PDA
View Full Version : SC400 / 300 Classifieds
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139
  1. NY FS: 97 SC Partout
  2. TN WTB: 92 SC400 Knock Sensor Harness
  3. NC WTB Wastegate
  4. FL FS: 1JZ to 2JZ ECU Harness & 2JZGTE GForce ECU
  5. GA FS Super Single OS Giken with push pull conversion kit
  6. CT ISO Sc400 auto trans
  7. TX 2005 Lexus is300 Manual Steering Wheel with Airbag
  8. CA ISO Front Camber Bolt
  9. WI wtb 92-96 front lip for sc300
  10. OR WTB LS400 brake front calipers
  11. FL F/T Aristo ecu trade for 2jzgte 6speed ecu
  12. CA WTB: NA-T turbo kit
  13. NY wtb black passenger window trim uncracked
  14. FL AEM V1 FOR SALE, aem serial gauges, vpc/gcc/jumper harness
  15. MN WTB center radio/controls harness
  16. CA FS: front and rear tt brakes with pads and new slotted rotors
  17. MI 97+ various parts.
  18. TN 1JZ/R154 partial part out (performance goodies)
  19. NM WTB: Nakamichi head unit
  20. In need of a radiator
  21. IL FS: 2JZGE / 2JZGTE OEM Toyota A/C Compressor Sensor
  22. IL FS: OEM Toyota Supra Repair/Maintenance Manuals - Elec, Chassis, Engine, Etc. $100
  23. IL FS: OEM Lower Control Arms (LCA) / Ball Joints - 5k miles - $250 shipped
  24. IL WTB: Black Carpet!
  25. AZ Wtb: 92-94 sc300 ecu
  26. CA FS: LS400 BBK with NEW Slotted Rotors
  27. WI wtb: sc300 black housing headlights
  28. TX LS1 Swap Parts
  29. International WTB - 4.3 Lexus SC300 - CWP from Differential
  30. AZ FS: Factory Service Manual '94 SC300/SC400
  31. CA FS: JDM Oem Toyota Soarer Window Visors
  32. CA WTB Basic NA-T FULL TURBO KIT SET UP $$$
  33. FL FS: Megasquirt v3
  34. SC WTB: ISC motor
  35. NJ WTB: stock radiator/clutch fan/shroud
  36. TX FS: BRAND NEW Borg Warner S366 Turbo
  37. FL WTB passenger door molding 97-00 lexus sc
  38. CA FS: ES300 Woodgrain steering wheel with airbag
  39. PA SC400 Power Steering pressure line, Hydraulic Fan and parts.
  40. VA 97+ Tail lights
  41. TX FS: 2JZGTE Aristo AC Compressor
  42. VA FS: 550cc injectors
  43. OR new act w58 clutch and pp
  44. CA FS: FIC1100cc Injectors hi-z
  45. OR FS:1jz igniter and map sensor
  46. GA WTB: Soarer Griffin Emblem and Bubble Side Markers
  47. CA WTB: SC300 NA-T Intercooler Kit / Piping and Core or fabricate me one? will pay!
  48. NY FS: 97 Body Parts
  49. CA FS: 92 White Sc300 bumper
  50. KS WTB Tan E-brake shifter boot and 5 speed shifter boot
  51. TX FS: Titan Motorsports 3500 Stall Converter
  52. NC WTB Q45 Throttle Body
  53. GA WTB: 92-94 SC300 A/C Line
  54. NM SC400 parts for sale: Floor mats, door actuators ECT
  55. IL FS: AEM TruBoost, AEM Wideband, TRD Shift Knob, IS Steering Wheel
  56. KY Fs: 2jzge
  57. CA FS: TurboSmart FPR, 2x VVTI COP setup, R154 slave
  58. WI WTB: black housing for headlights and highbeams
  59. CA WTB: NA-T Intercooler Piping
  60. TX FS: Boost Lab Extended Oil Drain Flange (-10 AN)
  61. TX WTB 1UZ Flexplate
