View Full Version : SC400 / 300 Classifieds
- VA WTB - 92sc400 Engine Undercover
- NY oem toyota wheel bearing
- NY vertex rep rear lip
- CA 95 Tail Lights FS
- CA WTB 98+ SC300/400 auto transmission and a few other parts
- WA Wtb: Stock sc400 stereo
- CA Parts for sale
- TN Black & Gray interior pieces, 5spd cluster, struts, hi beams, more
- GA 1998+ SC300 Gated shifter, no surround.
- GA WTB: Seats
- NJ WTB: OEM sc400 lip
- CA front hood cable wanted locals prefer
- OK WTB: Driver Side Window Motor
- OK WTB: Clear Side Markers
- TX wtb rack n pinion/ oem front bumper
- MD WTB: 1JZ IACV in perfect working condition
- FL looking for gte intake
- PA MAF and TPS...in working condition
- CA FS: Tein CST V2 for Sale (Lots of pictures)
- WA WTB: Supra sway bar mounts
- CO Wtb: 2jzgte patch harness
- CAN-Toronto Soarer power folding mirrors
- NY WTB exhaust manifold (catalytic converter)
- AZ FS: MAP ECU 3 with PHR harness
- CA WTB: Grey Interior Seats - Rear Sub Cover - OEM radio
- TX Injectors, ECU, R154 Clutch, Fuel Pumps, Radio, 5spd pedals, Mounts, Sidemount
- CA JZ to Z33 Flywheel adapter/TOB with Extended Sleeve
- NY 2jzgte swap/ soarer r154
- TX WTB: RX tan/wood steering wheel
- FL FS: Supra Rear TT calipers
- CA ISO: SC300 Lower Exhaust Manifold
- FL wtb oem supra susp/ sc400 lowering springs
- ME 1jz CXRacing Single Turbo Manifold, RFP1's, Precision Turbo, etc...
- TN WTB rear camber bolt
- FL Steering wheel and quick release hub f/s.
- FL WTB rack & pinion
- CA WTB: OEM upper shock mounts
- WTB: sc300 shifter from blown w58 trans
- CA LS400 Calipers
- FL WTB Heater Control Valve
- TX FS: '98 Tan steering wheel airbag
- FL FS: Tan center armrest (Mint)
- FL WTB Adjustable rear upper control arms
- WA Wtb: Nakamichi amp
- CA Prospeed Axel back dual exhaust
- MD Brand New Performance Parts
- CA wtb: 97+ front bumper grill
- CA WTB: 97 front bumper black. Cash in hand
- CA OBD1 95% Complete auto 2JZGE with Trans for sale/trade
- CA aem v1 verified by aem
- MN WTB SC door Actuator
- FL Tein Super Street coilover for sale
- MO 1992 sc400 ecu
- CA WTB: Looking for a Tanabe axle back exhaust, replicas okay
- FL SC400 Headlights (from 1999 SC400)
- For sale: stock 1jz twin turbos
- CA wtb sc OEM center cap
- FL looking for battle version tie rods for 92 sc300
- FL SOARER Digital Cluster for your SC300/400 (From 95 AUZ JZ)
- PA 2jzge AFM
- TX SC400 Supercharger setup
- CA FS : 2 butterfly cup holder
- GA WTB: SC300/400 Hood in METRO ATL
- TX sc300 harness redone in braided nylon setup for AEM v1 and lq9 coils
- AZ FS: 1991 Toyota Supra MKIII Manual Driveshaft
- FL MAP ECU, Inj Resistor Pack, 1jz stuff ect.
- NY FS:Soarer R154,used ACT extreme clutch kit,1jz flywheel,mk3 front half DS
- TX Extra parts from my build - OEM 99 SC300, JDM Supra, & Aftermarket Parts
- TX Selling a few things
- TX Brand new AEM sensors (IAT, mac Boost solenoid, AEM Stainless steel 3.5 bar)
- TX FS: 01+ GS tan/taupe steering wheel w/e-shift
- CA Black sc300/400 front seats for sale
- NC FS: OEM Tan floor mats, MISC parts
- CA 5 spd front driveshaft
- MD -10 RMR Fuel Rail / gte swap , trans swap R154
- FL Clutch Pedal, VVTi 1JZ downpipe stuffs
- OK GTE Serpentine Belt Tensioner Assembly - GTE PS Reservoir Nipple
- NC Wtb: Bcc
- FL F/S Supra seats
- FL R154 MKIII shift retainer housing brand new with seals (for extension)
- CA wtb soarer power steering reservoir with bracket and fuse box lid
- FL 97+ Spoiler/Rear Bumper, OEM R154 Clutches, & Autometer Oil Gauge
- CA XSPower 2JZ-GE FFIM, T4 Manifold, 1JZGTE Auto Trans - Anaheim, CA
- CA FS: Black 1997+ door moldings $150 picked up
- GA auto transmission
- CA FS: 1993 Supra Front Seats Tan Great condition PICKED UP!!!!
