Exhaust tips
Old Dec 19, 2024 | 06:40 AM
  #31
harryjames's Avatar
harryjames
I tried this about a year ago - didnt like how there is no clearance of the tips to the rear diffuser as well as how unfinifshed the diffuser looked looked without the surround in place. I was also worried about removing the stiffnes the original surround added to that area. I went back to the original until I had time to address those 3 factors.
1- design a stiffer for replacing original surround
2- drop the rear exhaust hanger by 1/4 inch to provide a small bit of clearance of the tips to the diffuser
3- design and 3dprint something to cleanup where the surround was
if I ever pick this project back up I'll post the solutions - right now too many other priorities
Old Dec 19, 2024 | 06:45 AM
  #32
np20412's Avatar
np20412
With the 4" tips there was definitely zero clearance. In fact the tips touched the top trim of the diffuser, and heat cycling made them rub against it and left scrapes on the exhaust tip from where it expanded and contracted. I don't think 3.5" tips would have this problem as the clearance would be there.
Old Dec 19, 2024 | 06:54 AM
  #33
Barncobob's Avatar
Barncobob
just ordered some tips 54mmx89mm slant cut SS from Aliexpress in China. Will post pics whenever they show(hope they work out)
Old Dec 19, 2024 | 07:50 AM
  #34
rstx's Avatar
rstx
Originally Posted by np20412
I think you nailed it. With the chrome piece blacked out/removed it flows much better IMO (not my Pic)
Interesting on this car they completely removed the chrome trim pieces (3) above the exhaust tips. Or maybe this is not the stock diffuser at all. I dont see the mounts for the stock chrome exhaust trim either.
The three "upper" stock chrome pieces are highlighted below.
Old Dec 19, 2024 | 08:01 AM
  #35
np20412's Avatar
np20412
The center piece of the diffuser appears to have been cut, you can see it there if you look closely. Seems they dremelled off the angled pieces where the mounting bolt for the exhaust chrome surround goes
Old Dec 19, 2024 | 08:16 AM
  #36
rstx's Avatar
rstx
Hmm true. I would love to remove all the chrome and gray trim on the car. Would prefer all the trim to match in gloss black. Wrapping would probably be cheapest option. I dont love the layout of the rear diffuser/chrome trim with the "fake" upper exhaust trim.
Old Dec 19, 2024 | 09:26 AM
  #37
np20412's Avatar
np20412
Agreed. I painted mine with plastidip luxury metal. Easier than wrapping and still removable.
Old Dec 19, 2024 | 04:28 PM
  #38
np20412's Avatar
np20412
Mounted my new tips with my armytrix exhaust. These are 3.5" instead of 4".
Old Dec 24, 2024 | 04:35 PM
  #39
Timado404's Avatar
Timado404
Veteran: Marine Corps
Does the chrome trim just pull/pop out? Release some type of retaining clips?
thanks...
Old Dec 24, 2024 | 04:49 PM
  #40
np20412's Avatar
np20412
thanks...
I'm unsure about the long horizontal piece or the two small pieces that make the small rectangles. I did not remove these to plastidip, I just masked off the entire rear end of the car with a painters cloth I had lying around.
The big chrome exhaust surrounds come out by taking out 4 screws on each housing, and you need to remove the covering first underneath as well. I posted the instructions for that part earlier in the thread.
Old Dec 24, 2024 | 05:51 PM
  #41
Timado404's Avatar
Timado404
Thanks for the quick response.
I know about the exhaust surrounds, thanks. I too dislike that long chrome piece running across the back, I'm sure it pops off, I'll just have to give it a good looking over. Probably paint it with some Spraymax 2K or vinyl wrap it.
Old Dec 24, 2024 | 05:54 PM
  #42
Timado404's Avatar
Timado404
Originally Posted by Barncobob
just ordered some tips 54mmx89mm slant cut SS from AliExpress in China. Will post pics whenever they show(hope they work out)
I'm definitely interesting in what you get from AliExpress...
Old Dec 24, 2024 | 08:20 PM
  #43
Timado404's Avatar
Timado404
Doesn't look like the 3.5's would fit inside the surrounds either...
Old Dec 25, 2024 | 05:57 AM
  #44
Barncobob's Avatar
Barncobob
ordered on 18th,just got email they cleared customs in LA and should be here in 4-5 days.
Old Dec 25, 2024 | 09:17 AM
  #45
Timado404's Avatar
Timado404
Cool Beans!
I'm toying around with some basic, straight chrome extension tips that slip on and just peek out eeeeeeever so slightly... Very understated and just enough so that you can see the car has quad exhaust. (through the surround)
