Exhaust tips
Old Jan 26, 2025 | 03:18 PM
  #121
Sundriver's Avatar
Sundriver
Veteran: Air Force
Wondering if the vapor drip from the extended tips will have a negative effect on chrome.
Old Jan 26, 2025 | 03:20 PM
  #122
Barncobob's Avatar
Barncobob
maybe with small paint brush paint the visible parts of clamps black so they blend into the blackhole.
Old Jan 26, 2025 | 06:02 PM
  #123
Timado404's Avatar
Timado404
Veteran: Marine Corps
Originally Posted by microsup
@CrossTownTraffic is right glossy stainless exhaust tips will look awesome on a contrast with black surrounding. When tips surrounded by chrome they are visually lost.
I'm not wanting the tips to be a main player here. Being somewhat visually lost, just works fore me. All I wanted was a slight peek, that a quad exhaust does exist.
Old Jan 26, 2025 | 06:07 PM
  #124
Timado404's Avatar
Timado404
I contemplated this very thing. If it happens and takes several years, I will just replace surrounds with new ones. If it happens far more frequently, I might consider the blackout option that CrossTown and microsup are suggesting.
Old Jan 26, 2025 | 07:01 PM
  #125
Sundriver's Avatar
Sundriver
Veteran: Air Force
👍🏽Good call!
Old Jan 27, 2025 | 03:10 AM
  #126
Timado404's Avatar
Timado404
I adjusted the camera lighting so you could see how it all goes together, otherwise clamps aren't visible.
Old Feb 7, 2025 | 11:49 PM
  #127
LS460SC430's Avatar
LS460SC430
Originally Posted by rmbrewer
The pipe is already out of stock on Amazon.
it's back in stock! I just ordered mine as well as the clamps & cutting tool 😎
Old Feb 7, 2025 | 11:51 PM
  #128
LS460SC430's Avatar
LS460SC430
Hey Timado404 - Why did you decide to go with the clamps instead of the cement?
Old Feb 8, 2025 | 12:25 AM
  #129
LS460SC430's Avatar
LS460SC430
That's cool, so no painting required 😎
Old Feb 8, 2025 | 06:37 AM
  #130
Timado404's Avatar
Timado404
I just wanted to keep some flexibility within the project... That particular cement is permanent, It works great. If you don't want the hassle of installing the clamps, a small dab of high temp RTV would work just the same. It will hold the tips in place but will also allow the ability to remove them.
Old Feb 8, 2025 | 06:41 AM
  #131
Timado404's Avatar
Timado404
The only time you can see the clamps is if you get on the ground, right behind the car and look straight into the exhaust. So no, I didn't paint them. Actually thinking that a high temp coat of black paint would make a nice look as well ...
Old Feb 8, 2025 | 09:29 AM
  #132
Timado404's Avatar
Timado404
It's been 2 weeks since the installation of my exhaust tips. Just wanted to share a pic of the discoloration, so far.
Old Feb 19, 2025 | 04:28 PM
  #133
LS460SC430's Avatar
LS460SC430
Wow, the discoloration is significant IMO, especially after a mere 2 weeks. I figured stainless steel would not discolor at all or at worse, only slightly. Can you post another picture after a month or so? I'm wondering if it will continue to discolor as time passes, or if this is the worse it will get. Thanks for sharing!
Im not sure if it's the resolution on my screen, but the outboard pipe seems more discolored than the inboard pipe. How is it in person?
Old Feb 19, 2025 | 04:35 PM
  #134
Timado404's Avatar
Timado404
Wow, the discoloration is significant IMO, especially after a mere 2 weeks. I figured stainless steel would not discolor at all or only slightly at best. Can you post another picture after a month or so? I'm wondering it will continue to discolor as time passes, or if this is the worse it will get. Thanks for sharing!
You're very welcome. I will post another pic in some more weeks. I think this is close to as far as it's going to discolor if any more, at all. I personally like the contrast it has with the exhaust surrounds. 👍🏾
Old Feb 19, 2025 | 04:40 PM
  #135
LS460SC430's Avatar
LS460SC430
I understand, maybe it's not as bad seeing it in-person. I have all the parts, I was just waiting for warmer days to do the install.
