IS200t tune
Old Jan 11, 2018 | 10:57 PM
  #2356
IS200TFOWL's Avatar
IS200TFOWL
I hope so. If it’s actually TRd then it might be something that’s covered under warranty if the dealer installs it. Looks like it’s going to be on display at the 2018 Tokyo Auto salon car show’ which starts tomorrow and goes through the weekend
Old Jan 11, 2018 | 11:47 PM
  #2357
GSE20MT's Avatar
GSE20MT
Originally Posted by Sheddy
Thanks Nigel for sharing this. TRD 8AR-FTS upgrade?!?
That seems to be some custom race spec 3S-GTE, which is actually a really interesting swap if you think about it
Old Jan 12, 2018 | 04:20 AM
  #2358
Sheddy's Avatar
Sheddy
I was hoping it was 8AR-FTS upgrade, but you’re right it can be a new generation 3S and they’re just comparing the power differences. Still pretty cool stuff!
Old Jan 12, 2018 | 04:39 AM
  #2359
Sheddy's Avatar
Sheddy
It is an upgraded 8AR-FTS! Spec B looks to be a prototype turbocharger.
3S-GTE successor!
I know this is going to be ridiculously priced, but knowing that they are working to improve this motor tells me that we would be seeing more aftermarket support!
Old Jan 12, 2018 | 07:02 AM
  #2360
loophole35's Avatar
loophole35
With the ECU tuning support now out there aftermarket will jump on board. The 8AR-FTS will be the new 3S-GTE.
Old Jan 12, 2018 | 07:14 AM
  #2361
IS200TFOWL's Avatar
IS200TFOWL
I knew we had a sleeper. That’s really cool guys! So without an upgraded turbo charger it says 289hp 354tq. To bad we’ve had to wait it out so long. Maybe toyota’s way of telling us what it can safely do. Hopefully Tony can match these numbers
Old Jan 12, 2018 | 07:54 AM
  #2362
Sheddy's Avatar
Sheddy
This motor definitely has the potential, so i had to post it on the main forum for the V6 fans lol.
Old Jan 12, 2018 | 07:55 AM
  #2363
E46CT's Avatar
E46CT
Cool upgrade! Yeah it didn't seem right that they'd be resurrecting an old cartoon engine from the 90s (no matter how good it was) the graphic seemed to indicate that this newly tuned engine is a successor.
from the photo, looks like they upgraded or changed the crank pulley. not sure what the white stuff is. looks like plastic. but can't be plastic. white painted steel? weird
Old Jan 12, 2018 | 08:00 AM
  #2364
E46CT's Avatar
E46CT
Also 367ps translates to about 360hp. so at least we know this means this engine (assuming the TRD has no internal/major mods) can safely handle at least 360hp. Which is about 300 wheel... which is about the limit the N20 guys are finding safe. so it all makes sense. Nice, but probably in a lighter car like a future GT86. 360hp is still kinda meh to move around 3,600 lbs.
Old Jan 12, 2018 | 08:04 AM
  #2365
PATCHEZ's Avatar
PATCHEZ
Seems about right for Toyota to starve this engine of power now seeing this.
Old Jan 12, 2018 | 08:11 AM
  #2366
PATCHEZ's Avatar
PATCHEZ
I have a feeling the internals weren’t upgradedBut external like fuel pump injectors and a mc naaaaasty tune from the samurai warriors of the tuning world..Maybe a little turbo tinkering Although I can’t wait till someone pulls this sleeper beast out of its cave and disassembles it so we can really see how strong everything is
Old Jan 12, 2018 | 08:15 AM
  #2367
IS200TFOWL's Avatar
IS200TFOWL
Old Jan 12, 2018 | 08:21 AM
  #2368
Sheddy's Avatar
Sheddy
Originally Posted by IS200TFOWL
Nice! I see an aftermarket waste gate actuator. I wonder if there will be a TRD vacuum regulator lol
It is the 8AR, so that means aftermarket modifications for us.
Old Jan 12, 2018 | 08:29 AM
  #2369
IS200TFOWL's Avatar
IS200TFOWL
If it was crank then 289 would be 245whp which I find to be off. I’m not going to assume these are crank numbers. 289whp and then 360whp on a modified turbo sounds correct.
Old Jan 12, 2018 | 08:33 AM
  #2370
IS200TFOWL's Avatar
IS200TFOWL
Besides to make 289whp the turbo only needs to hold a little less than 18psi. 18psi isn’t really unsafe