- VA WTB: 440c injectors, safc 1 or 2
- SC interior parts
- TX Greddy & DWP OEM items
- NJ SC 300/400 Blue LED Climate Control & Mint Black Leather Shift Knob F/S!
- NV FS: BC BR Type Coilovers
- FL sc oem lip with brackets, 92-96 oem spoiler with working leds.
- CA FS: few tan inertior belts/ doubledin dash kit and more!
- GA Auto TT LSD Diff
- NY WTB Zee's Wangan Wing
- FL wtb gated shifter and rx steering wheel... and 97 fogs
- TX AEM Wideband UEGO controller $120 OBO
- TX Eibach Springs/KYB Adjustables $400 OBO
- GA WTS: 2000 SC300 OEM Body Kit
- FL Front & rear Tan seats for sale
- VA WTB sc300/400 tan left door panel
- IL Ebay headlights broken, good lenses
- GA WTB: RHD Real Soarer Front Windshield
- GA WTB: Raw Clear Lens Material
- GA WTB: Manual Shift Bezel/w Boot
- AL FS: SP Quick Spool Valve
- AL Aristo 2jzgte for sale
- AL FS: SC300 A/C Lines, SC400 rear end, 1JZ cams, AEM Dry intake, brake booster, etc..
- CA WTB: 1JZ soarer sc300 stock hotside intercooler piping
- TX Blitz Nur Spec dual axleback exhaust
- PA Fs.. 92 sc300 parts n supra read diff
- PA Wtb vent gauge pod 92 sc300
- MA wtb black sc trunk without spoiler
- CA WTB crankshaft timing gear
- OK OK Black/Wood 3 Spoke Steering Wheel
- CA WTB: 98+Air box
- FL WTB clutch fan and shroud
- MD FS: 1JZGTE Chaser Soarer ECU A/T (needs to be re-capped)
- WA FS: Maf , ECU , Ignition coil
- CA fs tokico blues will ship
- PA WTB: OEM Drivers Headlight
- NM WTB: Mint Back seats for SC400
- NM FS: SC400 Headgaskets OEM Denso BRAND NEW
- MD WTB 1JZ Chaser/ Soarer Ecu ASAP
- NY WTB used coilovers...
- MO WTB: Need a few things, OEM and Aftermarket
- GA Random Parts- Garage clean out
- FL 2jzge Cast Turbo Manifold *Not EBAY!*
- CA dimming rear view mirror lens for lexus sc300/400
- GA FS: Supra tt RH front lower control arm-slight balljoint cover issue
- CA more parts to get rid off
- FL Wtb: 95 sc400 ecu
- IN Black and Spruce Interior Parts + More!!!
- FL need rack and pinion for 92 sc300
- NY WTB prothane or daizen LCA bushings
- NY WTB: gte swap harness
- FL Thread: huge part out list (( pics upon serious request))
- CA Looking for a 1jz map sensor !
- CA WTB: Tan Drivers Seat, Fan Shroud, ECU for 93 A/T
- WA WTS: 1 Rear Megan Coil, Universal oxygen sensors, hubcentric rings (all cheap!!)
- AZ FS: JDM Toyota MKIII Surpa Turbo R154 Transmission (60K)
- CA R154 from MKIII Supra
- NY FS: 95 tails, Megan Coilovers Supra Seats
- NJ 93 sc400 shift bezel
- NY FS: 97 Tails with harness - 150 each or 300 for the pair
- NC WTB: Working Climate Control for 95 SC 300
- IL 1995 taillights with harnesses
- FL Moving sale misc 2J parts
- CA SC400 stock radiator/Overflow tank, 97 SIDESKIRTS+ wing, hyd fan, stock air box, etc
- CA 5spd front driveshaft also r154 and w58
- CA FS/FT sc400 lip. other sc stuff
- AL 1uzfe motor for sale 101k miles on it
- CA 97+ tailights and harnesses MINT
- CA WTB 97 tail passenger
- Power Transistor
- CA FS-Rare 5Zigen*Fireball*Mega*Exhaust for sc300/sc400
- VA WTB: 2jzge engine or just block locally out of va
- NY Wtb: Aftermarket GTE intake ma
- VA WTB: 1jz engine pref locally out of Virginia
- NY Not enough history
- CA Fs: almost new sc300 eibach lowing springs and stock struts
- FL wtb sc grill 97-00
- OH Biggu's SC is sold need to sell the rest of parts
- MD WTB: 2JZGE non-VVTi Motor
- OK Interior parts, NEW heater control valve, Wiring Diagrams
- CA New Treadstone 2jzge stainless cast manifold.
