View Full Version : SC400 / 300 Classifieds
- CAN-Other FS 440CC 2jz(jdm) injectors
- TX 97 bumper fogs l side skirts&molding dr. Tail
- NY WTB 92-95 SC300 5 speed harness
- TX WTB: NA-T manifold and or oil feed/drain set up
- CA gt4202 for sale new never ran Been sitting on the shelf
- TX 92-96 sc300 tow hitch
- NH WTB: 1jzgte rear sump lower oil pan!
- FL WTB - SC300 Manual Gauge cluster
- CA WTB- single turbo 2jz 3" vband down pipe.
- GA 97+ Complete Body Kit with Tail Lights , 1992-1996 OEM Front lip w/ mounting hardware
- CA Pick up only. Obo on everything must go ASAP
- FL WTB: Manual clutch set asap
- TX 1997 SC oem service manual set
- CA WTB: Fog Lights 1998 SC400
- CA WTB:Stock air box 1998 SC400
- OR wtb: k&m missile overfenders
- AL wtb: auto flex plate and coolant sensor
- NV BFI w/sc400 MAF (1998)
- PA WILLING TO BUY: Toyota Soarer Griffin
- MD FS: R154 OEM Clutch Kit
- MD 92-97 shifer bezel
- VA 2JZ Belt Tensioner
- AZ Lex AFM with sensor and Q45 TB with TPS
- NJ wanted: black 95-96 front bumper
- NV HKS T04z turbo/kit (2jzgte)
- TN WTB: 98-00 APPS (or used throttle body
- CA WTB 20mm-30mm spacers
- GA 4" inlet 4" outlet muffler
- GA FS/FT- Blacked out low-beams, red/clear 95 tails, SC400 Maf, etc...
- VA Wtb: 2jzge ffim
- CA Tein Advance Street Coilovers
- FL Garrett GT4202r T4 Twin Scroll 1.15 ar
- CA WTB:98 SC400 air filter box/Fog Lights
- GA Garage Sale - 97+ grill , HVAC control , others
- MD SC300 Auto Trans (FREE) and driveshaft
- FL W58 Driveshaft+flex plate // W58 Competition Clutch Kit+Flywheel // 1JZ Alternator+++
- CA fs almost new tokico blue and springs will ship
- CA WTS HKS cam gears
- AZ FS: Toyota Supra MKIII Shifter Housing & shift Lever
- AL For sale: Walbro 465 and Aeromotive 340
- NC FS: 2jzgte Valve cover & spark plug cover
- MD 92-94 front and rear bumpers EXCEPTIONAL condition
- CO WTB sc headlights
- IL GREDDY OIL FILTER RELOCATION KIT - 2JZ Brand New!
- OH For Sale: HKS DLI for 2JZGTE
- CO FS:Driver side mirror black
- RI fs 95 sc300 instrument cluster
- TX Black stock steering wheel and airbag
- TX Single Turbo Soarer 1JZ, 550cc injectors, HX35, 272 cams/springs, SARD ECU, GE Block
- TX Fs: 93 tail lights
- CA 2jzgte Exhaust w/ Megan Mufflers
- CO FS:Grey window switch
- CA WB crankshaft pulley (harmonic balancer) ASAP 11/30/2013
- FL WTB Heater Control Valve
- NC PT67 GTQ .81 and ID 1000cc with P&P Clips
- PA WTB: Gated-Shifter
- CA East Bay - Free Interior Parts! Others for sale
- OK 97 Repair Manuals 93 Electrical Wiring Diagrams
- NV xs power fmic gte
- NY WTB: SC300 aftermarket headlights or clear lenses
- CA FS: Black 1997+ door moldings $150 picked up
- CA CA FS: Shine Auto Replica SIDES+ rear lip
- FL MakeOffer: OEM suspension, w58 differential, & 2 R154 clutches
- FL WTB: 92-94 SC lip
- GA FS 550cc w/ rail, rear sump upper/lower oil pan etc.
- GA SC400 Complete drivetrain plus others $400
- CA Wtb: vertex kit or vertex replica but must be fitted already or decent fitment
- PA WTB: sway bar and headlight parts!
- CA FS: Muteki Lug Nuts
- TX OBD2 gte mk4 6spd tt ecu and MAF
- CA FS: 95-96 rear taillight harness
- CA WTB sc300 AC compressor / sc400 power steering Resivor
- CA Wise lip and 92-96 front bumper both black
- CA FS:Minty tan rear seats/96 tails/4 spk steering wheel/LS bbk
- NV 92 air bag computer
- AZ FS: NGK AFX Air Fuel Monitor
- IA WTB: Manual Shifter Bezel/Boot, Gauge Cluster and more.
