View Full Version : SC400 / 300 Classifieds
- CAN-Toronto WTB: 051 White Passenger Side Body Parts
- CA WTB : 97+ Front Bumper
- WA Used SC400 slotted
- CA FS: 202 black moldings, inner tie rods, 4ply silicone elbow coupler
- CA WTB cluster or needles
- NY FS: 3 spoke steering wheel airbag / 4 spoke air bag
- TX 2jz complete rear upper and lower oil pans
- CA WTB 92-94 driverside tail light
- CA WTB: sc300 clutch pedal
- FL WTB: Engine undercover tray
- MI Outter passngers headlamp needed.
- FL *** Brand new OEM GTE pistons, rods and piston ring set ***
- NV FS/2jzge Man ECU,sc300/w58 used clutch
- FL FS: Used LS4 Drilled & Slotted Rotors (fresh)
- TX HID PnP kit
- NY Black L Emblem For Sale or Trade
- CA WTB PRE 97 DWP Front Bumper
- KY WTB: List of things, look inside.
- WA WTB: Missle Rear Wider Fenders
- CA FS SC 3/400 Rear window visor HIC (SD/LA local pref) $90
- TX WTB: Interior Parts for my 95 sc400
- KS WTB: Exterior lower door molding.
- CA FS: SCx00 parts - aftermarket and OEM -LOOK INSIDE!
- WA FS Broke in half lip, pass side door switch, cup holder, shifter bezel misc
- FL sc300 polished intake manifold + egr block off plate
- CA WTB:TT/GTE/SC400 Power steering reservior
- NJ WTB: 92-96 SC400 Ignition and KEY
- CA WTB Coolant Tank / Reservoir
- TX FS: Brand New supra TT rotors
- CA HKS Cams & Cam Gears for 1JZGTE
- CA in need of radiator..
- IL FS : Sc300 Glass High Beams
- NY FS: Lexus LS400 Front Calipers
- CA WTB Supra Wheels
- CA Wtb clear side markers
- WA FS: 1JZ VVti with R154 and PowerFC
- TX Wtb: Sc300 ecu
- OK **R154 swap parts/RPS clutch, 3.2 diff, Black Int/Tan Int. Bride Low Max seat!!!!**
- FL WTB Driver Side window Regulator
- CA want to trade brand new aem oil pressure gauge for a new oil pump
- CA FS 2jzge MT ECU
- CA SC300 Front Lower Control Arms- Good Bushings!
- NY SC300 Part out - 97 Grill - Black body parts
- LA WTB 1997 Driver side skirt and moulding
- CA Selling front lower control arms - sc300/sc400
- IL FS: Front and rear seats
- CA FS/trade 2JZGE moter/ parting
- WA Drivers side interior and exterior door handles
- CA WTB:sc300 5 speed clutch pedal
- NY FS: Adjustable fuel pressure regulator
- NY 2jzge 50k with w58 complete swap...plug and play
- WI oem black sc seats out of a 95 sc300
- WI front pass uca/w prothane bushings
- TX 1996 4 spoke steering wheel and airbag
- FL Two 10" 325lb Hypercoil springs and a fuel pump ecu
- IA WTB passenger side 95-96 fog light lens
- NJ 97+ Brand New OEM Foglights & Grille
- MD Need shocks, springs, or coilovers for 1inch+ drop.
- CA complete drop in 2jzgte/r154/eletronics/mist stuff
- CA Nitro rc car. soarer body ready to play new engine
- FL 5 speed Soarer diff
- TN Bolt on SC300/400 trailer hitch $60 shipped
- CA WTB: IACV for '92 SC400
- CA For sale: Xerd headers, midpipe with o2 sensors
- FL WTB: Perfect working Gauge Cluster for 94 SC400
- IN 97 sc400 nakamichi amp needed
- FL Black 3-spoke Wood steering wheel
- CAN-Toronto HKB Steering Boss/Hub Adapter
- WA SC 400, LS 400 maf and sensor
- NJ FS: SC300 REAR slotted brake rotors
- CA Fs: passenger fender.
- CA WTB: 92-94 SC300 Maf Sensor
- CA FS: w58/v160 speed sensor
- NY sc 300/400 parts
- FL WTB: 2jzgte throttle cable bracket
- UT FS: Lexus trunk mat , Tan dash cup holder
- CA WTB - SC300/SC400 sidemarkers, stock cheap ones
- CA WTB sc300 diff open or welded
- CA Eibach Prokit w/KYB GR2's
- CA 92 oem front lip good condition $150 firm 91770 - 91746
- FL SC400 Nakamichi Head Unit 12 Disk Player + more
- CA NorCal FS: Soarer R154, Supra MK3 R154, 1JZ bellhousing (Pickup Only)
- CA WTB:Complete Soarer Intercooler w/piping and SC400 P/S reservoir
- AL wastegate, DBC, Tomei Gauge, Trust Elbow.
