View Full Version : SC400 / 300 Classifieds
- NJ WTB d/s front caliper bracket
- NY FS: 2jzgte vvti head w/intake manifold & throttle body
- CA Tein Basic coilovers SoCal
- NJ WTB: supra tt shocks
- CA WTB Right side 97+ fog light
- WA selling 1992 sc400 lip spoiler
- PA FS: 2jz w58 bellhousing $250
- UT WTB: 5 speed front shaft
- KY WTB: 1jz soarer wiring harness or ecu connectors
- FL WTB Local 98 sc fogs and side markers and pass..headlight
- VA FS : Whole BLACK dashboard
- CA DriverSide Window Trim (No Cracks Here) - Black Back Speaker Panel - META Double Din
- FL WTB W58 TRANNY!!! will pay shipping
- FL WTB: 1JZ twins heat shield
- ID Sc300 Billet Fuel Pump hanger for sale
- CA 2jz motor US Spec
- LA 2jz-ge part out! What do you need?
- CA WTB Axles for a 92
- International WTB: Set of front Converter / Catalyst SC400 -97
- KS Wtb: 1992-93 sc300 ecu!
- NJ WTB: drivers side high beam light, DWP hood & front bumper
- VA WTB: Brakes, Rotors, what you got?
- NY FS: Drewgo Manifold for 2jzgte
- KY WTB Stock Harmonic Balancer
- TX I WTB- Tanabe NF210 springs for the SC400
- MI FS: Stock 92' sc300 parts, high beams, ecu, ect.
- MD Selling Vibrant custome sc300 FMIC and piping. MD
- MN WTB: Factory Pioneer Sub
- NY Wtb:2jzgte single turbo manifold
- CA FS: Apexi SAFC II
- CA SC300/400 AC control faceplate
- LA Fs: 95 sc400 ecu
- VA gas tank door
- WI needed LH Driver Side Window Regulator
- IL FS: BNIB OEM Clutch Master Cylinder
- CA WTB - Power Steering Pump
- MD Front Caliper mounting bracket
- NY 1996 lexus sc 300 manual ecu
- CA ---Apexi AFC2---Greddy BCC---
- CA FS: FMIC, wastegate, varis, clutch fan, PS line, oil catch can
- CA WTT: TIAL 50MM BOV for HKS TYPE2 Racing BOV
- CA Supra TT Brakes, 5 Speed Cluster, Solid Sub Frame Mounts, Nagisa Seat Rail
- KS WTB: 1997 sc300 ecu asap!
- FL 92-94 taillights, ds mirror, 95 12 disk changer, 98 changer, 92 Driver Sd Door handle
- CA WTB: Rear Deck (Shelf) Any Color
- FL WTB moded Lights. name your price :)
- MA Lots of parts for sale NA-T
- NJ Fs sc300 stock wheels
- NV Wtb- front fenders- drivers side door panel - oem wheels
- TX KYB GR2 shocks/ OEM springs
- VA WTB: Passenger Interior Door Handle
- NY lexus sc 300 seats beige
- FL SC300 Full CALIPER rear BRAND new brake pads!!!
- GA WTB: Driver side interior door panel - Tan
- GU FS: 1JZGTE Parts!! Single Turbo Setup
- TX Nakamichi speaker enclosures...FREE+shipping=yours
- CAN-Toronto Fs Mines Aristo Ecu
- NC WTB: Tan drivers side front seatbelt (1992)
- MS LS400 Brake Calipers upgrade kit
- OH Parts for sale
- NC WTB: Tan drivers seat skirt
- VA SC300 engine parts
- NY wtb: big win lip
- CA wtb - tt ps reservoir
- CA Innovate wideband, JL Audio 13 W7, 1000/1, single GTE parts, oem shifter
- FL Need w58 DRIVE SHAFT WTB !!!
- International WTB: 09/1996+ USDM SC400 cruise control module
- MO WTB - Ebay headlights..
- CA 5Zigen Fireballs *NEW* - WOW
- TX Custom CLEAR High Beams
- PA FS: BNIB AEM Wideband $200shipped
- OK FS: 97 Taillights - $250 OBO
- CA FS: 95 Driver side window regulator + motor
- ID FS TT Fuel Pump, ARP Head Studs, AEM Boost Seloniod
- FL NEED w58 Drive shaft and bellhousing!!
- IL Lexus sc 400 oem Lip
- FL Need w58 complete TRANNY
- CA FS: used HKS Camgear
- FL Need r154 tranny badly...!!
- PA Lots of cheap Parts
- CA Nakamichi Headunit & Amp
- FL 2jz-GE For sale !!! PICK UP ONLY
- CA Full complete 5 Speed Swap W58 SOCAL
- CA W58 transmission, 2jzge flywheel and clutch, slave cylinder
- CA Wtb 1jz lower front timing cover
- CA FS: BRAND NEW Auto Meter Gauges
- CAN-Vancouver WTT: Tan Cloth Seats
- CA FS: Vertex Kit (Replica)
- FL fs/S366 turbo
- NY FS: 97-00 Lexus SC300/SC400 OEM Foglights PAIR W harness
- FL Need R154 Tranny WTB !!!