- FL Trading parts in south florida
- NH WTB: ob2 harness
- MD FS: W58 Transmission
- GA Complete Black Interior Part Out
- CO FS:PROTHANE Polyurethane Rear Upper & Lower Control Arm Bushing Insert Kit
- CA 1992 sc300 Blown w58 transmission
- OH WTB: Drivers side window regulator
- CA wtb aem v1 for the ge
- FL WTB- ECU 95 sc400
- GA 97+ Body Kit Front Bumper Side Skirts Grill Hood Fenders 95 Tail light
- TX Driver 97 tailight $110 shipped
- TX 97 front bumper door molding sides R extension DFW
- VA LS400 Calipers BBK
- AZ FS: splash/mud guards
- FL wtb center ac vent
- CA Bumper trade
- FL no bulk sales
- FL *2JZ-GE NA-T Holiday Specials* (Clutch, Turbo, Intake and Turbo Manifold)
- CA **Dildomatic, 97+ Passenger Side Tailight (cracked lens), OEM Rims, Nakamichi Amp**
- FL AEM tru boost
- FL Wtb passenger side bottom door trim for 97+sc400
- CA WTB: GTE IACV check valve and washer
- AL WTS:R154 swap, AEM v1 etc
- FL FS: front lca's w/ prothane bushings installed
- AZ Wtb: Usdm obdii tt auto ecu non vvti
- TX FS: 97+ oem fog lights
- FL FS some sc parts for sale
- PA WTB: Rear Sump Oil Pan
- HI 97 sc300 / sc400 parts
- CAN-Vancouver FS... Parting out my stuff
- TX LF: Window Regulator
- CA FS: JIC Magic SUS full cat back exhaust
- WA Wtb: 12-disc cd changer
- CA Wtb- .82 AR or bigger turbine housing for pte5858
- FL 93 SC 400 Head lights And Door Panels
- NY Torsen LSD- $400
- TX Close please. Adding to existing thread.
- FL MISC 97 SC300 parts
- IL sc430 3.26 rear end good condition
- MD WTB: R154 Clutch Preferably 6 Puck
- OK Looking for complete 1UZ-FE shipped to Tulsa, OK
- AZ WTB: Front bumper side backets
- MO Wtb: Iacv #22270-50020
- AL need qualified voucher
- CAN-Other 1UZ Vortech V3 Si, Nitrous, Titan Line Lock, AEM FIC 8 & Failsafe Wideband, and MORE
- FL WTT: OEM 97+ Sideskirts for Aftermarket Sideskirts (Florida ONLY)
- AR Soarer 1jz vvti m/t ecu 89661-24500
- CA (97-00) Rear Bumper w/ Extensions
- TX F/S: r154 transmission (tripod shifter)
- CA WTT. NEW OEM w58 tranny mount for OLD broken mount. 91770 area
- CA WTB DWP 97+ Front Bumper
- FL WTB Gated Shifter
- CA FS: Tokico HP series shocks
- AR Bnib aem fic
- TX WTB: A few things.
- GA WTB 2jzge Turbo Manifold
- TX WTB 97 + passenger side rear extension
- NM 2JZGE non vvti partout, W58, speed limit cut controller FS
- CA WTB: Driver side door handles inside & out
- CA FS: LS400 bbk
- PA WTB: dual fuel pump hanger for SC
- IL Ground Coilovers Lexus sc Supra
- CA FS: Used OEM Shocks/Struts and Supra seats
- TX FS: Black Leather Steering Wheel 4spoke OEM
- NH left over parts
- TX 3 Spoke Wood Steering Wheel
- CA F/S brand new borg warner s366 turbo
- FL Nakamichi Head unit
- CA wtb: ac panel and control
- CA FS/FT: Sc300 sc400 extreme dimensions body kit
- TX synapse 40mm wastegate
- PA 97+ Smoked Tail lights
- CA Parts for sale! Read all about it!
- TX TT Rear Brakes (Calipers and Rotors)
- IA FS: 500cc and 330cc High Imp Injecotrs for 2jzge
- AZ WTT/FS: '97 Front bumper for AC/Shine/AIT front bumper
- CA WTB Wise front lip or trade for my oem lip
- GA WTB 97 Conversion Items
- FL wtb drivers door panel armrest
- CA WTB ASAP: 1996 SC300 Intake Box
- IA FS 500CC and 330CC Low Impedance Injectors
- FL WTB:Drivers Door Handle
- CA WTB:Driverside fender with DPW
- FL WTB Driver Glass High Beam
- NJ WTB Cluster Needles
- TX WTB coilovers
- GA FS 94 SC400 front bumper with lip/ 97+ Grill
- FL 1jz ac compresser , 93 bumper and lip , sc430 wheels
- KS FS A few great parts
- MD D2 Coilovers
- TX USDM & JDM 2JZGTE parts + USDM 2JZGE parts - CHEAP!
