Toe adjustment........
Old Sep 6, 2007 | 12:07 AM
na4now's Avatar
na4now
Default Toe adjustment........
What are you guys doing about the rear toe, when you lower the rear. Is there plenty of factory adjustment for that, when you get an alignment.
My car is pretty low, and mine are WAY toed in. I didnt realize quite how bad it was, till I put a 4 ft level on them.
Old Sep 6, 2007 | 09:27 PM
na4now's Avatar
na4now
I know there are several of you that are slammed. Are you doing nothing?
Old Sep 17, 2007 | 09:15 PM
SiennaII's's Avatar
SiennaII's
There should be enough adjustment with the factory suspension. My SC is dropped on Teins and I havent had any problems dialing the alignment in properly.
Old Sep 17, 2007 | 09:39 PM
Blizzy's Avatar
Blizzy
I am -1.5" in the rear. My rear toe is 0.20. Rear camber is -1.4.
I am -1.9" in the front. My front toe is 0.00. Front camber is -0.6. Caster is 5.8.
I am on factory alignment rods. The only mark out of spec is the front camber (-0.5 is factory allowable). My tire wear should definitely not suffer.
Old Sep 17, 2007 | 09:45 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
I run -2.7 rear, -2.0 front... with 1.8ish drop
tons of adjustment for everything...
MIC123321
Aug 23, 2015 08:39 AM
doodoo
Nov 14, 2014 04:26 PM
nandob
Suspension and Brakes
Feb 21, 2014 05:29 PM
iSexy
Oct 30, 2012 07:24 PM
mong
Jun 24, 2011 03:32 PM