- GA WTB-1jzgte SMIC
- FL 1jz parts
- NY FS: HKS Carbon Titanium exhaust for mkiv
- CA wtb 2jzgte engine (bay area)
- CA wtb: Aristo oil pan w/oil return line
- CA FS: TT brake kit, Custom exhaust, Tein CST, G35 19" Wheels, Sideskirts, Injen.
- FL 1993 Sc300 1jzgte 5 Speed
- TN FS: COMPLETE Turbo kit for NA-t Good stuff here!
- TN FS: Front TT Supra Brakes (calipers, pads, rotors)
- OK JDM Aristo LSD & Pumpkin (3.77:1 ratio) and axles for sale!!!!!
- FL WTB sc300 w58 tanny or R154!!!!
- TN FS: Haltech 2000 Platinum Sport EMS (2jz-ge plug and play!)
- AZ 1uz engine with rebuild kit, cheap
- NY ALL Year SC300/SC400 in stock for PART OUT!!! WHAT DO YOU NEED????
- TX WTB Fan shroud from NTL guys
- ND WTB: fuel pump ecu
- TX WTB: JDM GTE auto ecu
- VA RARE Authentic Bomex Rear Spoiler SC300 SC400
- CA fs 95 auto transmission
- KY WTB SC300 A/C Condensor
- AZ WTB: DR side visor / pass side mirror / rear seatbelt plastic
- CA HKS carbon Ti exhaust for MKIV, JZA80
- OK FS: Lots of SC300/SC400 parts
- OK Parting out GE head (cams, valve covers, cam gears, springs, buckets and more)
- NJ WTB: SC300 Altenator/Headlight bracket
- CA FS: Black Wood Grain Steering Wheel & Black Airbag
- MI Lexus SC300/400 Body Kit
- CA WTB PRE 97 Bumper DWP
- IL Dual Core Carputer with Custom 7in Monitor in Stock Radio Form
- UT 98+ gated shifter tan , great shape . Everything for install included
- UT FS : Ren Red 97+ side moldings great price
- FL FS: CLIMATE CONTROL (good screen no bleeding)
- CA FS: autometer 2" fuel pressure gauge
- CA WTT: Eibach Pro Kit
- FL FS: Greddy Boost Cut Controller & Speed Cut Controller merged
- GA WTB: Coilovers or TT struts/springs
- AL Got screwed..need 1jz ECU
- CA FS: 99 Fogs w/Wiring, 98+ Grill, MDX Antenna Mod
- CT WTB. LS400 BBK & Mint black SC400 hood
- FL Need SC300 left driver side door panel TAN !!!!
- FL sc300 high beam headlights $40 SHIPPED!!!
- IL WTB Sc 300 Fan Shroud
- MD Supra TT Rear Subframe Mounts for TT Sway Usage. $100 shipped.
- FL WTB Soarer 5 speed drive shaft!!!!!!!
- FL WTB: Air Flow Meter
- NY FS: Window Regulators, Climate Control, CD Changer
- AZ Need parts for w58 swap
- FL WTB: Pioneer factory headunit & factory sub
- FL WTB: Passenger Window Trim ASAP!!!
- NY RC engineering 750 CC high impendance injectors
- CA WTB DAIZEN rear sway for 92 SC400
- MA Greddy Fmic kit, Greddy bov, SSqbov, Aem Wideband
- GA WTB 95 SC400 ac condenser and tube that runs to dryer
- OR 92-96 Fog/cornering lights
- FL SC300 fog lights for sale FOG LIGHTS 91 92 93 94 95 $40!!!!!!!!!!!!!!!!!!!!!!
- NV WTB: hood latch cable
- PA wtb: 2jzge body plugs off the engine wiring harness
- TX WTT plus cash- turbo for lowering springs or coilovers
- FL WTB SC300 5 Speed pedal setup!!!!!!!!
- NY Supra subframe mounts
- VA Need Drivers Side Window Trim Fast!!
- FL FS: TiAL 50MM BOV
- OH F.S 1UZ-FE v8 88K miles
- CA WTB: Parts I need for 2jz and manual transmission swap
- WA WTB sc400 Airbox
- CAN-Toronto LF/WTB Nakamichi amp
- ID 5 Spd Rear Diff and Axles For Sale, ECM
- FL Tan Inerior Part out (make offers) (NE. FL)
- CT SC3/400 repair manuals 1992
- FL Really need sc300 97+ fog lights !!!!
- KS WTB: Side skirts and Rear lip to go with my replica JIC Magic Front bumper.
