View Full Version : SC400 / 300 Classifieds
- CA FS: TwinsTurbo 2JZ Dry Sump Kit
- MO WTB Antenna..
- GA WTB - stock 1jzgte fuel rail
- MA W58 (68K) Swap For JZ or 1UZ (with adaptor plate) + KA to 1UZ Swap +Manual ECU 4 Sale
- PA WTB: O2 Sensor (Front)
- TX Free SC300 Stuff....getting rid of all my spare SC300 parts
- PA Aristo 2jzgte ECU
- VA SC300 clutch pedal and brake pedal set
- CA getting rid of all my lexus stuff! lots of aftermarket parts!
- NY sc300 parts
- FL WTB: 2JZ-GE stock injector set
- GA FS GTE TPS and Beech Q45 TPS adapter
- FL 2JZGTE CP Pistons, 10.5:1 C/R, Bored .20 Over with Upgraded Wrist Pins
- MA Complete Daizen poly bushing set, Moog rubber bushings, radiator cap
- CA WTB black steering column cover & stereo surround (cup holder,etc)
- NM WTB: SC400 Driveshaft flexplate coupler and carrier bearing
- NJ FS/FT Vertex rep side skirts and rear bumper
- NY 1UZ/W58 Swap kit-$350 SC300/W58 Drive shaft w 68K, NA Miles $150
- VA WTB stock 2jzge,trans,harness, and ecu
- WA WTB - 2JZ-GTE Swap Parts
- FL WTB:SC300 fan shroud
- CA Looking for Splash Guard 4 97SC400
- CA FS:Brand New Sc300/2jzge Mantience Parts
- GA Wise Spoiler
- CA WTB Throttle Body 1998+ SC300
- CA Wtb cheap sideskirts and front bumper
- MI HIC roof spoiler
- FL full blown 342 fuel pump brand new
- FL 5spd pedal set w/master cyl, w58 drive shaft
- UT For Sale LXCC LCD climate controller BNIB Never used!!
- IL WTB: pass side inner trunk liner w/o cd changer
- SC WTB 1uz auto bellhousing
- OK 2000 SC300 A340E Automatic Transmission (109k miles)
- FL wtb: rear coilovers
- OK Complete 2JZGE Rear Sump Oil Pan
- MA W58 Transmission 68K Babied, Verified Miles $775
- CA FS: Wingless green Trunk w/emblems *pickup only San Diego* $100obo
- International WTB: Black Steering Column Cover
- CA FS 95-96 tail lights - Socal - 91770
- CA 1998 SC300 black steering wheel + airbag
- VA Center Driveshaft Bearing for SC300 & MKIV Supra
- CA brand new hks twin power
- NJ Wtb carbon fiber trunk
- CA WTB: Door wood trim
- CA FS: Brand New SC300 T70 Turbo Kit / Everything you need to go NA-T
- MD interior, door panels, lights, downpipe
- FL Aristo 440cc injectors
- NH Garage Cleanout
- MO WTB: 2JZ Power Steering Pump, Alternator, A/C Compressor
- CA WTB SC400 PPE Headers
- GA 97+ Fog lights, black 3 spoke steering wheel
- PA WTB...97+ Front Bumper....Any Color
- CA WTB: 3 Spoke Steering Wheel preferably black
- NH WTB driveshaft for my sc300 to supra auto
- IL WTB: black carpet
- CA Complete R154 Swap
- TX WTB: 93-98 Supra TT rear calipers
- CA WTB: Brake booster
- NY WTB:R154 Swap Parts Needed. slave, master, mount, extension, drive shaft, release hub
- CO WTB Door trim wood
- Throttle body complete gs300 - sc300 - is300
- MO Misc Swap Parts & 2JZGE Supra Stock Air Intake
- TX Garage Clean Out Thread! Cheap parts!
- FL Rear Sump Oil Pan 200
- In need of sc400 1uz rear style oil sump assembly
- FL PHR j&e custom spec'ed pistons, HKS gtII wastegate 60mm, precision injectors 550cc
- International WTB: Supermade clear lenses or similar
- TX WTB 97+ OEM Sideskirts, Rear Bumper or Vertex Replica body parts...
- FL C's Short Shifter for late model Soarer R154
- MI WTB: R154 Parts
- MI WTB 97+ fujin lip or other style
- FL is300 st wheel,water pump ITC SAFC2 Black plus more
- CA WTB A few parts
- OK LS400 Calipers and Drilled Rotors
- CA Powered By Max wheels spacers 30MM
- WA Selling 95 tail lights great condition
- need vapor shields!
- MD Open Differential Unit Without Ring Gear
- CA WTB: Parts from W58 transmission - retainer plate & tripod shifter bracket
- CA FS: Origin side skirts and rear bumper
- CA SC300 Random Parts For Sale
- TX 2jzGTE Radiator Hoses New
- CA WTB: factory tan floor mats
- FL Atf stage 3 supra tt auto and atf 4000k stall converter brand new 0 miles!!!!
