View Full Version : SC400 / 300 Classifieds
- Need A Door For SC400/94
- FS: Griffin and Soarer emblems, brand new--San Diego/Los Angeles
- WTB: W58 95+ Shifter
- WTB: Oil Filter Bracket
- WTB: TRI-STATE AREA a 2jz-ge Motor
- WTT/FS: My 95-96 taillights for your 97+ tails
- sc300/400 new double din kit $15
- FS SOCAL ONLY: 92-94 sc300/400 tailights good condition
- FS: JDM Griffin Emblem Red
- WTB: sc300 a/c parts
- F/S OEM SC400 Drive belt tensioner
- SUPRA OEM Auto TT rear pumpkin & Auto TT axles
- H3 3000k HIDs
- lexus sc300 5speed 1jzgtte need gonee!!!!!
- v160 flywheel, v160 oil, v160 ACT clutch, sc300 driveshaft and more stuff
- FS: SC300 radiator in excellent condition
- FS: Mark IV JDM 440cc injectors, rail and FPR
- WTB 97+ Front bumper (NYC)
- WTB 92-95 gauge cluster
- sard boost gauge w/ SARD POD 60mm
- SARD BOV universal
- wtb interior door handles for SC300.
- 2jzge Intake and MAF
- WTB: Daizen Sway Bars
- 1jzgte singleturboed motor partout,emanage blue,apexi muffler,twinturbo dp,cusco cage
- Wtb black volume knob sc400
- F/S - SC300 5spd transmission, no bellhousing + apexi VAFC 2
- ls400 brake kit
- FS: C's Short Shifter Soarer/Supra
- *** R154 tranny, 1jz bell housing, HPF Bronze clutch kit ***
- WTB: 1992 sc4 tranny!!
- ***Demon SuperMade COMPLETED Satin black lowbeam HEADLIGHTS fs!***
- WTB: 3" MAF Adapter...
- F/S: Eibach Pro Kit for Sc300/supra
- WTB: R154 Driveshaft, LSD, Short shifter MK3
- F/S*2jz ge from a 1997 sc300 w/ auto tranny
- WTB: Ring / Pinion Gear (Final Gear) SC300 / 400
- MK4 supra TT Injectors & rail
- soarer harness 1jz uncut
- WTB: sc300 auto instrument cluster
- wtb sc400 gated-shifter asap
- WTB: Cheap Headlights
- WTB DS AND PS DOOR PANELS upper and lower
- TWO Ignitors: ONE 1UZ and ONE 2jz-ge $40 shipped
- drivers side head light
- WTB: 97+ Tail lights
- FS: 1992 SC400 Auto Transmission
- WTB - 2JZGE (NA) w58 bellhousing + flywheel
- WTB ASAP: v160 swap
- WTB : Aristo JZS161 / Supra 2jzgte vvti MAF Meter
- WTB Stock 1JZ Flywheel
- wtb auto shifter assembly , radiator, powersterring pully
- FS: 7 Tein HR Coilovers MKIV TT Steering Wheel CHEAP
- wtb sc300 clutch!!
- WTB 92-95 SC300 Engine harness
- FS: Front Brake Calipers
- WTT: black 99 rear bumper + skirts for black vertex/JIC
- WTB: Coilovers and Rims
- FS: 2 Chrome Exhaust Tips (Slash Cut)
- Wtb soarer head complete
- fs:head unit
- FS: Supra Eibach Pro-Kit/Stock Supra Shock Combo
- WTB Sc300 A/C condenser
- WTB W58 Tranny
- WTB: SC300 MT Driveshaft
- 1995 Lexus SC300 for Sale with reasonable offer
- WTB: Magnaflow 14827/14829 mufflers
- 97 sc 300 tanabe nf210 lowering springs
- jdm twin turbo from a aristo
- e-manage ultimate harness
- toyomoto intercooler
- 98 ls400 calipers and rotors..
