Exhaust tips
Old Jan 21, 2025 | 09:04 AM
  #91
Timado404's Avatar
Timado404
Veteran: Marine Corps
Originally Posted by rmbrewer
Tim,
What brand is your orange tubing cutter you show back in post #64? I was hoping to find a cheap one at harbor Freight.
Check this one at Harbor Freight, I think it cuts to to 2.5 which is big enough.
https://www.harborfreight.com/no-2-p...AaAqOrEALw_wcB
Old Jan 21, 2025 | 09:10 AM
  #92
Timado404's Avatar
Timado404
After some consideration I decided to go with the clamps I mentioned...not the epoxy.
Cut four, 1"slits on each Tim Tip, (the muffler end), then install clamp.
Old Jan 21, 2025 | 09:42 AM
  #93
Timado404's Avatar
Timado404
Originally Posted by Barncobob
saw the tubing on Aliexpress..search 54mm stainless pipe/tubing.
A mid March delivery but there's one on this page...put this into Google search.
https://www.amazon.com/s?k=LIMITF&ref=bl_dp_s_web_0
Old Jan 21, 2025 | 11:28 AM
  #94
rmbrewer's Avatar
rmbrewer
Originally Posted by Timado404
Thanks, I like how your cutter rolls the edge, which looks more finished. I realize the other end needs cut differently to slip over.
Others wanted their tips to be a larger diameter, thus necessitating the removal of the surrounds. I, like you, just want them to be more visible. I like the surrounds and will eventually black them out with vinyl wrap. I had given up on extending the tips until I saw your post. Removing the surround and leaving the mounting bracket exposed would drive me nuts.
Extending the tips may also cut down on the discoloration of the surrounds now that I drive more in Sport+ mode.
Rob
Old Jan 21, 2025 | 04:07 PM
  #95
Timado404's Avatar
Timado404
Rob
Yeah, that was exactly my reasoning for this project. I wanted to keep the surrounds intact and I just wanted to be able to see the dang quad tips.
And you're correct, you get 2 nice, clean ends on 2 cut pieces with the pipe cutter...then you have to break out some sort of saw.
Old Jan 22, 2025 | 05:28 AM
  #96
Barncobob's Avatar
Barncobob
how do U get the rounded end instad of a straight 90 cut?
Old Jan 22, 2025 | 11:00 AM
  #97
rmbrewer's Avatar
rmbrewer
^^^ I believe the rounded end is done by the pipe cutter as it presses into the pipe to cut it.
Old Jan 22, 2025 | 11:31 AM
  #98
Timado404's Avatar
Timado404
rmbrewer is correct. The rounded end is the end cut with the pipe cutter. You have to apply a good deal of pressure as you're making the cut, and it just slightly bends over the end as it's cutting through the material. The 304 grade Stainless I'm using in this DIY is more pliable than a more rigid metal that would make a less rounded cut. 316 Stainless would do the same. I chose 304 for its corrosive resistant properties. Having a lot of nickel in it, it does pretty well...especially where I live, (Atlanta).
Old Jan 22, 2025 | 12:14 PM
  #99
rmbrewer's Avatar
rmbrewer
^^^ or, perhaps we could use a flaring tool to spread the pipe a bit more open (rather than closed) at the visible tip end for a different look.
I'm betting Timado has a flaring tool, lol.
Old Jan 22, 2025 | 03:16 PM
  #100
Timado404's Avatar
Timado404
Flaring tool...yeah, I got that...LOL.
I like the rolled end look, though.
Old Jan 23, 2025 | 04:15 PM
  #101
Timado404's Avatar
Timado404
Should wrap up the TimTips DIY tomorrow, when I get the clamps. Cut 1" slits in the tips today.
Old Jan 23, 2025 | 06:13 PM
  #102
CrossTownTraffic's Avatar
CrossTownTraffic
Just to add to the conversation, I had the chrome on my valance painted as well as the exhaust ports. I very much like the look as it is now, but take no position on having the exhaust pipes show through the exhaust ports. All looks good to me and is a personal preference. Here's a pick of the rear end. I got the car back from the detailer today who had sent it to a painter to do the valance.
Old Jan 24, 2025 | 03:49 AM
  #103
Timado404's Avatar
Timado404
Blacked out looks beautiful, especially on that yellow. Good look! 👌🏾
Old Jan 24, 2025 | 06:09 AM
  #104
Barncobob's Avatar
Barncobob
enjoying ur progress, might try it myself.
Old Jan 24, 2025 | 07:50 AM
  #105
Timado404's Avatar
Timado404
Thank you sir...been a pretty easy project, just the way I like them.