- VA FS: Whole Tan Interior
- MD WTB: SC300 96 2jzge engine harness
- FL For sale sc300 92-95 fog lights 40$
- FL Need SC300 REAR SEATS top and bottom!!!
- FL WANTED sc300 97+ fog lights!!!!!
- CA FS: 5zigen fireball megas!!!
- CA FS: Carputer, 4.08 diff, rear panel black, viper remote start
- CA WTB: A/F Wideband, AEM or MAP ECU, HKS CAMS.
- CA FS: Daizen front bushings, uppers & lowers with sleeves!
- FL SC/Soarer parts and misc
- NY FS: EVO VIII seats with mkiv sliders and brackets
- FL SC400 Drive Shaft!!!!
- ID 0 Mile BoostLogic Auto Trans For Sale
- CA WTB: safcII, wideband, & boost gauge
- CA WTB 1JZ harmonic balancer
- FL sc300-400 car cover
- NC 1995 sc400 parts for sale
- CA upper control arm 1 front 1 rear will ship<<<<
- CA wtt my bike for sc300
- MA Supra TT wheels
- FL wtb: motor mount brackets
- IN WTB: Drivers Inner Door Handle
- NC WTB: SC400/300 Broken Cluster/Or just The Plugs
- NJ FS: 1997+ SC 300 400 tail lights left and right BRAND NEW!!!
- NC WTB: a/c line
- FL WTB OEM Radio
- IL FS: 2JZ-GE bellhousing
- IL Lexus Sc 300 Cluster gated shifter etc
- CA CA: BRIDE gardis III rep seats
- IL FS: 2J-GE stock Camshafts, Starter, more
- IL FS: Aristo Swap Parts - Rear Sump Conversion, Oil Filter Bracket, etc
- CA SC 300/400 LH Driver Side Window Regulator
- TN exc cond headlights for sale
- CA Tom's Advox Coilovers and Brembo brakes
- CA HIC roof spoiler/visor BNIwrapper
- AZ WTB 4" Speaker baffle/housing
- FL WTB: courtsey door light
- CA wtb 2jz w58 bellhousing
- CA WTB: stock exhaust maniford and cat
- CA wtb - soarer downpipe
- GA Soarer BPU Parts: 1jzgte into an SC300
- CA FS: brand new complete hid kit for low and fogs
- NY WTB: 92-00 lexus SC300 fan shroud
- NC FS: SC300 is gone! Garage Cleanout (Intercooler, Supra spare, EGR block-off)
- CA 2JZGTE Aristo motor, ECU
- CA FS: 92 Sc300 Air bag (gray)
- GA FS: 95 SC400 ECU, MAF and ignition coil
- CA Garage Clean-out: MKIV OEM Springs / Shocks, Eibach
- FL Walbro pumps/fuel lines/filter/fittings/IC piping/2JZ-GTE throttle cable
- FL Fs:soarer 1jz w/r154
- CA FS: Nardi/Works Bell/NRG Quick release combo, 95 Tails, VIS CF Hood, 92 OEM Spoiler
- NY RX300 wood wheel with Gs300 airbag.
- UT Tan butterfly cup holder , Lexus trunk mat
- NC WTB: Harmonic Balancer
- IL WTB oem Fan Shroud
- FL WTB rack bushings for sc300!!!***
- CA Wtb 97 up bra
- FL WTB: 1JZ OEM Timing Belt
- MD RELIST - fs: FULLY BUILT 1jzgte head non-vvti
- NY feeler: supra tt auto tranny,jdm twins,tt head and more
- WI PT72GTS $460 Shipped
- CA WTB: yakima roof rack
- CA Need Money Sale!!! HELP
- WI FS: tan seats, window trims, door panels
- NY lexus sc300 seats
- IL Sc oem wood trim good condition
- CA FS: Shine Auto Front Bumper
- SC Basically new OEM auto transmission mount
- TN FS: 2jzGTE/GE rods
- CA WTB: Sc400 Espelir Asd Springs
- FL WTB Fully working auto sc300 cluster (92)
- TN WTB: SC300 Motor mounts in good shape!
- FL WTB:oem front lip spoiler fitted for 97+front bumper
- GA wtb 1994 sc400 transmission solenoids
- FL us 2jz-gte ECU
- FL FS: Sc300 Clutch Fan,Cruise Control,ABS ECU...Etc
- AL FS: Hawk HPS street pads for TT
- FL WTB Passenger Side Fender, pass. 99+ headlight and driver side 97+ FOG
- MD Sc300/400 tan master window switch
- CA cheap parts body parts
- CA FS: ARC shift knob + OEM 6spd knob
- NV Wtb: Stock front lip mounting brackets
- CA WTB: bride FO seat rail
- FL FS 440cc JDM 2JZ GTE injectors
- UT 97+ taillights, fogs , side moldings, grill , gated shifter , wise spoiler , steering
- FL JDM folding mirrirs
