Finally some great numbers! congrats nuke! how did you achieve this? you dyno tuned the car? or you got a new reflash and went to the dyno. Awesome numbers considering that where you live you have such high temps too!
Thanks buddy, this is stage 2+ with full boltons but my DP is a straight pipe so my is loud as hell....will have to go for a rerun maybe coz we couldn’t log the boost due to some dyno issues
Originally Posted by PATCHEZ
Those results are outstanding!!!
if this is just the beginning I have a great feeling about this engine!
Once that turbo is upgraded we’re gonna have ourselves a shocker lol
I’m back on my Stage 2+ tune. It feels great man, I just don’t know why my dyno readings were lower. I am still thinking the bad regulator is to blame.
Am sure this is the issue coz there is nothing special about my car and when I had the bad regulator 10 days ago my stage 2+ wasn't as good as it is now after changing the regulator
Another difference in my car is that it is a straight DP pipe but I highly doubt it can contribute to the power substantially
That’s true. I guess I need an aftermarket midpipe and axle back now to keep up with you guys lol.
is above information is correct nuke’s car should hit around 280 whp on dynojet
Well I raced my brother's WRX STI which is doing a 270WHP on a dynojet and I ate him so maybe ya am around that power band....or maybe the mustang dyno i used is broken :P
What is a Stage 2+ tune? How is it different from the normal Stage 2?
1) Allot of fine tuning for drivability improvement
2) High end boost drop fix (boost holds better on higher RPM)
3) Slightly more aggressive tune setup (Will leave this to Tony to explain)
Well i went to the dyno with a good regulator and stage 2+ full exhaust and catless downpipe and also charge pipe just like you and i only made 245whp and 276wtq thats why i am surprise Tony told me that we have the same tune so idk what would make my car make less power.. :/ there is something off here... thats a 35whp fifference and like 25wtq
When I did the dyno testing for the BMS tune we found out that we were getting better results without the dyno fan. The shop owner at Genesis automotive is also a tuner and he was telling me that this car seems to like the heat. I would like to test the Stage 2 + again, but I think next time I go will be to get dyno tuned. Hopefully then I will get to my goal of 260whp 300wtq with my current setup.
hmmm could it be a busted dyno? will try to find another Dyno to run a test....its hard to find dynos for cheaps here its very expensive to do a run here
hmmm interesting so my car likes Dubai weather you mean :P well these days its around 20~30c day time and inside the dyno room maybe abit warmer
