Installed LexionKorea unit
Old Aug 25, 2021 | 12:07 PM
  #301
InveredMP's Avatar
InveredMP
Originally Posted by s3v3n
Thanks for your time on this.
I did plugged in the microphone and the yellow RCA jacks labeled "camera". I know I did made sure I plugged both of them tightly.
Plugged in all the harness T-connectors ends, except the touchpad.
Routed 2 USB inputs that are labeled carplay and android to a accessible exposed area.
There are a couple of rca jacks which i didn't even bother since they have no use.
I hope the issue all lies to that touchpad connector, hopefully, since I can't fully switch to Android. The unit does it itself.
Btw, what is the combo to switch between OEM to Android display?
It’s supposed to and does for most I think, unless people aren’t reporting the issues. Mine doesn’t which is why I complained. I can’t access the Lexus OS at all. Lexion refuses to take care of it so I filed a claim for a defective unit.
Old Aug 25, 2021 | 12:12 PM
  #302
dojoman's Avatar
dojoman
You should definitely plug in the touchpad connector otherwise Android side is messed up for sure. I would definitely double check the backup camera yellow connector. There is another connector that plugs into the cable that you unhooked from oem screen it goes to backup camera. Also in camera setting I chose second option called LVDS but it’s different than first choice. Let me take a pic later. My camera only worked with second option selected.
Old Aug 25, 2021 | 12:49 PM
  #303
jmpickrell's Avatar
jmpickrell
I would plug in the touchpad and see if that somehow remedies all the issues. I've seen stranger things before so I would start with that. I can tell you mine acted a bit odd until I had everything plugged in. No idea if that will resolve your issues but fingers crossed it will. As someone else stated it's just holding the menu button down to switch between the two. It's not instant so it's a long press/hold.
Old Aug 25, 2021 | 01:22 PM
  #304
s3v3n's Avatar
s3v3n
It might be just the touchpad cable. I am so hoping it is. I don't want to drag them into a dispute since the materials and shipping costs money, too. And I kindda like the performance(speed) of this unit.
I will know later today how it goes.
Old Aug 25, 2021 | 01:24 PM
  #305
jmpickrell's Avatar
jmpickrell
Fingers crossed and looking forward to you saying it fixed it!
Old Aug 25, 2021 | 01:36 PM
  #306
undergrou6's Avatar
undergrou6
everything works on mine except I can’t sue the track pad on the OE system. It’s been a few weeks and still waiting on Lexion to provide the correct wiring harness. Not sure if I will ever get one, but at the moment at least the android side works flawlessly. BTW I have an RC so my problems are somewhat similar to the IS.
Old Aug 25, 2021 | 01:37 PM
  #307
jmpickrell's Avatar
jmpickrell
Yeah I have an RC as well and so far everything works correctly. I did have the mouse cursor disappear earlier for a little bit and then it showed back up.
Old Aug 25, 2021 | 01:39 PM
  #308
undergrou6's Avatar
undergrou6
that’s happened to me a few times, I just get out of the CarPlay screen and back into the android screen and the cursor comes back.
Old Aug 25, 2021 | 01:40 PM
  #309
jmpickrell's Avatar
jmpickrell
I did try all that and it didn't change it. It was like it was hung up thinking I had mashed on the trackpad or something and then randomly decided I was done with whatever it thought I had done, lol.
Old Aug 25, 2021 | 06:57 PM
  #310
s3v3n's Avatar
s3v3n
So far so good for me. Had to go thru all the settings, did a trial and error on all the options.
Finally, I have a working head unit, backup camera, audio and apple carplay.
One last thing, Is the touchpad mouse enabled on the Android OS? I see it but it's not moving. I went to settings that Jen posted but didn't see any options about touchpad mouse.
Old Aug 25, 2021 | 07:26 PM
  #311
dojoman's Avatar
dojoman
Go into Settings inside App+ and go to Android setting maybe your cursor sensitivity is turned down? You can’t move cursor in Android but CarPlay is fine?
Old Aug 25, 2021 | 08:03 PM
  #312
s3v3n's Avatar
s3v3n
Thanks. I just re-read Jen's post and carefully followed the submenus. Found the tracking speed settings. Also had to select the ****/Mouse in Input settings.
Old Aug 25, 2021 | 08:32 PM
  #313
s3v3n's Avatar
s3v3n
Originally Posted by rcJten
If you can take a pic of this setting I'd be very appreciative. I have poured through all the advanced settings, but maybe I'm missing something.
Update: I was missing it, and it fixed the issue!! Thanks man!! For those with the spazzy mouse issue go to the android settings and select "system," then "input," scroll to the bottom and click "advanced," and then "pointer speed." For me, 1/3 speed or less gets rid of the jumping.
Thank you rcJten.
This fixed the trackpad issue.
Old Aug 25, 2021 | 08:40 PM
  #314
dojoman's Avatar
dojoman
If only Lexion came with written instructions we wouldn’t have to go through the threads or ask the seller with world’s class customer support.
Old Aug 26, 2021 | 06:18 AM
  #315
jmpickrell's Avatar
jmpickrell
Thank you rcJten.
So you're saying everything is up and working now with getting the pad plugged in and following everyone else's trial and errors?! This is great news! I'm happy to hear it's working properly for you. I also am glad to see everyone pitching in with their knowledge and experience to help each other out in getting these things up and running. Sounds like Lexion needs to be paying all of us as support reps!