- WTB: 95-96 SC Tail-light (pass side)
- WTB: Drivers Door Mirror (met. green)
- WTB: 97+ side skirt (met. green)
- **Looking for 95-96 Taillights!**
- **FS:SC300 & 98 Supra Parts with PICS***
- 97 300 - wtb
- WTB OEM Shocks SC300
- wtb 400 parts any jdm parts
- WTB 1JZ Flywheel
- Need help pleaseeee...(WTB Carpet)
- WTB:Autocouture front bumper
- FS SoCal: SC300 driver and passenger seats
- rsx type s seats
- F/S: New drivers side door hinge
- 1998 sc400 speed o meter Bay Area, CA
- pte 61mm turbo like new cheap
- WTB: new brake setup
- Wtb: 1jzgte harness ( soarer )
- WTB 93 sc300 gauge cluster... 5 SPD
- WTB 1JZ Flywheel
- FS: S.FLA OEM SC3 Springs, Shocks
- WTB: 97 passenger side skirt and moulding
- LF: shocks for my sc400
- LF: lowering springs
- FS: LS400 4 Piston Brakes - BBK
- FS Lexus Sc400 Fuel pump control relay
- Clutch Pedal & Master Cylinder
- WTB: CLEAN 99-00 low beam headlights
- WTB: 5 speed tranny
- I need Altezza Taillights! (No, seriously!)
- WTB Daizen steering rack bushings
- Tons of parts, big and small, post up - if I have it, I will respond
- WTB: Cigarette lighter assembly
- Jic bodykit for sale
- F/S sc300 stock exhaust
- 4.08 rear diff, open
- FS: MK3 R154 Front Driveshaft/ SC300 5 speed rear and rubber donut.
- Sparco Reclinable, Suede black, and gray..350 New Seat
- FS: VERTEX front lip BNIB
- FS: R154 front drive shaft
- Free oem sc300 catback exhaust!!
- free 92 rear bumper and broken cluster tampa fl
- WTB: 5sp Driveshaft, Console Trim, Crossmember
- 95 sc300 (WTB parts)
- Any idea where I can find? (WTB Power Steering Pump)
- Parts needed!!!!!!
- Veilside CF Over Fenders (Make your SC wide!)
- FS: 5-speed conversion
- Zenki clean out!
- Free SC300 Interior Parts
- fs: lexus ls400 (1999) 4 piston calipers
- FS: built 2jzge, cp, acl, arp!
- WTB: 5spd Shifter Trim and shift knob.
- my 2JZ
- FS: sc400 cross drilled and slotted rotors
- FS: Slave & master cylinder
- FS: SC Cluster (Refurbished) and BCC (Repost).
- wtb 97+ grille
- Does anybody have a driver's side quarter panel for sale?
- injector resistor pack for 2jzgte - 6 output
- WTB 1j/2j map sensor
- WTB: front catalytic converter
- FS AAP Fan Kit with Chromed Shroud
- WTB: twin disk clutch
- WTB passenger AC vent/ blk rearview mirror
- 1999 SC300 parts for sale
- Fs: Na-t turbo kit
- WANTED - Supra Turbo Rear Brakes
- TRD Engine Mounts
- WTB: Tan door panels and bottom plastic from seats
- ***FS: CLEAN & CLEAR RH Headlight from 2000 SC300***
- FS: Fluidyne Radiator (BNIB) for MKIV Supra NA/TT but will fit SC300/400
- WTB: W58 driveshaft and shifter
- WTB - Side Skirts
- WTB: Driverside Front Brake Caliper Bracket
- WTB: IDLE AIR CONTROL VALVE (IDLE SPEED CONTROL) SoCal
- WTB: Need High Pressure Power Steering line
- FS: 1jz longblock + ECU or parting out
- FS: SC400 parts (OEM, some aftermarket)
- F/S NA-T items
- Would anyone be interested in buying...
- ***Brand new Drewgo manifold 2jz-gte***
- WTB: STIFF Rear suspension
- WTB: Hood, pass. fender, misc
- FS: ETS Pt61 turbo kit, with FMIC.
