IS200t tune
Old Jan 12, 2018 | 10:03 AM
  #2386
Sheddy's Avatar
Sheddy
SPEC A- More than or equal to 215KW (288hp) 480NM (354ft lb)
SPEC B -More than or equal to 270KW (362hp) 500NM (368ft lb) Prototype turbocharger
Old Jan 12, 2018 | 11:53 AM
  #2387
daniellina's Avatar
daniellina
Seems that around 250whp is what the engine can do with the stock turbo but we still have room for torque, lets see what the dyno tune does.
Old Jan 12, 2018 | 11:57 AM
  #2388
Sheddy's Avatar
Sheddy
Nuke did get 262whp 290wtq with TTI stage 2+, so TRD needs to step their game up! ..lol j/k
These are not official numbers since i do see the "greater than or equal to" symbol before the figures.
Old Jan 12, 2018 | 01:24 PM
  #2389
PATCHEZ's Avatar
PATCHEZ
Those are some awesome numbers
giggity giggity lol
Old Jan 12, 2018 | 01:36 PM
  #2390
IS200TFOWL's Avatar
IS200TFOWL
The difference between spec A and B. Spec A most likely peaks 23 psi and holds 18 psi whileSpec B peaks 24 psi holds 21-20 psi. Spec B peaks slightly higher 1+ psi, spec B holds more boost than spec A producing more hp.
Old Jan 12, 2018 | 01:41 PM
  #2391
PATCHEZ's Avatar
PATCHEZ
Originally Posted by IS200TFOWL
The difference between spec A and B. Spec A most likely peaks 22-23 psi and holds 18 psi whileSpec B peaks 23 psi holds 20 psi. Spec B peaks slightly higher 1+ psi, spec B holds more boost than spec A producing more hp.
B spec has a prototype turbo Do you think they just upgraded the intervals or a bigger turbo?
Old Jan 12, 2018 | 01:44 PM
  #2392
Sheddy's Avatar
Sheddy
SPEC B has a prototype turbo charger as well. I would love to get the full specs on these setups, hopefully soon we will see more information surface. I also want to think that this is the motor that they are using on the Gazoo Racing RC200t. Lots of that gold heat reflect stuff.
Old Jan 12, 2018 | 01:55 PM
  #2393
IS200TFOWL's Avatar
IS200TFOWL
Our ‘engine’ will do much more than 250whp on the stock turbo. I knew everyone would look at it and assume crank. 250whp is a light tune holding around 14psi. Our turbo/engine can do much more than only hold 14 psi
Old Jan 12, 2018 | 02:06 PM
  #2394
IS200TFOWL's Avatar
IS200TFOWL
Spec B appears to have a modified turbo, the modified turbo with bigger inlets/outlets and turbines will allow the stock turbo to hold boost better and safer. I highly highly doubt they did anything to the engine internals. Spec b at the most probably requires an upgraded intake manifold, fuel upgrade, exhaust and a modified turbo. If any of our internals needed upgrading it would be the pistons. If they swapped the aluminum alloy pistons to forged pistons then we could probably hit 500whp. The pistons are our only weak point on the our engine
Old Jan 12, 2018 | 02:14 PM
  #2395
IS200TFOWL's Avatar
IS200TFOWL
This motor definitely has the potential, so i had to post it on the main forum for the V6 fans lol.
Hahaha I love it
Old Jan 12, 2018 | 06:32 PM
  #2396
IS200TFOWL's Avatar
IS200TFOWL
Audi A4/mk6 ea888
Focus ST
​​​​​​​fk8 type R
TRd 8arfts
All engines have integrated exhaust manifolds
Old Jan 12, 2018 | 07:52 PM
  #2397
Sheddy's Avatar
Sheddy
Yea a lot of manufacturers are going this route, so soon we should see aftermarket turbos that can just bolt on.
Old Jan 12, 2018 | 08:29 PM
  #2398
IS200TFOWL's Avatar
IS200TFOWL
It looks like the integrated exhaust manifold has its own oil cooling system. You can see it port right into the top of the manifold
Old Jan 12, 2018 | 11:52 PM
  #2399
matttev's Avatar
matttev
I see you guys talking about fuel. Do you guys recommend anything other than 91 octane for a 2017 with a stage 2 tune?
Old Jan 13, 2018 | 05:20 AM
  #2400
loophole35's Avatar
loophole35
93 or true race gas. I would not use e85 or mixtures as it requires more fuel. On the subject of the exhaust ports. The Honda motors went to the integrated manifold back in mid 2000’s on the v-6’s and a bit later on the 4 cylinders. Toyota also have done this on the new 2GR (2GR-FKS) this motor is in the new Camry, Tacoma, RX and GS. A turbocharged version will come in the LS500 likely designated 2GR-FTS. Interestingly the FKS has not found its way into the RC or IS.
