View Full Version : SC400 / 300 Classifieds
- NY WTB Supra TT shocks and Springs
- TX WTB: Driver side door panel
- CA FREE: OEM Springs with Rubber boots
- VA FS: 2jzgte Custom Turbo Kit and RPS Triple C/C
- TX WTB: 800cc to 1200cc injectors
- IN FS: OEM SC300 engine parts / spoiler
- CA fs: dual mini N1 axlebacks
- WA WTB ebrake cover
- TX Wtb 92-94 sc400 ecu
- MD JDM 2jzgte down pipe
- CAN-Other WTB: wise lip shipped to canada
- PA WTB: pair of stock mk4 front struts and springs (93.5)
- FL SC300 Headlights and Highbeams
- OH FS: 1998 drivers side mirror black heated/dimming
- CA FS: JDM 95 Soarer front bumper, 3 fenders, 97 lip
- FL F/S electromotive tec3r wired up for 2jzgte
- AZ WTB: Volume / Temp Knob Bulbs (see pic)
- AZ FS: 1998 SC300 Cupholders, Center Console and Hazard Switch
- CA FS tan door panels - glass Dr, HB - Black Switch, E-Brake - OEM outer tie rods 91770
- NY FS: Bunch of Lexus Parts - no reasonable offer refused
- FL Build 2JZ-GTE short block 1000+ RWHP set up
- FL Singled Complete 1JZGTE R154 Soarer motorset
- NC FS: Center console, MISC Interior Items-CHEAP!
- FL Greddy Boost Controller Profec B2
- VA WTB: Rear Deck 3rd Brake Light, Black Grab Handles/Radio Buttons/E-Brake Handle
- OH 1J Auto TT ECU, 4 1JZ Stock Twins, Supra Springs/Struts, Megan Springs, HID, Lip, FPR
- NY FS: NEW AC Compressor R134
- CA wtb: black center console bezel
- CA tan driverside door panel 7/10 San diego
- CA wtf 2jz crankshaft
- NV passenger door panel tan 9/10
- AR FS: AEM EMS V2 DM series. Soarer 1jzgte. New $980
- MA Wtb: American stitches wood steering wheel
- FL WTB: Front passanger fender
- WTB Clean headlights & fogs
- FL WB passenger rear trunk panel with no cd changer coutout.
- AZ WTB: Auto to 5 Speed Swap Parts
- CA Lexus sc300 sc400 oem 95-96 tail lights
- CA FS MKIV TT supra rear brakes - Rotors Calipers Pads Bolts
- CA FS Ganador Super Mirrors for JZZ30
- FL WTB Driver's side Rear Trunk Panel.
- LA FS: Garrett T4 60-1 cheap!
- NY megan coilovers$600 new
- AL WTT: 1JZ auto tranny for LS400 calipers w/pads
- TX WTT: tial44 gate for emanage ultimate
- PA Fs/ft: sc300/400 2jzgte harness w/ auto ecu
- CA WTB: Few Items Mostly Interior
- OR Wtb 97+ side front and rear!
- CA LS 400 Brakes - SC400 Front Lip
- FL HKS DLI , Igniter , Low milage Coils , s366 , 044 bosch pumps
- CA WTB: power steering pump
- NY FS: 2JZGE Engine Partout
- FL brand new:mk4tt waterpump
- OR Fs:jdm twins
- CA wtb: 99 sc300 coilovers
- TX ac compressor pulley
- CA HKS timing belt and HKS headgasket for 2JZGTE
- CT WTB: 1995 SC300 5-Speed Radiator Shroud
- WI supra 6spd LSD
- PA WTB 92-96 sc30/sc400 Blk front bumper (local Philadelphia, PA)
- I need these parts RIGHT NOW
- FL GE longblock,heads, and other stuff
- CA wtb:megan lp coilovers
- FL Complete V160 6 speed swap
- 750 HP parting out W/pics #2
- LA FS: Tial 38mm wastegate $150 shipped!
- CAN-Toronto WTB: SC 300 2jz 5spd Parts
- TX WTB: 2JZGE Complete Motor & W58 Tripod Tranny
- CA rps fuel rail, 2jz coil packs & msd dis4
- CA FS: OEM sc400 front lip
- CA WTB 97+ front bumper grill
- PA 1uzfe IMF headers
- NY Headlights and HID kit
- TX WTB: Tan Door Panels
- NV wtb: Passenger valve cover, Lower oil pan 2jzge
- FL WTB 1jz intake manifold gaskets
- FL FD RX7 Wheels
- PA WTB: Torsen diff for an automatic
- IL FS: R154 Swap + TT Auto Diff (3.76)
- AZ Fs Ls400 calipers/pads
- VA WTB: 5zigen muffler
- VA WTB: Vertex canards air spoiler side flaps.
