IS200t tune
Old Dec 10, 2018 | 01:01 PM
  #3496
Sheddy's Avatar
Sheddy
Gazoo Racing's RC200t used for SP3T class racing. Still trying to find a good picture of their 8AR-FTS.
Old Dec 10, 2018 | 07:29 PM
  #3497
EXE46's Avatar
EXE46
Originally Posted by Sheddy
Has anyone test driven the 2019 model? I would like to know if the updated ECU made a difference...
I came here looking for the answer to this question. Lexus should update our ECU's too with the update they did to the 2019's....sigh
Old Dec 11, 2018 | 01:50 AM
  #3498
vanillatag's Avatar
vanillatag
What else are different for the 2019 model?
Old Dec 11, 2018 | 08:51 PM
  #3499
EXE46's Avatar
EXE46
This is all that's new for 2019 in the USA :
  • Software updates improve engine response on rear-wheel-drive models
  • New upgraded LED headlight option
  • Amazon Alexa-integrated voice commands
Old Dec 11, 2018 | 08:56 PM
  #3500
zhifan1's Avatar
zhifan1
I just want the software update to improve engine response.
Old Dec 12, 2018 | 06:52 AM
  #3501
Sheddy's Avatar
Sheddy
"Alexa- I need more power!"
I might have to take a trip to the local dealer to see for myself.
Old Dec 12, 2018 | 07:59 AM
  #3502
EXE46's Avatar
EXE46
Do that and let us know, thanks. I see no reason why they can't update our cars.
Old Dec 12, 2018 | 08:49 AM
  #3503
Burrcold's Avatar
Burrcold
100% guarantee they won't update anything.
Old Dec 12, 2018 | 09:14 AM
  #3504
loophole35's Avatar
loophole35
It's not that the dealer won't do it, it's more of can they do it. The dealership don't care either way so there is no reason for them to hold back a program that could be avalible.
TLDR the dealers would update if it's available for update. It's not available as of right now FYI.
Old Dec 12, 2018 | 03:14 PM
  #3505
AKNRI's Avatar
AKNRI
For the Lexus production JB4 only Map 0 (JB4 disable) Map 1 (+4psi) and Map 2 (+5psi) are active.
No proven power gains between the 2 systems. The JB4 just allows you to connect to the OBD port for engine readings like AFR, boost, etc.
Just installed JB4, but stock boost gauge never goes over 0.75 bar unless it's in 1st gear it goes to 1.25 bar. Prior to installing JB4, the stock boost gauge would max out all the time and flash red.
Does this mean JB4 is set to map 0? Anyone know which map it defaults to once installed?
Old Dec 13, 2018 | 06:48 AM
  #3506
OrangeVirus Tuning's Avatar
OrangeVirus Tuning
Originally Posted by vanillatag
Definitely following up on this.
Early next year will be our release. And we will be implementing our custom EROM patching to this ECU.
It completely changes ...everything about tuning this car. As we now have control to customize and change actual tables in the ECU to do what we want, how we want, etc.
For example in the Tacoma we really didn't like how the ignition control is setup, so we created our own ignition table for the ECU to follow. as seen below.
Old Dec 13, 2018 | 10:21 PM
  #3507
ModTrav's Avatar
ModTrav
Finally some good news!
Old Dec 14, 2018 | 09:17 AM
  #3508
Sheddy's Avatar
Sheddy
With a piggyback tune the stock boost gauge will read the altered (lower) boost signal being sent back to the ECU. The JB4 should be set to MAP 1 (+4psi).
Old Dec 15, 2018 | 03:33 AM
  #3509
KPCresta's Avatar
KPCresta
Wow that is some exciting news for IS200T owners and potential purchasers! I am sure I read that there is a 'high flow' turbo being developed as well? So in saying that could we realistically expect better than tuned IS350 performance with full bolt on mods? Or close to A45 AMG numbers??
Old Dec 16, 2018 | 01:56 PM
  #3510
Sheddy's Avatar
Sheddy
I am currently running the stock down pipe with the TTI Stage 2+ reflash and the car feels sluggish again
