FL WTB Heater Control Valve
OP, if you haven't found a replacement yet and you are willing to carefully use a Dremel to trim some excess plastic and a screwdriver to swap over the little arm from your stock HCV you can swap in a new Everco (aka Four Seasons) #74636 HCV. It is nearly the same thing and works just fine. This, assuming your solenoid still works. If not then you will need a whole replacement assembly.
https://www.clublexus.com/forums/per...ml#post8330556
94SC4
SC400 / 300 Classifieds
12-08-09 05:13 AM
