Installed LexionKorea unit
Yeah that really sucks. I hope you're blowing him up on WhatsApp to get another harness and to get it NOW. (Although I think you said you're pursuing a PayPal dispute so who knows if he'll ever get it to you.)
Yea he completely stopped responding. If PayPal takes care of me, I’ll gladly throw this hunk of crap in the garbage.
So you're saying everything is up and working now with getting the pad plugged in and following everyone else's trial and errors?! This is great news! I'm happy to hear it's working properly for you. I also am glad to see everyone pitching in with their knowledge and experience to help each other out in getting these things up and running. Sounds like Lexion needs to be paying all of us as support reps!
Thank you for the touchpad T-connector tip. I would never look on that area and was only focused to that idea that all T-harnesses will go to the back radio head unit and one to the display screen.
Thanks again jmpickrell.
Does 4x4 come with English label on the connectors? At least that's nice touch with Lexion, my OG 4x4 is all in Chinese had to resort to Google translate.
That is correct. Now, given that I am very savvy with IT stuff and honestly I still struggle a bit navigating on the menus, FOR A $900 unit, the seller needs to at least provide a documentation on which specific menu needs to be changed or play with.
I did notice that in the menu for door warning (I think that's what it's called) it's off, left, right. Setting this to left or right does that mean that it'll only show a warning on that particular door being opened? (I didn't test this out and thought I'd ask if anyone else had before I try it myself.)
Absolutely. I'm also very tech savvy (software developer for a living) and I struggled a little with the setup of this unit as well. It wasn't as clear as it could/should have been. I also find navigating some of the menus is a bit tedious and finding where stuff is hidden that applies to x or y in a given situation isn't very clear.
I turned off the door warning waste of space on the screen. I wish I can turn off climate control it's off by 1 degree. Someone pointed out you can mess around with up/down temp real quick and it will sync but then it's off again after adjusting.
Yeah that was me that pointed that out. You are correct you can get it back on temp and then it gets back off just as quick. I'm with you - I wish I could eliminate that pop-up screen as well.
This is also happening on my unit. I noticed it syncs up when it's 66 below, but anything above that it always adds 1 degree.
Also, I got a message from Lexion and they are sending me a new wiring harness for my RC to fix the issue with track pad not working on OE screen.