- WA SC front rotors and calipers
- NY 1997 SC300 A340E Transmission
- CA Fs: 97+ oem body kit parting out.
- IL 5 speed shifter console with heated seat buttons
- CA 2JZ/1JZ rear sump setup (COMPLETE with bolts)
- FL F/S Hks boost controller (like new)
- FL WTB Soarer R154
- CA WTB rack and pinion 97 sc300
- MD WTB: Richwood or Bullet Manifold for 1uz
- FL FS: SC300 front brakes and rotors as well as front/rear driver, passenger seat belts
- MA Fs/ft: Mt ecu
- CA WTB 93sc repair manual
- CA 3' secondary cat back exhaust F/T stock mid +$ or?
- NV FS mkiv supra w58
- FL WTB Any inside door handle
- CA Nakamichi Head Unit - 1992 SC400 - $60 shipped
- AL Original Black SC400 Steering Wheel w/ Bag Center Console
- CAN-Toronto WTB, trunk panels, door handle
- MD Scxxx parts
- FL need a 92-95 sc400 tranny located 813-727 area
- CA FS: ATx Plate, Subwoofer Cover, K&N Air Filter, Passenger Switches
- TX rc 750cc injectors w/ clips
- CA ** WANTED - 97+ Spoiler LED OEM lights **
- OK Selling my almost complete W58 swap!!!!!
- OK WTB::Underhood cruise control unit for 97+ SC300!!!
- I need a 92-95 tranny in tampa 813-727 area
- GA RARE! BNIB C's Short Stroke Shifter for Toyota Soarer JZZ30
- NY Rebuilt 2JZGE-T motor (just drop in the boost)
- CA Halo 194 LED
- CA Stock OEM 2jzge fuel rail and injectors
- TX WTB black sun visors & ac vents
- IL FS: Greddy Emanage Blue with Injector Harness and Software!
- CA wtb name brand used wastegate
- GA BUYING: R154 Tranny
- PA SC300 Seats/Steering Wheel.
- FL Bumper and spoiler
- FL FS: ARP Head Studs 2JZ
- IL Caged Hardtop SC300 shell, Custom NA-T setup, FFIM, PT67R, Koyo, R154 full swap
- TX WTB w58 non swan neck shifter
- CA 97+ Sideskirts & Rear Bumper + Extensions FRP
- CA Free: 2jzge (high milage) San Diego
- NY FS: Black interior parts - Blowout - Name a price
- NY FS: Dunlop Snow Tires and Rims
- NY WTB : 97+ parts
- TX 2JZ-GTE Longblock .020 over
- NY FS: 92-96 Spoiler - does not have cutout for the brake light
- CA Tein SuperStreets for MK4 Supra
- Ksport Coilovers
- CA SC400 Parts Catalog
- WA Uncracked Center Cents
- CA SSQV BOV "Purple Insert" - never used $15
- NM JDM Blitz Access ECU, Apexi NEO SAFC-2jz-gte
- CA New SC300 Manual Shifter Boot- $35
- CA WTB SC300/400 parts
- TX FS APEXI universal turbo N1 muffler
- FL Auto Couture front bumper! (not replica)
- CA FS: PHR Th400 Driveshaft
- CA FS: PHR SC Breather Kit
- NC wtb parts!!!!
- CA Megan Racing SC400 Engine/Trans Mount $200 shipped
- NY FS: Make an offer sale
- NY FS: 97 Climate Control
- MD BIG - Garrett 60-1 .70 a/r t3 flange turbo
- CA FS: Newly Reupholstered Front/Rear Leather Seats & Armrest
- CA WTB 95-96 or 97+ tail light harnesses
- TX WTB sc300 master clutch cylinder ASAP.....
- i need a front n rear bumper =(
- AZ FS: Tan driver window controller, Black 95 spoiler
- FL Driver Side Wood $30 Shipped & 99-00 Changer
- FL 1jz automatic trans
- NY FS: 97+ Rear Bumper and Quarter Extensions
- AZ WTB: Window motor
- CA WTB black driver side door handle unit!
- FL WTB: Black Passenger Side Door Handle
- CA Used SOARER Emblem
- GA FS: Greddy Type S Boost controller and gauge $320obo end of year cleanup
- CT Lexus sc400 headers for sale!!!
