IS200t tune
Old Jan 10, 2018 | 01:25 PM
  #2341
IS200TFOWL's Avatar
IS200TFOWL
Originally Posted by PATCHEZ
So the mix would be e15? Or is that e20?
I was quoting full E85TUNE. However it does say on our gas cap ‘up to e20’. We’ll probably be able to run up to e50 without having to upgrade our fuel injectors but eventually someone will have to test the flow of our stock injectors.
Old Jan 10, 2018 | 02:18 PM
  #2342
PATCHEZ's Avatar
PATCHEZ
That’s pretty cool cause there’s a gas station by me with e85
Are our tanks16gals?
So 3-5 gals of e85 and the rest 93?
I’m leaning towards 3gal tops to be safe.. this is only rough calculations lol
Old Jan 10, 2018 | 02:28 PM
  #2343
PATCHEZ's Avatar
PATCHEZ
I’ll try a mild mix on stock tune then after give it a try with the bms tune
I’ll be part of the tuned crew soon muuuhahahaaaa��
Old Jan 10, 2018 | 05:32 PM
  #2344
loophole35's Avatar
loophole35
​​​​​​​Guys I advise against running anything more than 10-15% ethanol in our cars. It requires a much richer mixture. These cars are not flex fuel they can not tell when the go above 15% ethanol (e15). E85 could cause damage to the motor.
Again unless you have an ethanol tune do not us E85 or mixtures past 15% ethanol.
Old Jan 10, 2018 | 06:23 PM
  #2345
IS200TFOWL's Avatar
IS200TFOWL
Yeah Idk if I’d use ethanol mixtures with only the Bms. The only reason I’m using e50 is because ive had two different tuners adjust my ecu to use ethanol specifically. However I don’t thinks gallon of e85 will hurt, most 91 octane gas already has 10% ethanol in it expecially cheaper gas stations. Ethanol is considered to be a safe way to cut’ gasoline. Adding a gallon of e85 to a full tank of 91 will probably give you about 92 octane, at that point it might be best to just pump 93 without using a higher percentage of ethanol which can trigger limp mode
Old Jan 10, 2018 | 08:33 PM
  #2346
Sheddy's Avatar
Sheddy
OV just posted this on their Facebook page. IS200t Stage 1
Old Jan 11, 2018 | 12:03 AM
  #2347
Miintt's Avatar
Miintt
Looks like they also added a dyno tune to their website but the description makes it sound like just a reflash
https://www.ovtuned.com/collections/...200t-dyno-tune
Old Jan 11, 2018 | 05:42 AM
  #2348
zcon's Avatar
zcon
Sheddy when you go get your custom tune ask your tuner how much room we have left in the fuel system, or the injector duty %. I do wonder how much room we have in the system. Injectors and a fuel pump are easy upgrades.
Old Jan 11, 2018 | 06:22 AM
  #2349
Sheddy's Avatar
Sheddy
I'll try to get as much information as i can. Companies like TTI and OV have done a lot of R&D on the 8AR, so I am hoping this tuner can find out all the restrictions and loopholes even though this is his first 200t. His 20 years of experience should shine!
Old Jan 11, 2018 | 07:36 AM
  #2350
PATCHEZ's Avatar
PATCHEZ
What shop?
Old Jan 11, 2018 | 08:02 AM
  #2351
Sheddy's Avatar
Sheddy
STP motorsports 4242 Peters Rd, Fort Lauderdale, FL 33317 . Danielina and i will be there at 10am this coming Monday.
Old Jan 11, 2018 | 08:34 AM
  #2352
PATCHEZ's Avatar
PATCHEZ
by where sound advice was?
btw wanted to share this calculator
http://www.georgebelton.com/E85Calculator.php
running 93 the absolute max is about 1.5 gal of e85 then fill the tank.
depending on the ethanol already in the gas will get you to e15
Old Jan 11, 2018 | 08:45 AM
  #2353
Sheddy's Avatar
Sheddy
Not sure what was there before, but its in bay #16.
Old Jan 11, 2018 | 09:25 AM
  #2354
PATCHEZ's Avatar
PATCHEZ
Sweeeet I’ll end up there after I’m tired of the bms lol
Old Jan 11, 2018 | 09:11 PM
  #2355
Sheddy's Avatar
Sheddy
Thanks Nigel for sharing this. TRD 8AR-FTS upgrade?!?