- KY garage clean out 5 spd parts 97 parts
- PA WTB: Used Coilovers
- FL WTB front and rear alignment cam bolts.
- GA Need rebuild service on engine ECU
- NY Wtb: Vvti coils & other jdm tt ecu mod parts
- 1995 sc300 wtb fan shroud asap!
- CA WTB: Driver side Door/Panels/Fender/Window/Hinges etc
- PA WTB R154 flywheel
- PA WTB: dual 3 inch mid pipe back or 4 inch exhaust
- PA Leftover Parts Sale....Interior, Seats, Door Panel etc..
- TX WTB SC400 engine harness
- NY Want To Borrow! - 95 SC400 ECU
- TX WTS: aristo ecu, AEM truboost,black interior, grey dome light, gated shifter
- TX SC300/400 Black Interior Parts and Misc.
- NY Black Seatbelts
- VA SC400 interior parts & intake (pics)
- MO Garage sale - LS400 BBK, FMIC and oem FREE things..
- GA 1997 SC300 Door Moldings
- IN WTB: W58 jz bellhousing
- IL WTT: AEM 30-4100 w/ LSU4.2 for EGT sensor
- NY 2jz th400 swap
- FL tan butterfly cup holder 35.00 shipped
- FL WTB 95-96 left driver taillight and glass pass high beam
- CO WTB 1993 fuel guage
- TX FS: 2jzgte PNP swap harness for SC300, Tial, RC 550 injectors
- CA Wtb Strut Tower Brace and Exhaust for Sc300
- VA FS: HKS EVC VI Boost Controller and Boost-by-Gear Software
- VA FS: MAPECU-3 w/ Boost Solenoid
- PA Supra Lower Control Arm
- CA WTB: 97+ right side lower door moulding
- GA WTB: sc400 Gauge Cluster
- NY wtb: bov ands waste gate
- WI JDM Soarer driveshaft
- IL WTB: black carpet, black door panels, other black interior pieces
- GA WTB 92 sc400 ecm 89661-24240
- DE FS: Black oem steering wheel and airbag. Not dyed!
- IL FS: 1996 Grey Carpet
- CA WTB: 93-2000 SC passenger side A/C vent assembly
- IN Blacked headlights
- FL F/S W58 transmission
- CA WTB: Coolant Reservoir 1995 Lexus SC400
- CA 4 Spoke Air bags 1 Black and 1 Tan
- CA LS400 Rotors Drilled/Slotted
- NY wtb dwp wingless trunk
- CA FS: Custom Air Suspension Complete adjustable Air Strut
- CO Megan ez street coilovers
- PA SC400 Firesale: W58, TV8 adapter kit, adaptronic
- CA LS400 front calipers and pads
- CA FS: REAL JDM Window Visors
- NH Ds62 ignitor
- CO sc300 Window Pillar Garnish
- NY FS: 98 SC400 Partout
- AZ FS: New/Open Box Precision 6165S Turbocharger
- NH Wtb: obd2 2jzgte ecu
- NY wtt green wingless trunk for a dwp wingless trunk
- AZ Ls400 frt calipers and rotors tt rear calipers with rotors
- CA EDFC for sale *cheap
- TN WTB: MINT Driver's side headlight and center dash vent
- NJ Blitz NUR Spec R Exhaust for SC300 - (Brand New)
- CA WTB: used coilovers
- FL WTB tan dildo matic shift knob
- FL WTB good center and passenger side vents for 94
- OR WTB 95-96 sc300/400 tail light harnesses
- CA WTB: Tan Door Panels, Headlights, Supra Seats, and Climate Control
- TX MKIV Toyota Supra TT OEM Springs
- MD Used W58/2JZGE Flywheel, Pressure & Friction Plate
- GA 2JZGE non-vvti rebuilt block, head, and extras
- GA Altezza 3-spoke steering wheel, manual version.
- PA Used W58 Competition Clutch Stage 4...Cheap!!!!
- CO Mirror ECU
- CA FS: M1 Stainless dual Exhaust
- CA SC300/400 Custom built Air Struts with Universal Air Bags
- GA FS Early Saorer R154 non tripod trans swap
- CA FS: DG-5 Coilovers
- GA SC300 Maintenance Parts - FREE plus shipping
- CA WTB GTE a340e J3 bell housing
- IL Hks ssqv4 bov
- GA Fs sc300 fan shroud
- IL 1JZ Swap Parts: ECU's, ignitor, MAP, P/S
- CA WTB: Wise spoiler
- MO FS 3.26 Big Diff/6spd axles/TT brakes/TT rear sway bar
- NY FS: MISC Parts CHEAP
- LA FS: Weld Rears and Tanabe Lowering Springs
- IA Tuning Parts: SAFC NEO, AEM F/IC6 30-1910
- CA FS: Black four spoke sc300/400 steering wheel
- NM WTB: Coilovers for my SC
- IL Intercooler setup for 2JZGTE stock twins SC300/400
- CA Full air suspension system for coilovers with cash on top
- IL FS: MKIV TT Power Steering Reservoir Tank
- GA More Parts For Sale!!