  62. CA Daizen sway bars - Socal - 91770
  63. TX Complete trans cooler setup w/ gauge, various fuel lines, an fittings, oil feed etc..
  64. AZ FS: gated shifter and climate control
  65. MN 97+ OEM Front/Rear Bumpers & Front OEM Headlights
  66. CO looking for ECU Pins for TT ECU mod
  67. CO WTB Honda S2000 Antenna Assembly OEM
  68. TX FS: 2JZGE Fan Blade and Clutch Combo
  69. TX WTB: Tan center arm rest & felt lined console box
  70. NY FS: 1jz harness, 2jzge parts
  71. CA FS: Sc300 Tanabe NF210 Lowering Springs
  72. NY Rare IS300 5 speed steering wheel $180 shipped
  73. TN Wtb: 1992-1994 sc400 ecu
  74. NY FS: 97 Foglight Pigtails with Black Caps
  75. NY FS: 97 Grill
  76. CA FS: Wise spoiler,Black housing headlights, AEM failsafe gauge, Apexi AFC Neo & more!
  77. IN 2JZGE/Auto Complete Motor (Wiring harness, ECU, etc.)
  78. GA FS Aristo 440cc injectors
  79. NY FS: 97-2000 Rear bumper and extensions
  80. PA Garage Cleanout.....W58, Clutch, 2JZ flywheel, Interior, etc.
  81. CA UAS Air Suspension
  82. CA WTB: Supra Rear Calipers and 97 Big Win Lip
  83. TX 95 NA-T part out!
  84. PA SC300 power steering resevoir
  85. PA untorn rear seat
  86. WA Wanted Fuel Pump Ecu & Ignition wire clamp
  87. GA WTB: Airbag Adapter
  88. CA WTB: 97 Big Win Lip
  89. CA FS (SoCal): 97+ Front Bumper, Glass Highbeams, Plastic Highbeams, etc.
  90. TX FS: 1JZGTE JZZ30 Engine Brackets
  91. WI wtb: sc300 driver fender oem
  92. NY NA/T parts needed! SAFC, TT ECU or Standalone, AEM, Fuel Setup, Boost Controller, ETC
  93. NM For Sale: Drivers side door actuator
  94. CA wtb: volume/climate control knob
  95. NY FS: Pair of Uncracked Upper Window Trims in brown
  96. CO WTB - OBD1 Lower Intake Manifold Runner and Injectors
  97. CO WTB/ Need To Buy 440cc injectors
  98. NY FS: cluster for parts
  99. NJ dura flex rear lip and side skirt
  100. NY FS: 2JZ-GE Engines - parts available as well -
  101. NY FS: 97-00 Pass Tailight with harness
  102. PA 99 SC400 door moldings
  103. TX AMS LSx Mount Kit - $800 shipped
  104. CA WTB : Solid bushing for rear subframe and rear differential
  105. PA Selling Tan Parts, Most in MINT Condition! Highbeam Trim, E-Brake, Radio, More!
  106. AZ AR5 Transmission setup for your SC
  107. NY FS: 97 SC3 Partout
  108. WA Wtb - ls400 bbk
  109. TX FS: NA-T partout..need to move this stuff ASAP
  110. SC WTB 1jz
  111. VA Complete OEM Struts Front and Rear.
  112. NY SC400 Partout
  113. FL F/S set of 6 1jz 2jz gte coil packs
  114. MI Wtb 95-96 or 97-up tail lights
  115. MI WTB 92-95 1UZFE crank trigger wheel
  116. CA FS. SC clutch and brake pedals - SoCal - 91770
  117. TX F/S tomei FPR
  118. NM WTB: Random items, door actuator, floor mat
  119. CA WTB: JDM sidemarkers / LS400 BBK / Supra Seats / Woodgrain Wheel / 97+ Lip and MORE
  120. CA 2JZGE EGR block off Plates / New SC300 Trunk Shocks
  121. CA Wtb: R154
  122. CA r154 package! trans, clutch, flywheel, 3.5" driveshaft