- FS: Used-Good Condition OEM Tan Leather Front & Rear +
- FS: Supra TT front oem sway bar: $75 + s/h
- W58 tranny with act clutch+Fidanza Flywheel
- High pressure power steering fluid line
- WTB 2J W58 Bellhousing
- 1j manifold
- HKS Boost controller / PLX DEVICES wideband
- 95 sc400 rear bumper
- sc300 400 stering wheel with airbag
- Genuine Glass SC high beams and other SC parts for sale
- 6 speed front driveshaft, auto tt rear driveshaft, slave cylinder, clutch/flywheel
- FS: Q45 Throttle Body
- WTB Stock Exhaust for 95 SC300
- WTT Driver side headlight for passenger side
- Wtb: Sc300 lip, headlights, left fender
- WTB hood hinges driver side head light etc.
- FS: New Drewgo 1JZ single T4 manifold
- 95-96 tail lights
- WTB - 95-96 driverside tail light
- WTB Tan Door Panel
- WTB Cheap Stock Air intake box for '98 sc3
- FS: complete SC300/400 5spd Swap.
- FS:Motors For Window Regulator...
- FS:Defi boost gauge
- FS:Nardi woodgrain steering wheel MINT
- FS: 95-96 Tails with Module
- FS: 95 Lexus SC passenger side tail light
- ABflug Coilovers *FL* Cheap
- wtb 2jzgte clutch fan
- precision 61 mm turbo cheap
- FS: Blitz Single Exit Exhaust
- FS: Soarer R154 transmission
- WTB: black 92 OEM spoiler w or w/o LED
- WTB: sc300 fan shroud and fan
- TB coolant hose
- Hks 3" full catback exhaust
- FS: Pair of schroth 3 point harness
- FS: Black Int Partout
- 93' sc400 gray poly front bumper with lip
- Supra Twin turbo Brakes
- FS: tan interior from 1993 sc300
- WTB Dash trim piece
- ***FS: a Pair of OEM SC300/SC400 engine MOTOR mount, PERFECT***
- ***FS: 92-00 Lexus SC DASH Center Airvent w Trim, VERY RARE, NO CRACK***
- FS:sc300 passenger side seat rail..
- FS:JZZ30 SC/SOARER Tanabe hyper medalion mufflers RARE
- WTT:Socal: Athuntic Vertex Front Bumper for 97+
- FS: 97+ RH tail lamp
- wtb: roof spoiler new or used
- wtb: side mirrors w/ blinkers
- pre-97 lip, headlights, ls400 conversion, boost controller etc....
- wtb: 92-96 (flush mount) trunk spoiler
- wtb: auto couture body kit new or used
- SC400 Kingsborne Wires caps and rotors
- Anyone Selling OEM SPRINGS???
- Supra Seats Tan
- ~ WTB 2JZGTE Short Block ~
- WTB: Coil
- FS: 97+ Tail Lights Upgrade w/ blinker module
- FS: Auto Couture body kit NEW
- t60-1 turbo kit
- NA Header
- WTB: reusable air filter for factory air box
- FS:JDM Mark IV 2JZ-GTE twins and 440cc injectors/rail
- Parting out SC400 TORONTO area !!!
- WTB: Fender Liner and Splash Guard 97+ SC
- F/S: 97+ front bumper
- F/S 97+ side skirts $350 shipped
- WTB: 1jz Soarer engine harness
- WTB: t4 turbo NA-T
- FS D2 coilovers MK4/sc300 600 shipped
- 92-93 alternator 5k miles on it
- **93 SC300 Part out,lots of good part & clean spruce interior!!!
- WTB w58 Transmission
- WTB: grey door panel
- wtb vertex back bumper tested and fitted.....
- WTB\ITB: 97 Tails
- Wtb: Sc400/300
- WTB air intake/filter
- wtb stock sc300 bellhousing
- Wtb PS lines for sc300 so cal
- FT/FS clean 92 lexus sc400
- WTB: 92-96 sc400 locks and key
- ***Gathering interest!! possible part out!!***
- WTB: Suspension
- WTB 1JZ to W58 Bellhousing
- WTB: Trunk Lid *SoCal Preferred*
- brand new seibon ts-ll carbon fiber hood, never installed
- WTB: OEM 5spd shift knob, sub cover + more
- J magic rear bumper lip, brand new in package