- GA FS: 92-94 Set of Red Lextech needles $60 shipped
- OK Buy 94-95 sc400 TEMP CONTROL MODULE!!!
- CA WTB: single turbo setup
- TN FS/FT: Beck Arnley Alternator for 2JZ 95+
- TN FS: e-fans
- TX WTB: ABS Brake Booster Master Cylinder
- TN FS: 2jzGE (1995) bottom end w/ oil pump & other stuff
- NC WTB SC300 Window drvier side regulator
- TN toyota 97+ toyota Chaser auto trans
- NY WTB: 1JZGTE Soarer Harness & ECU
- AZ WTB: Broken headlight DR or Pass side.
- GA FS/FT - DPW 95 trunk lid + spoiler + led
- NY FS: Black seatbelts front and rear
- TX 1jz gasket kit, no rear main
- NY FS: Tan Armrest
- IL WTB: Ivory door panels
- NY FS: 97 sc300 Cluster with harness clips
- CA WTB: ACS Replica fRont
- CA FS: Black 3 spoke steering wheel with airbag
- TX 97+ red rear bumper with side extensions...
- International WTB: SC300 clear headlights (modded)
- GA WTB: parts for 92 SC400 and 95 SC300
- CA 92-96 OEM Spoiler Light
- TX WTB map ecu
- TX w58 spec stage 2 clutch kit and w58 flywheel
- CA sc300/400 hood $50
- NC WTB Black Interior Pieces for 92 Sc3
- CA WTB factory amp (So cal)
- FL FREE!!!! A/C control unit(bleeding)
- VA FS : Tan Cup holder
- CA f/s brand new aem oil pressure gauge digital
- NY 3 spoke tan wheel: 75 shipped
- TX h.i.d. kit for sc
- CA OEM SC Springs and OEM Supra Springs
- CA wtb a few parts in socal
- CA FS: SC400 Slotted iRotors and Posi Quiet Brake Pads Front and Rear
- NY FS: Pair of 97 Headlights no leaks, all tabs in tact
- NY FS: CD Changer
- NJ WTT/WTS: stock suspension
- NY FS: Butterfly cupholders
- CA fs :97+ oem complete kit ,blk
- CA WTB- Driver side tan seat belt
- NC WTB: Vertex Canards.
- CA WTB 97+ front bumper
- WA Oem supra springs :)
- CA 93 SC300 Full Tan Interior And Other Stuff
- MA WTB: Lot's O Stuff
- TX RX350 Windshield Washer Nozzles (upgrade)
- CA 2 sets of 5 mm spacers, 10 mm spacer
- NJ Wtb pair of stock rims
- MD Sc300/400 mirrors
- MD Sc300/400 tan door panels
- NY FS: Precision 46mm wastegate brand new in box
- SC WTB rear sump oil pan
- NY Garage Sale: turbo parts, lighting parts etc.
- CA fs 98 sc tan steering wheel w/ airbag
- FL Brian Crower springs and retainers
- CA WTB 97+ grill
- CA Wtb sc400 maf
- CA wtb airbag harness
- CA WTB: nor-cal, ls400 or supra mkiv calipers, 97+ door tr$im, 92+front lip + others
- CA Roof/Rear window spoiler
- NY FS leftover ScX00 parts
- NC wtb 2jz water pump pulley
- CA 94 Sc300 parts
- TX FS: 1000cc Precision Injectors & Clips, Custom GTE Fuel Rail, AEM Peak & Hold Driver
- CA 98+ intrepid fogs
- CA WTB 92 sc4 serp. belt TENSIONER 91770
- CA FS: NEW - SRT Intake for 98-00 SC400s
- NY Black Interior Parts to two tone your interior
- MD WTB: W58 or R154
- IL Black interior parts
- FL WTD: ATX Shifter Handle
- CA WTB Vertex or raceon wide body front bumper
- NY FS: 97 Door Molding and SideSkirt
- CAN-Toronto Wtb : 98 sc400 abs sensor
- CA 92 SC Black bumper
- TX WTB: AEM ems 1050 box
- GA FS: W58, driveshaft, pressure plate and clutch disk...Pick up Only!
- TN WTB: 95+ Front Bumper Cover
- CA WTB Passenger side side skirt
- CA Wtb: Stock spring
- CA WTB/WTT: DPW Wingless/92-96 Trunk
- MD FS: T4 Turbo Blanket & GE/GTE Alternator & Starter.
- VA Shine Auto SPEC-A/ AC Replica Front Bumper
- LA WTB: Passenger Side Lower Control Arm
- NY Junking Car Today
- NY WTB 97 Front Bumper