  123. NY FS: 96-96 Tails with harness and ecu
  124. MD Supra/SC 2jz parts for sale
  125. CA LS400 Calipers with all hardware P&P
  126. CA FS: Tan 3 spoke steering wheel with bag
  127. International WTB SC300/400 e-brake with boot in BLACK
  128. CA DaveH Polished PT61 Turbo kit, Map Ecu, MC R154, Rebuilt 2jzge 1.3mm HG
  129. WA WTB: 96-97 Manual ECU
  130. CA Misc oem black interior parts FS
  131. CA SC300 Cusco Strut Brace
  132. PA FS: AEM EMS v1 for 2jzgte
  133. CA WTB soarer downpipe for stock twins and intercooler piping
  134. TX 2JZ Short Distributor Cap
  135. CA Irvine - Greddy Radiator AirFlow Shield - Greddy Oil Filter Relocation Kit
  136. AZ WTB 1JZ to R154 Flywheel
  137. OK FS: Black/Wood 02 RX Steering wheel/airbag combo
  138. TX FS: Tan Passenger Door Panels x2
  139. NM WTB: Passenger A-Pillar in tan
  140. AZ FS: 2JZGTE Twin intake pipe kit
  141. CA Irvine - Inside Door Latch - Driver and Passenger
  142. TN WTB: TRD LSD SC/Supra Diff (Whole Pumpkin)
  143. PA WTB: TRD strut bar for Supra
  144. CA 97 tail lights $120 - Socal 91770
  145. NY FS: Rideskinz front lip
  146. FL Reupholstered Grey Seats Central Florida
  147. GA SCX00 Battery Tie Down
  148. CAN-Vancouver fs 97 sunroof control module and motor and front camber arms
  149. MD 1/2 JZ Knock sensors, Map sensor, Injectors, throttle bracket
  150. FL WTB: SC400 drive shaft & differential flange
  151. TN WTT Volk GT-P 18s for SC goodies in South East
  152. OR WTB sc300 body plug
  153. WI wtb: precut bfi air box
  154. OR WTB 1jz stock BOV
  155. ( wtb) obd1 engine harness
  156. CA Irvine - Daizen Front Upper Control Arm Poly Urethane Bushings
  157. NY FS: 95 SC300 Partout
  158. IL FS 97+ tail lights with harness, LED bulbs
  159. LA FS: Eaton M122
  160. TX Rear Seat Belt Buckle Cover (Tan)
  161. FL FS: SEM Landau Black Paint
  162. CA WTT: Black 92-96 Trunk w/wing for black wingless trunk
  163. FL wtb mint condition drivers side upper seat foam
  164. FL Fs: 97+ headlights,tail lights, emblem
  165. WI WTB: OEM Soarer window visors
  166. CA FS - Stock struts
  167. MD FS: 2jz-ge motor
  168. CA WTB : sc300 non vvti auto transmission with torque converter.
  169. In search of 3rd Gen 3sgte mr2 turbo injectors and sc400 differential
  170. GA WTB soarer wiring harness
  171. CAN-Toronto Wtb rear 50mm over fenders k&m
  172. GA 2JZ-GTE 3800 Stall converter
  173. CA Rear Hawk Brake Pads Supra TT
  174. CA MY LOSS YOUR GAIN - Whiteline Adjustable Supra Swaybar
  175. GA WTB: 97+ Front bumper
  176. NY Fs:brand new 2jzgte cp pistons with upgraded pins
  177. WTB: need rear speaker covers
  178. wtb bc racing coilovers for 98 sc400
  179. CA wtb: ge ps reservoir LA area
  180. TX Vertex Clear Sidemarkers
  181. MD Garage Clean up, alot of parts AEM EMS/V160/ R154
  182. WI WTB: sc400 oem lip
  183. CA SC300 front brake calipers and drilled/slotted rotors. Only $30
