
- NJ WTB: 2jzge turbo manifold NA-T
- WA WTB person to do some suspension work
- NJ Wanted: Stock driver side 1UZ header
- GA WTB SC Aftermarkey Upgrades
- FL WTB +97 Pass Fog Light
- FL WTB: Radiator with shroud
- CA FS: 2 Used Rear Supra KYB Shocks
- AZ FS: Celica Steering Wheel
- TX Freshly Polished Driver Side Headlight + Highbeams
- PA Boostlogic NA-T Intercooler Kit w/BOV
- MN wtb oem front lip
- shout out to Aliga
- IL FS: Strut Tower Bar SC300/400 $110
- FL WTB OEM Black Driver Window Trim
- CA WTB: Tan Headliner W/Sunroof
- NJ WTB: SC300 AUTO Engine Harness
- WI wtb: 92 sc300 parts
- TX 1994 SC400 Underhood Clean Up Items
- TX FS: Black Leather rear seat, just the bottom cushion
- TX FS: BBK For SC300/400 LS400 Complete front set including NEW PADS
- CA Wtb egr block off plate
- GA WTB: 440cc-460cc top feed injectors
- PA Need Perfect Working 1997 SC400 Alternator asap
- NV FS: BC Extreme Lows with Swifts (brand new)
- WA sc300/400 5speed pedal set
- CA Free parts!!! Pick up only!!!!
- CA MOMO Competizione Shift Knob
- NM WTB: Pressure feed PS hose
- FL WTB entry level coilovers.
- CA FS: Glass High Beams 2 sets
- TX WTS: titan cams, large b&m cooler w/ braided line an fittings, diy plasti dip kit!!!
- WA GReddy Turbo timer F/S
- NV wtb sc300 stuff
- CAN-Toronto wanted: driver seat rail for bride
- AZ WTB - Non-working Sub
- FL wtb stock headunit (non working ok)
- CA Espelir off my 99 SC400
- NJ WTB Auto couture or Shine front bumper
- FL BC Racing Coilover open box new
- GA F/S: AEM EMS V2. for 2JZ-GTE (30-6100)
- TX WTB 95 SC driver side rear lamp
- CA sc400 oem lip (misc items)
- MO FIC 900cc Injectors
- GA 97+ tail lights + harness
- FL FS: Aem v1 standalone for 2jz gte
- KY F.s. 5spd swap w58 pedal complete
- NY Wtb: Side skirts. Oem or aftermarket
- WA wtb coilovers, not picky
- CAN-Vancouver Complete M112 Supercharger Kit (Adaptronic ECU, Innovate MTX-L, AEM W/M kit)
- PA WTB....Passenger Door Panel
- FL Fs: soarer 1jz auto and manual ecus
- NY ID Injectors, Dr. Tweaks Harness, LQ9, Driveshaft Shop, RPS, AEM, Racepak...
- CA WTB - Aristo 2JZGTE VVT-i MAF
- CA 5 Speed and NA-T parts
- HI wtb 95 Sc300 ac compressor fitting plate
- CA gte igniter for sale
- GA 1jz full swap and many others parts R154
- FL WTB: Torque Converter
- NY Three PERFECT Steering Wheels. 2 Three Spoke, One Black, One Tan. 1 Four Spoke ,Black
- CO WTB LS400 Caliper part
- CA FS: BNIB GT4708R 80mm ball bearing turbo
- OK WTB: Soarer Griffin Emblem
- Fix your black leather front seats
- CA FS: OEM Toyota Rain Visors for 1SC - $130
- GA WTB: Various SC TT Parts
- GA WTT: Wise wing replica for a 97 front
- CA FS: Misc SC300 parts for sale
- CA FS: Blitz Nur Spec axle back
- Crashed my sc - WTB rear window glass
- FL FS: Greedy profec B spec 2 (electronic boost controller)
- NY FS: 97 Lexus SC300 Partout
- NJ NO Voucher - No High Dollar Sale
- NY FS: 97+ SC Taillights
- FL FS: Manifold, DP, Intercooler ...& stuff
- LA Sc400 stuff for sale!!!