- FL Wtb:97+ fog lights
- VA 95 SC400 Multiple Parts, Everything Must Go!
- FL SC300 (JZZ30) fan shroud/ TT 150amp Polished Alternator
- IL Pre 97 wing flush oem
- FL FS: 800cc Denso Side Feed injectors Drop-ins
- CA Sc400 Pass Seat door panel radio speakers amp cd changer oem
- CA WTB-96 ac line
- CA (Cali) Nology Hot Wires Hyper Ground System Headlights
- CA WTS: Garage clean up
- FL WTB vertical windshield trims in mint shape
- CA WTB OEM sc400 wheels
- CA stock W58 clutch
- CA buying soarer badges / OEM mud guards / steering wheel
- CA Complete 6spd mkiv supra rear subframe. Diff, axles, sway, brakes, hubbs, everything
- SC Injector resistor packs/JDM M's K&N filter for 1JZ
- CA WTB:1998+Trunk spoiler
- PA WTB 2jzGE oil filter housing
- VA WTB: supra calipers/rotors f&r
- FL B&M universal inline trans filter kit 55.00 shipped!!
- VA WTB: bucket seats
- CA WTB: 1 WORKING Aristo 440 injector
- OR Fs:usdm tt mk4 supra oil return lines for 2jz with flange
- TX WTB: SC4 KMV Sensor
- IN 750 hp parting out w/pics
- FL 1JZ OEM flywheel.
- FL Crower rods and CP pistons with upgrade pins
- KY WTB w58 shift piston/ shift rod
- GA -----WTB-----SC400 Differential
- CA FS: OEM Unpainted 97+ front bumper & Megan Street LP's
- CA WTB t4 divided exhaust housing
- IL Tan Front seats
- TX Prothane
- IL Need vouch
- CA WTB: AC Vent good condition
- NY Wtb driver side door panel blk
- TN Multiple SC300 parts (tune up parts, fan clutch, badges, 12 changer,)
- CA wtb:shine ac kit
- CA WTB tan carpet
- FL 1jzgte jzx90 auto wire harness 80.00!
- ME SC300/Supra Ksport Kontrol Coilovers/1UZ-FE 155k mile Engine/Trans/ECU/Wiring
- MO WTB - Fuel Line
- FL JDM 1jzgte m/t wire harness 140 shipped !!
- FL Wtb : 95 -97 sc300/400 brake booster
- IL FS: Almost brand new 2JZ/1JZ serpentine belt tensioner...750 miles
- PA Wtb gray auto shifter
- VA 95 SC400 Spare Wheel/Tire
- CA FS- Daizen Rear camber correction kit pn S1-2021
- GA Wtb ls400 set front calipers & 92-94 headlights
- SC Urethane control arm bushings, high beams
- CAN-Other SC400 Cluster
- FL Interior/Exterior Sc300 / 5 speed clutch / Radio parts for sale.
- FL 1jzgte soarer, 2jzge, sc300, and aftermarket swap parts
- TX 2JZ garage sale
- TX 2JZGE KN drop in filter
- NJ NJ FS: 97+ SC300/SC400 Taillights
- PA WTB: Fuel Door and Driver Mirror
- TX R154 driveshaft for sc300
- IL 93 Lexus SC300 Part Out
- IL Lexus SC300 parts
- TX Corbeau Seat Rails(Pair)!
- GA wtb sc trunk spoiler
- AZ Fs sc300/sc400 wise front lip
- TN 2 Precision/Comp Turbo billet 6062s - cheap
- FL Full car part out including shell r154, and 1jzgte
- CA Wtb. Drivers inner door handle.
- FL FS: 2J 440cc injectors
- NY wtb w58 shifter
- TX FS: Blitz Nur Spec Dual Exhaust Complete
- FL SC stock parts
- FL FS: RC 1200cc injectors BNIB
- NC WTB: HKS BOV weld on flange
- NY SC300 Partout - No reasonable offer refused
- FL r154 shifter extension
- CA NorCal Sacramento OEM 97+ SC front bumper and grille
- Sacramento folks have 97+ SC OEM front bumper and grille for sale
- CA FS: Random OEM stuff... bumpers, electronics, etc.
- TX FS/FT HKS SSQV for TiAL 50MM BOV
- CA 1jzgte intake, Turbo, stock catback, Emanage,other parts
- FL parts for sale- stock and aftermarket (o2 sensors, fuel rail, clutch, and more)
- CA 92-96 OEM spoiler
- TX A few things for sale
- FL WTB: R154 with everything to put into a 92 sc300 that already 5spd
- NY FS: Glass Highbeams and Driver Side Headlight
- CA fs driftmotion new clutch kit w58 will ship
- VA FS: SC300 5-speed drive shaft and Master Cylinder
- MA 95 tails and some more
- FL Pair of sc300 motor mount brackets 50.00
- CA FS:turbo/blitz DTT/SAFC/HKS GCC/HKS VPC
- NV JDM obd1 Aristo ecu + map sensor
- FL Wtb 92-94 sc300 a/t ecu 89661-24310/24312/24313
- FL rear sump oil pan set up 275.00
- NC FS: Black Butterfly Cup Holder w/MISC Black center console pieces...cheap!