- CO w58 clutch kit Beck/Arnley oem style
- NY stock SC400 drive shaft
- NJ WTB: tail light socket or harness
- NY WTB: 1jzgte r154 or soarer gear box
- FL WTB: Driver Door Assembly
- CA FS: Clear headlight covers,Origin CF roof wing,blk steering wheel
- NY WTB - Platinum Metallic Trunk - 97+
- TX IS350 Hyper wheel set OEM
- CA Fs 1999 fog lights and climate control
- NY WTB: Axle half shaft bolts / stub axle bolts
- FL For sale Aristo 440cc injectors
- WA WTB Passenger side spark plug wire clamp
- CA Wtb coilover
- TX wtb: sc300 shell 94 n up in TX
- CA brand new 14mm 1200cc gas/e85 injectors $350
- AZ WTB: GE/GTE lower timing belt cover
- TX WTB stock CD changer for '96 SC400
- KY full set black seat belts, other random black interior parts
- FL 2jzge LS400 TB, ARP Wheel Studs, Muteki
- NY 2JZGE starter and IAC
- AZ FS: Tial Q BOV (Never Used)
- GA MKIV Supra Twin Turbo Rebuilt Calipers R154 Driveshaft Cheap
- WA Wtb: Stock amp for sc400
- CAN-Toronto MKIII Toyota Supra Turbo Drive Shaft (R154)
- CA WTB 20mm-30mm spacers
- FL FS: Aristo lsd diff
- IL WTB: Automatic / Dildomatic shift knob in grey or black
- NM FS: Authentic HKS 40MM Wastegate - $400
- TX WTB: sc300 97+ parts: LCA both sides, Brake pads, trunk struts.
- AZ FS: Toyota OEM 1JZ/2JZ R154 Flywheel
- OK SC300/400 Heater Control Valve
- NY FS: 3 gauge pillar pod
- CA [NorCal] OEM front lip Black
- AZ FS: OEM 1998 SC300 Pioneer Radio MINT CONDITION
- AR FS: Blitz ZZ-R coilovers, OEM blk leather, Is300 str wheel/Airbag, 1jz vvti M/T ECU
- AZ WTT/WTB Eibach Lowering Springs for SC300. My Espelir for your Eibach
- NY need some info
- GA 2jzge Turbo Manifold Manual ECU 97+ Black Side Skirts Fenders
- PA 2jzgte Jdm stock twins, manifolds, complete assemblies f/s
- IL 5 speed swap complete, black interior
- PA 93 SC300 MAFS, Driveshaft Donut/Rubber
- TX FS: Passenger Side window switch (TAN)
- GA WTB 97+ Driver tail light and Pass. side fog light
- CA WTB: 1998 OEM Fog Lights SC400
- CA WTB: SC400 Air box/Stock intake
- NY 92-95 sc400 cluster
- NY FS black leather rear seats, excellent condition
- AZ FS: R154 Shift Fork
- FL Need a pair of 96 sc300 fog lights
- GA 95 LS400 BBk, Supra Titan Sway Bar Kit, Door Panels and more
- NY BNIB sc300 sc400 upper control arms
- NY WTB AC Shine Front Bumper or rep
- TX FS: PBM, BV, ATL, GReddy, Shell
- CAN-Vancouver WTB: R154 transmission
- TX AEM v2 30-6101 sc300
- PA FS SC400 Drivers Window Regulator *Never Used*
- NY wtb: Soarer Gear box
- CA FS: 97 Front Bumper
- CO FS: Shop clean out 2jzgte ge 1jz
- WA Soarer 1jz ecu
- WA 1997 ls400 bbk
- CA rays wheel lugs red
- NM FS: SC300 Driveshaft
- AZ SC300 Black Center Console Lid
- FL Fs:heater control valves
- FL FS: Black/Wood RX steering Wheel w/airbag
- RI FS sc300/400 driveshaft and sc400 ecu
- CA car tent for the winter good for backyard local ony
- TX Supra Front Lower Control Arms- new in packaging
- MD 97+ grill, 92-94 ECU, 95+ A/Ccontrol unit
- CA looking for a carbon fiber trunk
- TX New AEM Uego wideband and Greddy BLK boost gauge
- CA FS - front and rear gray cloth seats
- CA WTB sc300 95 shifter
- GA FS- 95-96 Tail lights / Gated shifter
- TX AEM v1
- CA wtb:Supra Solid Rear Subframe Mount
- TX Tripod w58 swap
- CA Trust / greddy jdm maf adapter
- CA 1JZGTE Spark Plug Cover (center)
- WA 1jzgte parts//sc300 parts
- TX Tan sc300 three spoke airbag wheel
- TX Sc400 rear calliper&upper control arm susp.
- FL WTB 1jz bell housing for r154...