- CA WTB: 2JZGE tensioner pulley
- CA Fs: Safc1 1jgte params $140
- GA 2JZGE engine ARP headstuds, TT Headgasket , Crower springs & retainers
- FL FS: Custom JDM Clear/Red tailights....one of a kind!
- AZ Misc partout
- MD Dildo-matic shifter, bezel and heated seat switches
- AZ GE head, harmonic balancer, and more
- GA 2JZGTE GTE Valve Covers
- AZ SCx00 window switch driver and passenger side
- AZ FS: Aristo Alternator and A/C compressor
- MO 2jzgte aristo/supra parts
- FL FS: 97+ Rear Bumper, TT Brakes/Rotors & Rear Sway Bar, 1JZ Manifold...Look MORE
- GA WTB 97+ Passenger Fog light
- CA WTB black side skirts.
- CA FS - GReddy/Trust 3" to dual 2.5" Y-Pipe
- NJ Wanted: used old o2 sensors
- FL WTB Interior Driver Door Handle
- CA FS: BOV and 3" downpipe
- PA Save the Babies sale thread extravaganza nomenclature...
- TX Random SC300/400 parts
- NY WTB: SC300 Interior Black parts
- FL wtb Radiator
- CA FS: DevilsOwn Meth Kit
- NV 97+ skirts & 97+ tailights w/ harness
- OK FS: 97+ Tails & Harness
- FL wtb door assembly (preferably black)
- TX OEM Side Skirts and JDM replica Sides
- TX WTB 97+ front bumper
- CA FS Front LCA - 95-96 tail lights - 95 passenger high beam. - 91770 area
- TX Mint 92 tails+harness $110 shipped
- PA MOMO Team 300mm Steering Wheel
- GA WTB: 97+ Front Bumper
- NV FS: 1992 SC Taillights
- NY FMIC, pair of headlights,
- CAN-Vancouver WTB wise sport spoiler
- TX Espelir Springs ASD (Active Super Down) For Lexus 1992-2000 SC300 / SC400
- IL WTB Z06 Caliper Brackets
- NH 1uzfe rear (mid) sump oil pan complete assembly
- NJ WTB fuel rail sc300
- NY wtt blitz nurspec axleback for fireball axleback
- CA WTB: w58 tranny for 92-93 SC300
- FL Parting out stock 2jz-ge
- IL WTB: Blitz Nur-Spec Dual Axleback Exhaust Lexus
- GA Need racecar money - Driver Door panels, 97 cluster, 96 cluster, 97 tails,
- CA F/S CA IPT SC400 High Performance TC - Torque Converter
- FL WTB Headlight switch assembly
- CA wtb: NA-T jdm tt ecu mod parts
- PA Part Out 2jzge, ECU, MAF, NGK etc.
- IN CLEAN 1995 SC300/SC400 Headlight (low beam) pair
- NC Free Stuff, Waste Gate, Turbo Blanket, UR Pulley
- GA Differential 3.26 Gear Ratio Pumpkin with LSD
- FL wingless trunk lid
- NY WTB: 2jzgte cylinder head
- GA WTB: 5zigen Fireball Mega SC300
- WA WTB Power steering pump for 1jz/2jz
- International FS JDM 2jz-gte engine ecu harness twin turbo's bc272 cams and intake plenum
- FL WTB intercooler for 1jz sc300!
- TX New front leather seat set $300 shipped!
- AZ misc parts for sale, 97 fogs, ashtray, black ebrake etc
- IN Crack free window garnish molding, 115 cluster
- TX 2000 Tan 3 Spoke Steering Wheel 8.5/10
- TX F/S: 2jzgte t4 xspower manifold
- TX WTB gs400 3.26 pumpkin with diff
- MD trans swap , etc..
- TX sc 5sd ecu
- GA WTB 2jzge lower intake plenum
- VA Cluster, tail lights
- AL FS: Misc. stuff from SC
- IN Various 1995 SC300 Parts
- NY WTB: SC300 Roll Cage
- NC NGK Wideband, Bosch 044 Fuel System
- CA fs greddy speed cut
- IL Wrecked 1995 5 Speed SC300 Sale as parts car
- FL Brand New in Box! Tial Q BOV, Titan 2JZ Cam Gears
- PA Black GS400 Steering Wheel with E-Shift
- CA FS: Wedge Engineering seat bracket & Sc3 trunk
- VA FS: Erebuni rep/Fujin rear lip
- TX Full 97+ conversion
- FL WTB 97+ Fogs
- CA FS: 97+ Vertex front lip and carbon fiber wing
- CA Driftmotion T-57 1jzgte single turbo kit
- KY FS: 1jz Cylinder Head, other misc. 1jz stuff