- NY WTB: 97+ Front Bumper
- FL Greddy E-01 BC complete, brand new 1j polished rail.
- IL Soarer Rear Badge 25, Chrome, great shape
- CA cx racing turbo kit, na-t parts [Vouched]
- FL misch 1992 SC 400 parts
- CA precision 1000cc injectors
- CA FS: Tan A pillars. Cheap
- CA LS400 Brakes
- FL WTB working 97+ 3rd brake light aka spoiler light
- FL Sc300 open diff.
- KY Black passenger seat. Good condition
- KY FS NF 210 & or KYB GR-2 great condition
- CA WTS: Sc300 calipers
- MD Left over SC parts, auto trans parts, etc. free/cheap!
- FL Sc300 Reupholster TAN SEATS FOR SALE
- TX 1UZ Supercharger for sale!
- SC SC400 Aftermarket Exhaust
- CA FS - New Denso Supra OEM 550CC injectors + resistor box
- TX Gated shifter FS
- CAN-Other Toyota Soarer / Lexus SC3 SC4 part out
- CA NRG quick release 2.0 & Hub
- TX wtb 4" intake piping
- MD Tan flipout cupholder
- FL FS: SC300 Powered by MAX Coilovers Brand New!!
- FL WTB SC3 2jz-ge exhaust manifold
- NY na-t coil pack set up $350 shipped
- TX 01-05 GS300/400 driver airbag
- CA Fs authentic vertex full front bumper
- CA FS: Clear Headlights, Supra Shocks, ac vent
- NV 1jz/ 2jz map sensor, 5 speed harness
- TX Lots of parts inexpensive/Turbo
- NY MXL strada w/carbon fiber pod $900 obo
- NY FS: 97-00 Sideskirts
- NY WTB: Lexus SC400 Cats
- TX F/S: precision 67mm t4 turbo
- Need new rear end!!!
- TX WTB: USDM 550cc denso injectors
- CAN-Other FS:Hol**** HX40, Tial BOV, Bosch 750cc injectors, Greddy boost controller, lots more
- CA Black leather seats, black center console, oem lexus wheels and tires
- CA SC300/400 Retrofitted headlights with RX350 projectors & LEDs
- SC FS: R154/ SAFC2 Black
- LA WTB: 1UZ VVti stuff
- LA 2jz-ge and 1jz A/C compressor both $100ea
- GA WTT : Haltech PS 2000 ECU / 6 speed 2jzgte engine / HKS Carbon-ti Muffler
- GA WTB: Soarer 1jz uncut engine harness
- CA FS: OEM pionner radio sc300
- NC FS: W58 Bell Housing
- MA FS: 5-speed ECU
- ME WTB: 2jz-gte vvti ecu
- VA WTB 94 Intake Hose
- NY WTB: 2JZ-GE AC compressor
- FL WTB: R154 Trans, Bell housing.. etc.
- TX FS: Slightly Used Competition clutch FX300 full face kit
- PA WTB: Stock TT Springs/shocks/tophats
- NY FS: Lexus LS400 Front Calipers
- CA FS: JDM Amber Raised Side Markers
- CA WTB - OEM Front Lip for SC400
- CA FS tan door panels.
- CA WTB 1j single turbo manifold
- CA WTT: Vertex Replica Front Bumper (socal Inland Empire)
- GA Soarer Air Bag / Stock 2JZGTE Injectors
- FL WTB:Front half Driveshaft Carrier bearing
- CA fs/ft sc300/400 4pot break up grade
- MA FS: Soarer SideMarkers & Yellow Capsules
- CA 95 OEM Front / Rear Bumpers
- CA "O-Design" Side skirts and rear bumper PRICED TO GO.
- CA FS: NEW Seibon carbon fiber doors - NOW SHIPPING
- FL F/s 2 supra diffs 1 auto trd us and 1 6 spd jdm
- GA Wtb: 94 sc400 ecu
- CA band new 97+ sc left fog light
- CA WTB: Low Beam Housing Rubber Cover
- CA aftermarket headparts supertech double valve springs arps titanium retainers keepers
- CAN-Other WTB: front upper grill that suit 97-00 sc300/400 bumper!
- FL Lexus SC Trunk w/ Spoiler!!!!!
- FL sc300 rubber a/c lines 40.00 shipped!