- CO WTB Temperatue Control
- CA fs brand new tt headgasket
- CA clear side marker (custom made
- VA FS: 1995 Taillights w/LED turn signals
- CA FS: OEM floor mats, Leather seat covers, front bumper
- FL WTB 2jzge na-t complete turbo kit effi ect
- CA FS silver 97+ Door molding silver - Black knobs - 91770
- CA WTB: Sc300 lowering springs or Supra strut/shock combo! cheap coils also considered
- TX WTB/Looking for LSD.
- FL OEM Supra TT Springs and KYB Gas-a-Just Shocks
- CA FS: Brand New 5Zigen Fireball Mega Exhaust for SC300/400
- IN FS: Custom Center Console Trim + Cimate Switch
- IL FS: 1uz, auto trans, ECU
- TX 97 sc tailights good dfw $210 shipped
- CA looking for black driver side door panel
- TX 98 sc300/400 tailights
- VA WTB Coilovers
- CO WTB BBK LS400 for sc
- WA fs 1jz ignitor/map sensor/4inch stainless intake with larger cone filter
- CAN-Vancouver WTB - 1JZ BOV Block Off Plate
- CA WTB Black wingless trunk Los Angeles
- OR WTB: complete 1uz to 6 speed conversion SC400.
- FL WTB:1jzgte m/t ecu
- FL 2jzge na-t kit turbo kit complete ffim etc
- FL 2JZ VVTI items
- NY Partout 1996 SC300
- IN FS: OEM Black Dash/Console Parts
- OH F.s. 2jzgte doc race intake manifold,rmr 90mm tb, fuel rail
- CA OEM Headlights Right and Left $240
- GA WTB: SC300 1995 obd1 ecu
- FL OEM Complete Black floormats (Rare)
- TX FS: Driver side door hinge,SC300/400 Platinum Silver
- CA wanted tan front seat cover pair and 97 speedo auto cluster !!!!!
- CO WTB Center Console
- OR WTB Sc400 ecu
- IN FS: 3" BMPC Intercooler
- NJ LCA for sale
- IL Glass Highbeams off 1995 SC
- International WTB: Driver side door molding 97+
- GA WTB: 2jzGTE motor set
- GA WTB: SC300 steering wheel hub for Grip Royal
- TN SC300/400 CHEAP parts - lowering shocks/springs, 2800 stall TC, new shocks, 5spd swap
- CA FS SoCal: Trunk w/ Spoiler, 95-96 Tail lights, OEM Radio
- FL WTB OEM Black interior door panels
- VA BRAND NEW Front T.Turbo Calipers L&R
- TN WTB SC300 auto trans/torque converter in South East
- FL wtb asap black d/s power mirror
- CA FS: mise sc3/400 parts clearence
- TX 97 side skirts rocker DFW $100 firm
- TX 97 Taillights w harness DFW $240
- AZ Wtb: Aem v1
- AZ FS:BNIB AEM Flow Guage for methanol
- CA OC selling White 94 SC400 130k mi
- FL Tein Street Flex Coilover
- CA Brand New 1JZ Single Turbo Oil Line Kit!
- CA FS: NA-t Manifold, greddy oil filter relocation, BC Cam Gears
- IN FS: Black Master Window Switches
- NY FS: Brand new tein-s springs with brand new KYB GR2 shocks
- NY Fs: Brand new tien coilovers
- CA FS- Megan Coilovers
- AZ r154 clutch, shifter, Supra tt ecu, sc300 ecu, auto shifter
- CA FS: Turbo Supra Brakes Brand New OEM Project Mu pads
- CO CLEAN OUT OEM GTE Twins grey floor mats + more
- GA FS 1jzgte IACV
- FL intakes, accufab, GTE coils,BLK seats, and steering wheel, R154
- TX PPE Headers BNIB for SC400
- CA FS- Misc. parts for SC300/400
- NV WTB OEM front mudguards
- NJ Rear cat for 97 sc 300d