  184. CAN-Toronto **WANT TO BUY**SC400 differential 1992
  185. NJ WTB parts for 97 sc400
  186. CO WTB 97+ grille and fogs
  187. NY FS Clear Side Markers
  188. TX Sc parts sale. Daizen tein stoptech
  189. TN WTB 93 SC300 rebuilt ECU
  190. PA wtb for my 98 sc400
  191. NY FS: Black Radio Surround, Buterfly cupholder
  192. GA WTB Climate Control
  193. CA FS - Holset WH1C Turbocharger, Brand New Not Used (NO REBUILD NEEDED!) - $550
  194. TX batlle version rear spacers....ALL OF THEM!
  195. CA FS sc grill 97+
  196. AZ FS: Soarer extension
  197. MD WTB A Limited Slip Differential for My sc400
  198. NY FS:2jzgte Brand new BC crower rods with arp hardware
  199. AR FS: 1993 SC300 FSM Vol 1
  200. CAN-Toronto 92 SC400 Transmission for sale 400$
  201. WA WTB: Seat mounting tabs
  202. PA WTB 95/96 Front bumper cover Assy
  203. FL F/S Tan interior
  204. TX WTB: Passenger Side Door Panel
  205. FL f/s custom oem high pressure power steering line ,oem low miles crank pulley
  206. MD WTB Read packing shelf in brown
  207. AZ Garage clean out
  208. CA WTB: Platinum silver Pasanger Fender and A Lip for 97+ Bumper
  209. TX Megan Racing LP Coilovers
  210. PA WTB: 92-94 or 97+ Front Bumper
  211. PA Sparco Bracket and Slider.....Drivers side..
  212. FL FS: GForce ECU,MAP ECU1,Turbonetics Turbo,50MM Wastegate,Black Pillars,Shift Kit...
  213. IL Cam Gears
  214. CAN-Toronto WTB: Clutch Pedal and Brake Pedal
  215. MA WTB: 2jz-gte valve covers
  216. MK4 Supra USDM 6 Speed Rear Diff
  217. CA Brand New OEM GTE Crank Sensor $85 Shipped
  218. IL Wtb Interior pieces rear lower seat TAN
  219. CA black door panels/black carpet/black steering wheel
  220. CA FS sc grill 97+
  221. WI WTB: oem lip for 92 sc300
  222. NY FS: Engine/Trans Blow Out, 6s and 8s
  223. CA CA: Tan Interior Parts Located in Orange County
  224. CA sc3/4 trunk spoiler >>>
  225. CA WTB : SC400 oem lip
  226. NJ WTB 1997 sc400 TC and trans lines
  227. LA WTB: Gated Shifter
  228. GA FS: Stance coilovers, BNIB. Local pick up preferred.
  229. NC WTB Ride Skinz Rear Lip & SAFC
  230. CA WTB: Aristo ECU
  231. VA WTB W58 flywheel and clutch cover/diaphragmdiaphragm/pressure plate
  232. CA cusco strut tower bar
  233. FL v160 clutch
  234. CA WTB: SC300 EGR delete
  235. CA WTB: Wood grain steering wheel
  236. PA Need the following parts with part numbers
  237. WI WTB: sc300 95-96 taillights and more
  238. NE LS400 brake calipers.
  239. CA Tanabe Sustec lowering springs BRAND NEW
  240. FL FS: Garage Clean Out
  241. PA WTB 1jz engine
  242. NC Toyota DS62 Igniters with Pigtails for TT ECU Mod
  243. CA FS: OEM Side marker lights
  244. CA FS: 1992-1994 SC300/400 Corner Light Assembly
  245. GA WTB: 2jzGE ODB1 ecu
  246. NY Wtb tial 50mm bov
  247. CA fs: full black interior (CHEAP)
  248. IL JDM Aristo 2JZGTE Twin Turbos & Automatic Transmission
  249. TX WTB MKIV Supra Front LCA's
  250. KY WTB: 97+ goodies
