alignment issue
Old May 21, 2010 | 10:52 AM
lisc300's Avatar
lisc300
Default alignment issue
i recently bought some rpf1 the staggered supra fitment, 17x8.5 and 17x10 with a 40 and 38 offset respectively.I am grunning 275 40s on the rear. Got My tire mounted and balanced at STS. The guy who aligned them said Since I lowered it the factory spec alignment wouldnt work. I got my car back no problems in the front but the rear was a disaster. The spec sheet for my rear wheels rear reads:
left rear
-.9 degrees camber
.25 degrees of toe
right rear
-1.9 degrees camber
.25 degrees toe
The diagram shows my rear wheels at less than a 90 degree angle mean the wheel and tire is slanted away from the tire well which I always thought meant overly positive camber.
what can I do to correct this
Old May 21, 2010 | 01:18 PM
good2go's Avatar
good2go
left rear
-.9 degrees camber
.25 degrees of toe
right rear
-1.9 degrees camber
.25 degrees toe
leaning in at the top = NEGATIVE
leaning out at the top = POSITIVE
Usually, lowering creates negative camber, some of which can be corrected with camber kits.
Old May 22, 2010 | 07:16 AM
lisc300's Avatar
lisc300
it has sick positive camber. What do you think caused this. I recently got into a rear ender fender bender,could that have possible caused that..If I got a camber kit it should correct my issue but would I allow me to have even tire wear
Old May 22, 2010 | 09:41 AM
good2go's Avatar
good2go
... The spec sheet for my rear wheels rear reads:
left rear
-.9 degrees camber
.25 degrees of toe
right rear
-1.9 degrees camber
.25 degrees toe
I'm not really following this contradiction
Did the alignment shop screw up that badly??...or is there some other confusion here?
Old May 23, 2010 | 10:01 AM
lisc300's Avatar
lisc300
ok in reality the shop negative camber reading was really positive because the top of the tire is pointing out from the fender. I thought a car being lowered causes negative camber..what can be wrong..I recently got into a car accident could that have caused the positive camber..
Old May 23, 2010 | 02:07 PM
good2go's Avatar
good2go
Absolutely. But if your alignment shop is telling you it's negative and you can see it's leaning out at the top, you need to find a more reputable shop.
Old May 23, 2010 | 04:40 PM
StiCk3's Avatar
StiCk3
i wouldn't jump to conclusions...
are you sure your eyes arent playing tricks on you? What the shop said is probably the correct numbers. Something isn't adding up here. Your 3rd post is contridicting your first post. You have Negative camber in the rear if the top of the tire leans toward the car. If it's positive the top of the wheel will lean away from the car. So which is it?
Also to correct those numbers i would try to bring the right rear in (more positive) or get the left rear to lean out (more negative)
Old May 24, 2010 | 07:55 AM
good2go's Avatar
good2go
^^ your post seems to imply that camber is adjustable
To the OP, how about posting some pics so we can see what you're seeing.
Old May 24, 2010 | 08:41 AM
need2boost's Avatar
need2boost
because it is....to a certain point
Old May 24, 2010 | 09:26 AM
good2go's Avatar
good2go
^^ true, I was just assuming the shop had his adjustments maxed. Still seems they should be able to get the left rear closer to the right though.
Old May 25, 2010 | 06:53 PM
StiCk3's Avatar
StiCk3
That's because it IS. As is every other alignment angle on the car.
just as long as you can get the numbers on both sides close to each other it shouldnt be too much of a problem. I'd rather have both rear tires wear down faster as opposed to just one wearing down faster than the other. If the tech can't get the numbers to move any more, then you might have to look into replacing more suspension parts.
question: have you had the car aligned before swapping to coilovers? just trying to get a history on the car.
nandob
Suspension and Brakes
Feb 21, 2014 05:29 PM
nioks
Jan 18, 2011 09:27 AM
Lexy602
IS - 1st Gen (2001-2005)
14
Aug 7, 2010 07:10 AM
UpInTheLex
Jun 4, 2008 11:58 PM
na4now
Sep 17, 2007 09:45 PM