- CA 1998 Stock SC300 5 star 16" rims+wheels
- OK Supra Bilsteins w/ B&G Springs
- Buying Repair manual
- NC WTB OBD1 GE Intake Lower Runners
- CA WTB: TPS for 95 GE
- WA OEM 97+ Side Skirts
- CA Wtb 98-00 3 spoke steering wheel / airbag
- FL WTB black steering column cover
- FL Selling 1jzgte and 2jzgte auto Ecu
- TX WTB: GS400 or GS430 diff flange
- TX garage sale - headlights, ge turbo header, misc stuff
- NY FS: Tan Butterfly Cupholder
- FL Fs: Sc300/400 LCA
- CA WTB : 1997 Sc300 Front Bumper Cover + Grill
- CA WTB:! 2jzge ffim
- FL Free Steering Rack & 18" Wheel & tire P/u only
- IL FS: Grey / Black interior parts
- CA fs 3.9 ring and pinion good condition
- FL SC400 auto drive shaft & rear diff output flange
- CA FS: '97+ Fog Lights
- IL wtb ls400 bbk 95-00
- OR WTT: Royal Jade Pearl '94 front bumper
- IL FREE grey destroyed interior Pickup
- IL Cusco Zero-2E Coilovers MKIV 93-98 Supra with E-Controller
- CA FS fenders - crash bar - head light support - cheap or scrap metal - Rosemead 91770
- IL OEM 2JZGTE PARTS....Going Single Sale
- PA FT My Silver Emblems for your Gold ones SC4
- CA FS: +97 OEM Sun Visors, Sunroof/Domelight cover from BLACK interior
- CA WTB: Sc300 Strut tower plates
- CA San Diego. All Brand New. Water pump, timing belt, etc.
- CA WTB: 97+ Fujin Lip
- IL F.S: Bullseye S372 turbo kit brand new!!!!!
- CA WTB - Griffin Emblem
- NY USDM 2jzgte non vvti coilpacks
- VA 97 + Fujin/Rideskinz/big win etc style Lip
- WA WTB: W58 transmission
- TX WTB Front Ashtray
- CA 2JZGTE Valve Covers
- NY FS: Black Interior Partout - SC4 Partout
- GA FS 2jzge TTC 268 cams with BC Springs
- CA WTB: +97oem front bumper lower grill VERTICAL BLACK PLASTIC GARNISH TRIM
- NY FS: SC300 Partout
- PA WTB.....1JZ R154 Bellhousing
- NY 5 Speed Swap - all parts to convert from auto to manual
- CA Tan Interior Parts (almost everything)
- IL WTB Ashtray assembly with lid
- FL FT: Mk4 supra torsen diff
- NY wtb: safc2
- CA FS: JDM Bubble Sidemarkers, SS Brakelines, 97+ rear spoiler
- PA MVP Motorsports Boost Cut Control Device.....$$$
- TX WTB: ebay headlights for cheap
- CA Tan Center Console - 1Black, 1 Tan 4 Spoke Steering Wheel
- PA WTB R154 MK3 Front Driveshaft..$$$$
- CA WTB: SC400 differential
- NY sc300 parts
- CA WTB BigWin Front lip
- CAN-Vancouver lexus sc300/400 parts for sale
- CA FS: 97+ Foglights (SoCal)
- CA Wtb: 95 Tail Harness
- VA WTB - 98-00 SC400 Gas Pedal w/ Cable
- FL Rare hks tt kit, fresh rebuilt turbos with warranty and coated
- GA FS 2jzgte SCxxx Harness, Aristo ECU, etc...
- TX WTB Black window switches oem
- FL FS: Serpentine Belt, R154 Pressure Plate, gte OEM Fuel Rail (Cheap)
- IL WTB: 97+ SC300/400 front bumper
- CA wtb: 98-2000 GS400/GS430 3.266 rear diff
- VA WTB - 98-00 SC400 4sp Gated Shifter
- CA FS Momo Corse steering wheel with hub
- MO 97+ gauge cluster
- GA FS Turbonetics t3/t4 with DP and 2jzge Turbo Mani
- IL FS: Mines JDM 6spd ECU , SAFC II , Autosports Patch Harness
- IA WTB: ProEFI 48 705 ECU
- IL FS: RPS Carbon Carbon Twin Disk Clutch and Chromoly Steel Flywheel for V160
- IL WTB Complete Interior Wood Trim (No damage)
- CA FS: Custom Oil lines 4an feed 10an drain push lock fittings
- CA SC300 OEM Stock parts available: 2JZ Blocks - GTE PARTS - NA Head - Body Panels - MOR
